www.msksemi.com
LL4148-MS
Semiconductor
Compiance
Features
5K
Vo
2nF
60
IF:200mA
VR:75V
PKG:LL34 glass case
VRF =2V
power dissipation
Rectification Efficiency Measurement Circuit
LL-34
REEL SPECIFICATION
P/N
PKG
QTY
LL4148-MS
LL34
2500
Absolute Maximum Ratings (Ta = 25 OC)
Parameter
Symbol
Value
Unit
Peak Reverse Voltage
VRM
100
V
Reverse Voltage
VR
75
V
IF(AV)
200
mA
Average Rectified Forward Current
Non-repetitive Peak Forward Surge Current
at t = 1 s
at t = 1 ms
at t = 1 μs
Power Dissipation
Ptot
0.5
1
4
500 1)
Tj
175
O
C
Tstg
- 65 to + 175
O
C
IFSM
Junction Temperature
Storage Temperature Range
1)
A
mW
Valid provided that electrodes are kept at ambient temperature.
Characteristics at Ta = 25 OC
Parameter
Symbol
Min.
Max.
Unit
VF
1
V
IR
IR
IR
25
5
50
nA
µA
µA
V(BR)R
100
V
Capacitance
at VR = 0, f = 1 MHz
Ctot
4
pF
Voltage Rise when Switching ON
tested with 50 mA Forward Pulses
tp = 0.1 s, Rise Time < 30 ns, fp = 5 to 100 KHz
Vfr
2.5
V
Reverse Recovery Time
at IF = 10 mA to IR = 1 mA, VR = 6 V, RL = 100 Ω
trr
4
ns
RthA
0.35
ηV
0.45
Forward Voltage
at IF = 10 mA
Leakage Current
at VR = 20 V
at VR = 75 V
at VR = 20 V, Tj = 150 C
O
Reverse Breakdown Voltage
tested with 100 µA Pulses
Thermal Resistance Junction to Ambient Air
at f = 100 MHz, VRF = 2 V
1)
1)
K/mW
www.msksemi.com
LL4148-MS
Semiconductor
Dynamic forward resistance
versus forward current
Forward characteristics
10
Compiance
3
10 4
Tj=25oC
f=1KHz
5
2
10 2
o
Tj=100 C
iF
10 3
o
Tj=25 C
rf
10
5
2
10 2
5
1
2
10
10 -1
5
2
10 -2
1
2V
10 -1
10 -2
1
10
VF
IF
Admissible power dissipation
versus ambient temperature
Relative capacitance
versus reverse voltage
temperature
mW
LL 4148
1000
500
900
Power Dissipation: Ptot (mW)
Tj=25oC
f=1MHz
1.1
400
800
P tot
10 2 mA
Ctot(VR)
Ctot(0V)
700
1.0
300
600
500
0.9
200
400
300
100
0.8
200
100
100
150
Ambient Temperature: Ta (OC)
Power Derating
Curve
Tamb
200
o
200 C
0.7
4
6
8
10 V
VR
www.msksemi.com
LL4148-MS
Semiconductor
Compiance
Attention
■ Any and all MSKSEMI Semiconductor products described or contained herein do not have specifications
that can handle applications that require extremely high levels of reliability, such as life-support systems,
aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious
physical and/or material damage. Consult with your MSKSEMI Semiconductor representative
nearest
you
before using any MSKSEMI Semiconductor products described or contained herein in such applications.
■ MSKSEMI Semiconductor assumes no responsibility for equipment failures that result from using products
at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or
other parameters) listed in products specificationsof any andall MSKSEMI Semiconductor products described
orcontained herein.
■ Specifications of any and all MSKSEMI Semiconductor products described or contained herein stipulate the
performance, characteristics, and functions of the described products in the independent state, and are not
guarantees of the performance, characteristics, and functions of the described products as mounted in the
customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent
device, the customer should always evaluate and test devices mounted in the customer’sproducts orequipment.
■ MSKSEMI Semiconductor. strives to supply high-quality high-reliability products. However, any and all
semiconductor products fail with someprobability. It is possiblethat these probabilistic failures could give rise to
accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause
damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents
or events cannot occur. Such measures include but are not limited to protective circuits anderror prevention
circuitsfor safedesign, redundant design, and structural design.
■ In the event that any or all MSKSEMI Semiconductor products(including technical data, services) described
or contained herein are controlled under any of applicable local export control laws and regulations, such
products must not be exported without obtaining the export license from theauthorities
concerned
in
accordance with the above law.
■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or
mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise,
without the prior written permission of MSKSEMI Semiconductor.
■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not
guaranteed for volume production. MSKSEMI Semiconductor believes information herein is accurate and reliable,
but no guarantees are made or implied regarding its use or any infringementsof intellectual property rights or
other rightsof third parties.
■ Any and all information described or contained herein are subject to change without notice due to
product/technology improvement, etc. Whendesigning equipment, referto the "Delivery Specification" for the
MSKSEMI Semiconductor productthat you intend to use.
www.msksemi.com
很抱歉,暂时无法提供与“LL4148-MS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.04270
- 2500+0.03340
- 国内价格
- 50+0.08414
- 500+0.06751
- 2500+0.04935
- 5000+0.04381
- 25000+0.03899
- 50000+0.03632
