EM520
AXIAL LEADED RECTIFIER DIODES
VOLTAGE RANGE: 2000V
CURRENT: 1.0 A
Features
Diffused Junction
Low Forward Voltage Drop
High Current Capability
High Reliability
High Surge Current Capability
B
A
A
C
D
Mechanical Data
Case:DO-41 Molded Plastic
Terminals: Plated Leads Solderable per
MIL-STD-202, Method 208
Polarity: Cathode Band
Weight: 0.35 grams (approx.)
Mounting Position: Any
Marking: Type Number
DO-41
Dim
Min
A
25.40
Max
¾
B
4.06
5.21
C
0.71
0.864
D
2.00
2.72
All Dimensions in mm
Maximum Ratings and Electrical Characteristics
TA = 25C unless otherwise specified
Single phase, half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%.
Symbol
EM520
Unit
VRRM
VRWM
VR
2000
V
VR(RMS)
1400
V
IO
1.0
A
Non-Repetitive Peak Forward Surge Current 8.3ms Single
half sine-wave superimposed on rated load (JEDEC Method)
IFSM
30
A
Forward Voltage
@IF = 1.0A
VFM
1.1
V
@TA = 25°C
@TA = 100°C
IRM
5.0
500
µA
Cj
15
pF
RJA
50
K/W
Tj
-65 to +125
°C
TSTG
-65 to +150
°C
Characteristic
Peak Repetitive Reverse Voltage
Working Peak Reverse Voltage
DC Blocking Voltage
RMS Reverse Voltage
Average Rectified Output Current (Note 1)
Peak Reverse Current
At Rated DC Blocking Voltage
@TA = 75°C
Typical Junction Capacitance (Note 2)
Typical Thermal Resistance Junction to Ambient (Note 1)
Operating Temperature Range
Storage Temperature Range
Note: 1. Leads maintained at ambient temperature at a distance of 9.5mm from the case
2. Measured at 1.0 MHz and Applied Reverse Voltage of 4.0V D.C.
1 of 2
www.sunmate.tw
2 of 2
www.sunmate.tw
很抱歉,暂时无法提供与“EM520”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.34659
- 100+0.27857
- 300+0.24451
- 1000+0.21895
- 5000+0.19853
- 10000+0.18838
- 国内价格
- 10+0.31770
- 100+0.25535
- 1000+0.20070
- 2000+0.19769
- 5000+0.18198
