AACT322523R510
AACT322523R510
    COILANK(驰兴)
    SMD
    共模电感 510µH 200mA 700mΩ 2.6KΩ CHOKE_3.2X2.5MM_SM
AACT322523R510 数据手册
Common Mode Chokes AACT Series Features      Qualified to AEC-Q200. High common mode impedance at high frequency effects excellent noise suppression performance. Support a wide range of -40 ~ +125℃, can be used for high temperature resistant vehicle equipment. High precision automatic winding method ensures high stability and reliability. The products 100% Lead(Pb) and RoHS compliant. Applications  The AACT series can be used as a common mode filter for vehicle LAN system such as CANBUS and FlexRay. Test Conditions  All test data is referenced to 25℃ ambient.  Operating temperature range -40℃ to +125℃(Including self - temperature rise).  The part temperature(ambient + temp rise)should not exceed 125℃ under worst case operating conditions. Circuit design,component placement, PCB trace size and thickness,airflow and other cooling provisions all affect the part temperature,part temperature should be verified in the end application. External dimensions (Unit:mm) A D2 Equivalent circuit c C a b D2 No Polarity B D1 D1 Type A B C Max. D1 Typ. D2 Typ. a b c d Q’Ty/Reel AACT322523 3.2±0.2 2.5±0.2 2.3±0.2 0.8 0.9 1.9 3.7 0.75 2.55 1000 AACT453228 4.5±0.2 3.2±0.2 2.8±0.2 1.0 1.2 2.4 5.1 0.75 3.39 500 Part Number Code AACT 322523 A B R C 1) Series Name 2) Dimensions(mm) 3) Tolerance 4) Inductance 110 D Common Mode Chokes 322523: 3.2x2.5x2.5 R: Reference 110: 11μH Http://www.coilank.com E-mail:sales@coilank.com d Common Mode Chokes AACT322523 Series Part Number Common Mode Impedance @10MHz Common Mode Inductance @100KHz/0.5V (μH)+50%/-30% DC Resistance Rated Current Rated Voltage Insulation Resistance (Ω)Max. (mA)Max. (V)Max. (MΩ)Min. (Ω)Min. (Ω)Typ. AACT322523R110 300 500 11 0.4 300 80 10 AACT322523R220 500 1000 22 0.5 250 80 10 AACT322523R510 1000 2600 51 0.7 200 80 10 AACT322523R101 2000 5100 100 1.5 150 80 10 AACT322523R201 10000 15000 *200 4.8 70 80 10 AACT322523R800G - - 80 2.4 70 80 10 *(μH)+30%/-20% Characteristics(Reference) AACT322523R110 AACT322523R220 AACT322523R510 AACT322523R101 AACT322523R201 AACT322523R800G Http://www.coilank.com E-mail:sales@coilank.com Common Mode Chokes AACT453228 Series Part Number Common Mode Impedance @10MHz Common Mode Inductance @100KHz/0.5V DC Resistance Rated Current Rated Voltage Insulation Resistance (Ω)Min. (Ω)Typ. (μH)+50%/-30% (Ω)Max. (mA)Max. (V)Max. (MΩ)Min. AACT453228R110 300 700 11 0.6 250 50 10 AACT453228R220 500 1000 22 1.0 200 50 10 AACT453228R510 1000 2000 51 1.0 200 50 10 AACT453228R101 2000 5000 100 2.0 150 50 10 AACT453228R201 10000 15000 200 4.5 100 50 10 Characteristics(Reference) AACT453228R110 AACT453228R220 AACT453228R510 AACT453228R101 AACT453228R201 Http://www.coilank.com E-mail:sales@coilank.com Common Mode Chokes Reliability Test Item Specifications Test conditions Temperature: 125±2℃. Duration:1000hrs. Measured at room temperature after placing for 24±4 hrs. High temperature storage test No visible mechanical damage. Inductance change: Within ±10%. T em p 125°C H ig h tem p eratu re 25°C 0°C Temperature cycling test No visible mechanical damage. Inductance change: Within ±10%. 24H 1000H T est T im e Condition for 1 cycle. Step1:-40±2℃ 30min Min. Step2:125±2℃, transition time 1min Max. Step3:125±2℃ 30min Min. Step4:Low temp, transition time 1min Max. Number of cycles:1000. Measured at room temperature after placing for 24±4 hrs. T em p 125°C C h an g e tim e< 1m in 25°C 0°C T im e -40°C Biased humidity test No visible mechanical damage. Inductance change: Within ±10%. Humidity :85﹪±3 RH. Temperature:85℃±2℃. Duration : 1000hrs. Measured at room temperature after placing for24±4 hrs. Operational life test No visible mechanical damage. Inductance change: Within ±10%. Temperature:105±2℃. Duration :1000hrs. Measured at room temperature after placing for24±4 hrs. Resistance to solvent test No visible mechanical damage. Inductance change: Within ±10%. Add aqueous wash chemical - OKEM clean or equivalent. No visible mechanical damage. Inductance change: Within ±10%. Oscillation Frequency: 10~2K~10Hz for 20 minute. Total Amplitude:1.52mm±10%. Testing Time : 12 hours(20 minutes, 12 cycles each of 3 orientations). Vibration test Temperature (°C): 260 ±5 (solder temp). Time (s): 10 ±1. ramp/immersion and emersion rate: 25mm/s ±6 mm/s. Number of heat cycles:1. Resistance to soldering heat test No visible mechanical damage. Inductance change: Within ±10%. 260°C 150°C 60 sec. Http://www.coilank.com E-mail:sales@coilank.com 10±1 sec. Common Mode Chokes Item Specifications Test conditions Steam Aging: 8 hours ± 15 min. Preheat: 150℃,60sec. Solder: Sn99.5%-Cu0. 5%. Temperature: 245±5℃. Flux for lead free: Rosin. 9.5%. Dip time: 4±1sec. Depth: completely cover the termination. More than 95% of the terminal electrode should be covered with solder. Solderability test 245°C 150°C 4±1 sec. 60 sec. Terminal strength (SMD) test With the component mounted on a PCB with the device to be tested,apply a 17.7 N (1.8 Kg) force to the side of a device being tested. This force shall be applied for 60 +1 seconds. Also the force shall be applied radually as not to apply a shock to the component being tested. No visible mechanical damage. Packaging(Unit:mm) P P0 K0 W P1 B0 t A0 Type W P P0 P1 A0 B0 K0 t AACT322523 8.0±0.2 4.0±0.1 4.0±0.1 2.0±0.1 2.8±0.1 3.6±0.1 2.2±0.1 0.26±0.1 AACT453228 12.0±0.2 8.0±0.1 4.0±0.1 2.0±0.1 3.45±0.1 4.9±0.1 3.05±0.1 0.26±0.1 D C B A E Type A B C D E AACT322523 178.0±2.0 60.0±2.0 13.5±2.0 13.0±2.0 9.0±2.0 AACT453228 178.0±2.0 60.0±2.0 13.5±2.0 17.5±2.0 13.5±2.0 Http://www.coilank.com E-mail:sales@coilank.com Common Mode Chokes Recommended Soldering Technologies Re-flowing Profile: △ Preheat condition: 150~200℃/60~120sec. △ Allowed time above 217℃: 60~90sec. 217°C △ Max temp: 260℃ △ Max time at max temp: 5sec. △ Solder paste: Sn/3.0Ag/0.5Cu △ Allowed Reflow time: 2x max Peak 260 °C Max 260°C Max Ramp Up Rate=3 °C/sec Max Ramp Down Rate=8 °C/sec 60~90sec 200°C 150°C 60~120sec 25°C Time 25°C to Peak=8min Max Iron Soldering Profile: △ Iron soldering power: Max.30W △ Pre-heating: 150℃/60sec. △ Soldering Tip temperature: 350℃Max. 3sec Max 350°C Soldering Irom Power:max.30W △ Soldering time: 3sec Max. △ Solder paste: Sn/3.0Ag/0.5Cu △ Max.1 times for iron soldering Tc °C Diameter of Soldering Iron 1.0mm max [Note: Take care not to apply the tip of the soldering iron to the] Http://www.coilank.com E-mail:sales@coilank.com
AACT322523R510 价格&库存
很抱歉,暂时无法提供与“AACT322523R510”相匹配的价格&库存,您可以联系我们找货
AACT322523R510
    • 1000+1.83600
    库存:1001000
