XKB Product features
Voltage: < 12V
Current: < 20mA
Conduction time: 2ms
Closed circuit resistance: < 30m ohm
Open circuit resistance: > 10m ohm
High temperature resistance: 240 degrees
Terminal tension: 500gf / min
Humidity: 95RH 40 degrees 96 hours
Operating life: 200000 times
A
XKB Product features:
XKB
1.SW-58010 series is a sealed spring type non-directional vibration induction trigger
switch, which can be triggered at any Angle.
1.SW-58010
2. This series switch is in the open circuit OFF state when it is stationary. When it is
touched by external force and reaches the corresponding vibration force, or when the
moving speed reaches the appropriate (partial) centrifugal force, the conductive pin will
produce instantaneous conduction and present ON state;When the external force
disappears, the switch reverts to the open circuit OFF state.
2.
B
0.8[0.03]
3, This series switch with P model, for the completely sealed package.
3
P
4. This series of switch trigger sensitivity is very high.
4.
5. The life of this series switch can reach 200,000 times in normal use.
5.
6. This series switch is suitable for toys, burglar alarm, electronic scale and other
electronic products. XKB
6
body A
1
1
1
1
1
Brass
Rohs epoxy resin
Phosphor copper
Brass
silver plating
PAPT NAMF
QTY
MATERIAL
FINISHING
Coat the brass
sealing rubber
spring B
ITEM
X
X
X
MARK
units: mm
tolerance:
NICKE
0.10
DSND
DATE
SCALE: N/A
MODEL TYPE:
DWN
DATE
VIEW:
PART NO.:
CHKD
DATE
UNIT: mm/in
APPD
DATE
REMARK
Vibration switch
DWG NO.:
DESCRIPTION
REVISIONS
www.xk-dg.cn www.helloxkb.com
DATE
REVISED
APPROVED
UNSPECIFIED TOLERANCES
www.helloxkb.cn
XKB INDUSTRIAL PRECISION CO.,LIMITED
SW-58012PWD-4A9B1
WEIGHT
1.0g
SHEET
1/1
REVISION
A0
很抱歉,暂时无法提供与“SW-58012PWD-4A9B1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.25048
- 100+0.23432
- 500+0.21816
- 2000+0.20200
- 5000+0.19069
- 10000+0.18584
- 国内价格
- 5+0.53493
- 50+0.43524
- 150+0.38546
- 1000+0.34820
- 2000+0.31828
- 5000+0.30338
- 国内价格
- 5+0.54350
- 50+0.44220
- 150+0.39160
- 1000+0.35380
- 2000+0.32340
- 国内价格
- 1+0.70840
- 100+0.52990
- 500+0.41070
- 1000+0.29770
- 5000+0.26790
