SS-10-16SP-AE
SS-10-16SP-AE
    NIDEC(尼得科)
    SW6_10X10MM_TM
    1极6触点,顶部设置,50V 100mA DIP
SS-10-16SP-AE 数据手册
ROTARY SELECTORSS-10 SWITCHES 構造図 RoHS compliant SS-10/S-2050 INTERNAL STRUCTURE 1 SS-10 series 7 2 6 3 5 Part name 4 Material Flammability ■ FEATURES ① Rotor ● RoHS compliant ● Compact-size DIP pin configuration ● Protected against dust and washable after soldering ● Self-cleaning mechanism ② “O” ring ③ Base ④ Terminal pin ⑤ Contact Copper alloy, Gold-plated ⑥ P.C.B. Gold-plated epoxy board ⑦ Housing Polybutyleneterephthalate Polyoxymethylene Silicone rubber UL94HB Polybutyleneterephthalate Copper alloy, Gold-plated — UL94HB ■ PART NUMBER DESIGNATION SS-10 - 1 6 S P - L - A E W Series name Form of packaging W:Tray packaging Blank:Plastic bag No. of poles 1:1 pole 2:2 poles Terminal pin No. of contacts E:Au (Lead-free) 3:3 contacts (2 poles only) 5:5 contacts (1 pole only) 6:6 contacts (1 pole only) Schematic    ※ 1 Contact timing A:Without OFF position Blank:With OFF position N:Non-shorting (1pole 6 contacts with OFF, 2 poles 3 contacts) S:Shorting (1 pole 5 contacts, 1 pole 6 contacts without OFF) Shape of rotor L:With knob (extended shaft) Blank:Without knob Setting position P:Top setting ※ 1:The designation for schematic is only aplicable to SS-10-16 □□ . The other partnumbers (ex. S-2050, SS-10-15SPEW) are without OFF position. ※ Please refer to the LIST OF PART NUMBERS when placing orders. SS-10/S-2050 ROTARY SELECTOR SWITCHES ■ LIST OF PART NUMBERS Circuit type Shape With knob 1 pole 4 contacts Without knob Side setting With knob Without knob 1 pole 5 contacts With knob Without knob With OFF With knob Top setting 1 pole 6 contacts Non-shorting Tray packaging Plastic bag Tray packaging Plastic bag Tray packaging Plastic bag Tray packaging Plastic bag Tray packaging Plastic bag Tray packaging Plastic bag Tray packaging Plastic bag Tray packaging Plastic bag Tray packaging Plastic bag Tray packaging Plastic bag Tray packaging Plastic bag Tray packaging Plastic bag Without knob Top setting Contact timing Form of packaging Without knob Without OFF With knob Without knob 2 poles 3 contacts With knob Pieces in package Shorting S-2050W S-2050 S-2150W S-2150 S-2051W S-2051 S-2151W S-2151 SS-10-15SP-EW SS-10-15S-PE SS-10-15SP-L-EW SS-10-15SP-L-E SS-10-16NP-EW SS-10-16NP-E SS-10-16NP-L-EW SS-10-16NP-L-E SS-10-16SP-AEW SS-10-16SP-AE SS-10-16SP-L-AEW SS-10-16SP-L-AE SS-10-23NP-EW SS-10-23NP-E SS-10-23NP-L-EW SS-10-23NP-L-E 50 pcs./tray 25 pcs./pack 50 pcs./tray 25 pcs./pack 50 pcs./tray 25 pcs./pack 50 pcs./tray 25 pcs./pack 50 pcs./tray 25 pcs./pack 50 pcs./tray 25 pcs./pack 50 pcs./tray 25 pcs./pack 50 pcs./tray 25 pcs./pack 50 pcs./tray 25 pcs./pack 50 pcs./tray 25 pcs./pack 50 pcs./tray 25 pcs./pack 50 pcs./tray 25 pcs./pack : Not manufactured ※ Verify the above part numbers when placing orders. Tray version can be supplied only in tray nuits. ■ SCHEMATIC DIAGRAMS 1 ON 1 1 1 1 1 1 6 C C SS-10-16SP-AE SS-10-16SP-L-AE C C 1 C ON 1 C 1 ON ON C C C 2 3 1 1 2 2 3 3 1 3 Schematic 2 3 4 1 2 C ON 5 C C C C 31 1 42 2 53 3 64 4 5 5 6 6 C Switching specifications 2 3 4 2 3 1 6 ON ON 1 1 2 3 4 C 1 C 1 ON ON C ● 1 pole 6 contacts (Without OFF) Series 1 5 6 6 5 5 ON C 1 (OFF) 2 (OFF) C C 1 C 1 6 6 C C 1 5 2 C C 1 1 5 C C 4 C 3 SS-10-23NP-L-E 1 C SS-10-16NP-E 5 1 C 5 Schematic(OFF) C 4 ON ON 2 3 4 Switching specifications 2 3 4 2 3 4 1 C 1 1 1 C C 1 1 1 1 C 1 ON ON ● 1 pole 6 contacts (With OFF) SS-10-16NP-L-E 1 4 ON Series C 3  2  3 1 4 2 SS-10-23NP-E 5 3 3 1 4 C 2 3 C C C 1 Schematic  2   2  3 3 C 1 C 5 C 5 S-2151 2 1 SS-10-15SP-E 3 2 4 SS-10-15SP-L-E 3 2 2 3 4 2 3 4 1 S-2051 C Switching specifications Series 1 2 3 4 2 1 S-2150 Schematic 4 3 4 S-2050 2 3 4 Switching specifications Series 3 2 2 Schematic 5 Switching specifications Series ● 2 poles 3 contacts ● 1 pole 5 contacts 1 ● 1 pole 4 contacts 2 1 3 12 4 23 5 34 6 45 56 6 SS-10/S-2050 ROTARY SELECTOR SWITCHES SS-10端子接続 SS-10端子接続 ■ TERMINAL CONNECTION / P.C.B. THROUGH HOLE DIMENSIONS S-2050 S-2150 2 2 C C C C 5 5 1 1 4 4 Dimension is common to SS-10-15, SS-10-16 and SS-10-23 series. 2 2 C C C C 2 2 1 1 3 3 8 – φ 0.8 hole 8 – φ 0.8 hole 2.54±0.1 2.54±0.1 SS – 10 case SS – 10 case ■ STANDARD SPECIFICATIONS Circuit type Contact rating Non-switching Switching Minimum − 25 ~ 70 °C Contact timing Storage temperature range Sealing Net weight Contact resistance Washable by “O” ring ※ Please refer to page 150, 151 Approx. 0.84 g (without knob) Approx. 0.94 g (with knob) ■ MECHANICAL CHARACTERISTICS No. of positions 3, 4, 5, 6 Adjustment torque 40 mN·m {408 gf·cm} maximum Stopper strength 50 mN·m {510 gf·cm} minimum 36° Stepping angle Terminal strength Solderability Soldering heat 4 contacts (12 pole poles 3 contacts ) 30° (1 pole 5 contacts) 22.5° (1 pole 6 contacts, with OFF) 28° (1 pole 6 contacts, without OFF) C C 5 – φ 0.8 hole 5 – φ 0.8 hole 2.54±0.1 2.54±0.1 S – 2050 case SS––2150 2050 case case S – 2150 case  Operating face 2.54±0.1  Operating face 5 – φ 0.8 hole 2.54±0.1 5 – φ 0.8 hole S – 2051 case SS––2151 2051 case case S – 2151 case ■ ELECTRICAL CHARACTERISTICS 1 pole 4 contacts 1 pole 5 contacts 1 pole 6 contacts 2 poles 3 contacts Operating temperature range 4 3 2 1 4 3 2 1 4 3 2 1 4 3 2 1 C C 7.62±0.1 7.62±0.1 P.C.B. dimensions (Bottom view) 3 3 1 1 Operating face Operating face 2.54±0.1 2.54±0.1 3 3 6 6 7.62±0.1 7.62±0.1 1 1 4 4 2.54±0.1 2.54±0.1 C C 5 5 2.54±0.1 2.54±0.1 3 2 3 2 NC C NC C Terminal pin layout (Bottom view) S-2051 S-2151 5.08±0.1 5.08±0.1 SS-10-15 SS-10-16 SS-10-23 Insulation resistance Dielectric strength DC50 V 100 mA DC5 V 100 mA DC20 mV 1 μ A Shorting Non-shorting 100 m Ω maximum 100 M Ω (DC100 V) minimum AC300 V, 60 s ■ ENVIRONMENTAL CHARACTERISTICS Vibration Shock Humidity (Steady state) Load life (Amplitude) 1.5 mmor (Acceleration) 98 m/s2, 10-500-10 Hz, 3 directions for 2 h each 490 m/s2, 11 ms 6 directions for 3 times each 40 °C, Relative humidity 90 ~ 95 %, 240 h 500 cycles minimum DC5 V, 100 mA 15 N {1.53 kgf} minimum High temperature exposure 70 °C, 240 h 245 ± 3 °C, 2 ~ 3 s Low temperature exposure − 25 °C, 96 h Flow soldering 260 ± 3 °C, 5 ~ 6 s, two times maximum Manual soldering 380 ± 10 °C, 3 ~ 4 s { } : Reference only (Unit: mm) Thermal shock − 25 (0.5 h) ~ 70 °C (0.5 h), 5 cycles SS-10/S-2050 ROTARY SELECTOR SWITCHES ■ OUTLINE DIMENSIONS Unless otherwise specified, tolerance: ± 0.3 (Unit: mm) ● SS-10-15SP-E ● SS-10-15SP-L-E Part No., Production date code & Lead-free Identification mark Part No., Production date code & Lead-free Identification mark 5 2 C 3 NC 6.6 3 NC C 3 6 2.54 7.62 1 2.54 2 1 ˚ 28 Straight knurl M = 0.2 0.7 W × 1 D 8 – 0.5 ± 0.1 t = 0.2 2.54 2.54 2.54 5 8 – 0.5 ± 0.1 t = 0.2 2.54 6 4 C 5 2 C 3 6 ● SS-10-16NP-L-E Part No., Production date code & Lead-free Identification mark Part No., Production date code & Lead-free Identification mark 6.6 C 3 6 2.54 2.54 2 ˚ .5 22 Straight knurl M = 0.2 0.7 W × 1 D 4 C 5 2 C 3 6 ● SS-10-23NP-L-E Part No., Production date code & Lead-free Identification mark Part No., Production date code & Lead-free Identification mark 4.5 ± 0.5 6.6 1 2.54 2.54 3 0.7 W × 1 D Straight knurl M = 0.2 2.54 C 7.62 1 8 – 0.5 ± 0.1 t = 0.2 2 3.9 2 ˚ 3 36 2.54 8 – 0.5 ± 0.1 t = 0.2 2.54 4.5 ± 0.5 123 1 C SS –1 0 123 SS –1 0 36˚ 7 10 7.62 2.54 7 10 6 ● SS-10-23NP-E 7.62 1 2.54 5 3.9 2.54 2.54 C 8 – 0.5 ± 0.1 t = 0.2 2.54 4 345 0.7 W × 3.2 L × 1 D 4.5 ± 0.5 12 345 1 SS–1 0 12 SS–1 0 ˚ .5 22 7 10 7.62 8 – 0.5 ± 0.1 t = 0.2 4.5 ± 0.5 10 7 10 6 10 4 ● SS-10-16NP-E 10 C 4.5 ± 0.5 23 4 5 1 C SS–1 0 23 4 5 SS–1 0 ˚ 28 7 10 7.62 3.9 4.5 ± 0.5 10 7 1 10 5 2 Part No., Production date code & Lead-free Identification mark 6 0.7 W × 3.2 L × 1 D 10 10 Straight knurl M = 0.2 4 C ● SS-10-16SP-L-AE Part No., Production date code & Lead-free Identification mark 0.7 W × 3.2 L × 1 D 2.54 ˚ 30 0.7 W × 1 D ● SS-10-16SP-AE 1 2.54 4 7.62 8 – 0.5 ± 0.1 t = 0.2 2.54 0.7 W × 3.2 L × 1 D 4.5 ± 0.5 3.9 2.54 2.54 1 C 8 – 0.5 ± 0.1 t = 0.2 2.54 ˚ 30 7 10 7.62 SS –1 0 SS –1 0 10 6.6 4. 5 ± 0.5 10 7 10 3 C 2 2 C 3 1 SS-10/S-2050 ROTARY SELECTOR SWITCHES 外形図 S-2150 外形図 ■ OUTLINE DIMENSIONS ● S-2050 Unless otherwise specified, tolerance: ± 0.3 (Unit: mm) ● S-2150 0.7 W × 3.2 L × 1 D Part No. & Production date code 0.7 W × 1 D Part No. & Production date code 4.5 ± 0.5 6.6 10 7 4.5 ± 0.5 10 7.62 2.54 2.54 7.62 4 ● S-2051 Part No. & Production date code 0.7 W × 1 D 0.7 W × 3.2 L × 1 D ˚ 3 2 1 C 5 – 0.5 ± 0.1 t = 0.2 2.54 2.54 6 4 3 2.54 2 1 C 5 – 0.5 ± 0.1 t = 0.2 5.08 2.54 18.1 6.6 φ 3.9 1 23 10 4 3.5 ± 0.5 10 3.5 ± 0.5 ˚ 4 1 36 10 4 23 11.5 36 10 2.54 2.54 Straight knurl M = 0.2 ● S-2151 Part No. & Production date code 2.54 3 C 2 1 36 ˚ 2.54 5–0.5 ± 0.1 t = 0.2 36 ˚ 1 5–0.5 ± 0.1 t = 0.2 2 10 2.54 C 4 4 形図 3 23 23 10 1 4 φ 3.9 1 12.6 5.08 Straight knurl M = 0.2 2.54 7 S-1000長軸用ツマミ付き SS-10/S-2050 ROTARY SELECTOR SWITCHES ■ SWITCHES WITH KNOB AS EXTENDED SHAFT (Unit: mm) 10 φ 5.5 1 φ 9.5 0.7 The large knob is common to S-1000A, S-2000A, SA-5000, and SS-10 series. ※ Knob can’t be dettached due to being fixed. Simple knob can’t be sold. ■ PACKAGING SPECIFICATIONS ■ PACKAGING SPECIFICATIONS ● Tray version is packaged in 50 pcs. per tray. Orders will be accepted for units of 50 pcs., i. e., 50, 100, 150 pcs. etc. ● Tray version is boxed with 10 trays. ● The smallest unit of bulk pack in a plastic bag is 10 pcs. per pack. Orders will be accepted for unit of minimum 10 pcs., i.e., 10, 20, 30 pcs., etc. ● Boxing of bulk in a plastic bag is performed with 25 pcs. (standard 50 pcs.) per box. : The switch with a large knob for manual adjustment is available as a semi-standard item. Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nidec: SS-10-23NPE SS-10-16NP-LE SS-10-16NPE SS-10-15SPE SS-10-23NP-LE SS-10-15SP-LE S-2050 S-2151 S2051 S-2150 S-2050W S-2051W S-2150W S-2151W SS-10-15SPEW SS-10-15SP-LEW SS-10-23NPEW SS-1023NP-LEW SS-10-16NPEW SS-10-16NP-LEW SS-10-16SP-AE SS-10-16SP-AEW SS-10-16SP-L-AE SS-10-16SPL-AEW
SS-10-16SP-AE 价格&库存
很抱歉,暂时无法提供与“SS-10-16SP-AE”相匹配的价格&库存,您可以联系我们找货
SS-10-16SP-AE
  • 1+14.35100
  • 10+13.22100
  • 30+12.99500
  • 100+12.31700
