WR02X474JAL
WR02X474JAL
    WALSIN(华新科)
    贴片电阻 0201 470KΩ ±5% 1/20W ±200ppm/℃
WR02X474JAL 数据手册
Approval sheet WR02X(W) ±5%, ±1% Thick Film General purpose chip resistors Size 0201 *Contents in this sheet are subject to change without prior notice. Page 1 of 7 ASC_WR02X_V18 MAY - 2016 Approval sheet FEATURE 1. Small size and light weight 2. High reliability and stability 3. Reduced size of final equipment 4. Suitable for high density print circuit board assembly 5. Higher component and equipment reliability 6. Lead free product APPLICATION • Mobile phone • PDA • Camcorders • Palmtop computers • Hybrid module DESCRIPTION The resistors are constructed in a high grade ceramic body (aluminum oxide). Internal metal electrodes are added at each end and connected by a resistive paste that is applied to the top surface of the substrate. The composition of the paste is adjusted to give the approximate resistance required and the value is trimmed to nominated value within tolerance which controlled by laser trimming of this resistive layer. The resistive layer is covered with a protective coat. Finally, the two external end terminations are added. For ease of soldering the outer layer of these end terminations is a pure Tin. Fig 1. Construction of Chip-R WR02X Page 2 of 7 ASC_WR02X_V18 MAY - 2016 Approval sheet QUICK REFERENCE DATA Item General Specification Series No. WR02X(W) Size code 0201(0603) 1Ω~10MΩ ( ±5% tolerance ), Jumper Resistance Range 1Ω~ 10MΩ ( ±1% tolerance ) Resistance Tolerance ±1% ±5% E96/E24 E24 10Ω - 10MΩ, ≤±200 TCR (ppm/°C) 1 - 9.76Ω, +600~-200 Max. dissipation @ Tamb=70°C 1/20 W Max. Operation Voltage (DC or RMS) 25V Max. Overload Voltage (DC or RMS) 50V Operation temperature -55 ~ +125’C Note : 1. This is the maximum voltage that may be continuously supplied to the resistor element, see “IEC publication 60115-8” 2. Max. Operation Voltage : So called RCWV (Rated Continuous Working Voltage) is determined by RCWV = Rated Power × Resistance Value or Max. RCWV listed above, whichever is lower. DIMENSION(unit : mm) Protective c oat WR02X(W) L 0.60 ± 0.03 W 0.30 ± 0.03 T 0.23 ± 0.03 Tb 0.15 ± 0.05 Tt 0.10 ± 0.05 T End term ination Tb Resistive layer Tt Ceramic Substrate W T L MARKING WR02X(W) has no marking. Page 3 of 7 ASC_WR02X_V18 MAY - 2016 Approval sheet FUNCTIONAL DESCRIPTION Product characterization Standard values of nominal resistance are taken from the E24/E96 series for resistors with a tolerance of ±5% & ±1%. The values of the E24/E96 series are in accordance with “IEC publication 60063” Derating The power that the resistor can dissipate depends on the operating temperature; see Fig.2 Figure 2. Maximum dissipation in percentage of rated power As a function of the ambient temperature MOUNTING Due to their rectangular shapes and small tolerances, Surface Mountable Resistors are suitable for handling by automatic placement systems. Chip placement can be on ceramic substrates and printed-circuit boards (PCBs). Electrical connection to the circuit is by individual soldering condition. The end terminations guarantee a reliable contact. SOLDERING CONDITION The robust construction of chip resistors allows them to be completely immersed in a solder bath of 260°C for 10 seconds. Therefore, it is possible to mount Surface Mount Resistors on one side of a PCB and other discrete components on the reverse (mixed PCBs). Surface Mount Resistors are tested for solderability at 235°C during 2 seconds. The test condition for no leaching is 260°C for 30 seconds. Typical examples of soldering processes that provide reliable joints without any damage are given in Fig 3. Fig 3. Infrared soldering profile for Chip Resistors WR02X(W) Page 4 of 7 ASC_WR02X_V18 MAY - 2016 Approval sheet CATALOGUE NUMBERS The resistors have a catalogue number starting with : WR02 X 472_ J A L Size code Type code Resistance code Tolerance Packaging code Termination code WR02 X : Normal 5%, E24: 2 significant digits followed by no. of zeros and a blank J : ±5% A : 7” Reeled taping (15Kpcs/Reel) L = Sn base (lead free) : 0201 W : 1% For 1MΩ 4.7Ω = 4R7_ 100Ω = 101_ 10KΩ F : ±1% P : Jumper T : 7” Reeled taping (10Kpcs/Reel) D : 7” Reeled taping (20Kpcs/Reel) = 103_ H : 13” Reeled taping 1%, E24+E96: 3 significant digits followed by no. of zeros 100Ω =1000 37.4KΩ =3742 (50Kpcs/Reel) G : 13” Reeled taping (70Kpcs/Reel) TEST CONDITION FOR JUMPER (0 Ω) Item Power Rating At 70°C Resistance Rated Current Peak Current within 5 sec Operating Temperature Page 5 of 7 WR02 1/20W MAX.50mΩ 1A 2.5A -55 ~ +125°C ASC_WR02X_V18 MAY - 2016 Approval sheet TEST AND REQUIREMENTS (JIS C 5201-1 : 1998) TEST Electrical Characteristics JISC5201-1: 1998 Clause 4.8 REQUIREMENT PROCEDURE / TEST METHOD 0Ω Ω Resistor - DC resistance values measurement Within the specified tolerance - Temperature Coefficient of Resistance (T.C.R) Refer to “QUICK Natural resistance centigrade. R2 − R1 × 106 R1 (t2 − t1 ) change (ppm/°C) per change in degree REFERENCE DATA”
WR02X474JAL
物料型号:WR02X(W) 0201(0603)
器件简介:该电阻器采用小型化、轻量化设计,具有高可靠性和稳定性,适用于高密度印刷电路板组装,提高组件和设备可靠性,且为无铅产品。
引脚分配:文档中未明确指出具体的引脚分配,但通常这类电阻器为表面贴装型,两端为外部端接点。
参数特性: - 电阻范围:1~10M(±5%容差),跳线 - 电阻容差:±1%,±5% - 温度系数(TCR):10 -10M, +200 ppm/°C (1~9.76, +600~-200 ppm/°C) - 最大耗散功率:1/20W(环境温度70°C) - 最大工作电压:25V DC或RMS - 最大过载电压:50V DC或RMS - 工作温度范围:-55~+125°C
功能详解: - 电阻器采用高等级陶瓷体(氧化铝)构造,内部金属电极通过电阻浆料连接,并通过激光修调至标称值。 - 电阻层被保护层覆盖,外部端接点为纯锡,易于焊接。
应用信息: - 适用于手机、PDA、摄像机、掌上电脑、混合模块等。
封装信息: - 尺寸:L 0.60±0.03 mm, W 0.30±0.03 mm, T 0.23±0.03 mm - 标记:WR02X(W) 无标记
WR02X474JAL 价格&库存
很抱歉,暂时无法提供与“WR02X474JAL”相匹配的价格&库存,您可以联系我们找货
WR02X474JAL
  • 100+0.00454
  • 500+0.00427
  • 1000+0.00386
  • 5000+0.00332
  • 10000+0.00300
库存:14950
WR02X474 JAL
  • 200000+0.00222
库存:1320000
WR02X474 JAL
  • 1+0.888971+0.11476
  • 10+0.1681610+0.02171
  • 25+0.1203925+0.01554
  • 50+0.0938350+0.01212
  • 100+0.07530100+0.00972
  • 250+0.05703250+0.00737
  • 500+0.04696500+0.00607
  • 1000+0.038981000+0.00504
  • 5000+0.026665000+0.00345
库存:19509
WR02X474 JAL
  • 15000+0.0214215000+0.00277
  • 30000+0.0189930000+0.00246
  • 45000+0.0178245000+0.00230
  • 75000+0.0165475000+0.00214
  • 105000+0.01581105000+0.00204
  • 150000+0.01513150000+0.00196
库存:19509
WR02X474 JAL
  • 15000+0.00991
