0.6[0.02]
XKB Product features
2.4[0.09]
Voltage: < 12V
Current: < 20mA
Conduction time: 2ms
Closed circuit resistance: < 10m ohm
Open circuit resistance: > 10m ohm
High temperature resistance: 120 degrees
Terminal tension: 500gf / min
Humidity: 25~95%RH
Operating life: 100000 times
Down 10 degrees OFF
XKB Product features:
XKB
1.SW-520 is a double ball type single direction tilt induction trigger switch.
1.SW-520
2. When the product tilts towards the cap end, the tilting Angle is greater than 10 degrees,
the product is in the open, (OFF) state;
When the horizontal state of the product has a tilt change, the trigger end (gold-plated pin
end) is lower than the horizontal and the tilt Angle is greaterWhen the Angle is 10 degrees,
the product is in the closed circuit, (ON) state.
2.
10
10
Down 10 degrees ON
ON
3. When the switch tilts parallel to the direction of the PIN and the tilting Angle of the
trigger PIN end is less than 45 angles, the switch is in the OFF state;When the inclination
Angle of the trigger pin end is greater than 45 degrees, it is in the closed-circuit ON state.
3.
45
45
4. The products of this specification are completely sealed, waterproof and dustproof.XKB
4.
5. This switch is suitable for triggering small current circuit, not for power switch.
5.
6. This product is made of environment-friendly metal material with stable performance.
XKB
6
ON
Heat shrinkable tube
OFF
OFF
ITEM
X
X
X
MARK
units: mm
tolerance:
PET
Rubber stopper
Ball
Ball
Guide pin
Copper tube
1
1
1
1
1
1
Heat resistant nylon
iron
iron
Brass
Brass
silvering
silvering
Gold-plated
PAPT NAMF
QTY
MATERIAL
FINISHING
DSND
DATE
SCALE: N/A
MODEL TYPE:
DWN
DATE
VIEW:
PART NO.:
CHKD
DATE
UNIT: mm/in
APPD
DATE
REMARK
Vibration switch
DWG NO.:
DESCRIPTION
REVISIONS
www.xk-dg.cn www.helloxkb.com
DATE
REVISED
APPROVED
UNSPECIFIED TOLERANCES
www.helloxkb.cn
XKB INDUSTRIAL PRECISION CO.,LIMITED
SW-520DS-AB12G
WEIGHT
1.0g
SHEET
1/1
REVISION
A0
很抱歉,暂时无法提供与“SW-520DS-AB12G”相匹配的价格&库存,您可以联系我们找货
