ANT-GNSSCP-TH18L1
ANT-GNSSCP-TH18L1
    LINXTECHNOLOGIES(灵思)
    ANT_18X18MM_SM
    ANT-GNSSCP-TH18L1
ANT-GNSSCP-TH18L1 数据手册
Datasheet ANT-GNSSCP-TH18L1 Ceramic Patch GNSS Antenna The GNSSCP-TH18L1 is an 18 mm x 18 mm square ceramic patch antenna for GPS/GLONASS/ GALILEO/BeiDou global navigation satellite system (GNSS) operation. It provides excellent gain and radiation pattern performance supporting solutions with high location accuracy, rapid satellite signal reception and lock, and quick time to first fix. The GNSSCP-TH18L1 offers an extended temperature range to +105 °C for compliance to automotive standard AEC-Q200 Grade 2. The antenna is mounted via attached adhesive patch and has a solder pin signal connection. Features Applications • Performance at 1567.24 MHz to 1583.60 MHz ― VSWR: ≤ 2.8 ― Peak Gain: 5.1 dBi ― Efficiency: 66% • Directional radiation pattern orthogonal to antenna surface • Right-hand circularly polarized (RHCP) • Extended operation to +105 °C • AEC-Q200 Grade 2 compliance • Adhesive mounting to PCB • Solder pin signal connection • Global navigation GNSS ― GPS L1 ― Galileo E1 ― GLONASS I L1 ― GLONASS II L1 ― Beidou B1-BOC ― Beidou B1-2 ― QZSS L1 • Timing solutions • Automotive location Ordering Information Part Number ANT-GNSSCP-TH18L1 Description GNSS ceramic patch antenna with pin-type solder connection Available from Linx Technologies and select distributors and representatives. ANT-GNSSCP-TH18L1 Datasheet Electrical Specifications GNSSCP-TH18L1 GPS L1, GALILEO E1, GLONASS II L1, Beidou B1BOC, QZSS L1 Beidou B1-2 GLONASS II L1 Center Frequency 1575.42 MHz 1589.74 MHz 1602 MHz Frequency Range 1567.24 MHz to 1583.60 MHz 1587.69 MHz to 1591.79 MHz 1593.31 MHz to 1608.68 MHz VSWR (max) 2.8 3.2 2.9 Peak Gain (dBi) 5.1 2.8 4.0 10 Deg. Elevation (dBi) 2.5 1.7 1.3 Axial Ratio (dB) 12.2 9.6 12.3 Average Gain (dBi) -2.2 -3.8 -2.3 Efficiency (%) 66 44 65 Polarization RHCP Radiation Omnidirectional Max Power 8W Wavelength 1/4-wave Electrical Type Ceramic Patch Impedance 50 Ω Connection Pin Type (Through hole) Operating Temp. Range -40 °C to +105 °C Weight 6.0 g (0.21 oz) Dimensions 18.0 mm x 18.0 mm x 4.0 (0.71 in x 0.71 in x 0.16 in) ESD Sensitivity NOT ESD sensitive. As a best practice, Linx may use ESD packaging. Electrical specifications and plots measured with a 70 mm x 70 mm (2.76 in x 2.76 in) reference ground plane. Product Dimensions Figure 1 provides dimensions of the GNSSCP-TH18L1. 18.0 mm (0.71 in) 4.0 mm (0.16 in) TECHNOLOGIES ANT-GNSSCP-TH18L1 v Adhesive pad, NITTO 5015 adhesive OD 16 mm (0.63 in) ID 7.5 mm (0.30 in) Thickness 0.12 mm (0.005 in) 18.0 mm (0.71 in) 1.7 mm (0.67 in) 1.8 mm (0.07 in) Ø3.0 mm (0.12 in) Figure 1.  GNSSCP-TH18L1 Antenna Dimensions 2 Pin Ø0.9 mm (0.04 in) Datasheet ANT-GNSSCP-TH18L1 VSWR 1609 1601 1602 1592 1593 1590 1587 1584 1575 5 1567 Figure 2 provides the voltage standing wave ratio (VSWR) across the antenna bandwidth. VSWR describes the power reflected from the antenna back to the radio. A lower VSWR value indicates better antenna performance at a given frequency. Reflected power is also shown on the right-side vertical axis as a gauge of the percentage of transmitter power reflected back from the antenna. VSWR 4 30 3 20 2 10 1 1560 1570 1580 1590 Frequency (MHz) Reflected Power (%) 40 0 1610 1600 Figure 2.  GNSSCP-TH18L1 VSWR Return Loss 1609 1601 1602 1592 1593 1590 1587 1584 1575 0 1567 Return loss (Figure 3), represents the loss in power at the antenna due to reflected signals. Like VSWR, a lower return loss value indicates better antenna performance at a given frequency. -2 Return Loss (dB) -4 -6 -8 -10 -12 -14 -16 -18 -20 1560 1570 1580 1590 Frequency (MHz) 1600 1610 Figure 3.  GNSSCP-TH18L1 Return Loss 3 ANT-GNSSCP-TH18L1 Datasheet Peak Gain 1609 1601 1602 1592 1593 1590 1587 1584 1575 10 1567 The peak gain across the antenna bandwidth is shown in Figure 4. Peak gain represents the maximum antenna input power concentration across 3-dimensional space, and therefore peak performance at a given frequency, but does not consider any directionality in the gain pattern. Peak Gain (dBi) 5 0 -5 -10 1560 1570 1580 1590 Frequency (MHz) 1600 1610 Figure 4.  GNSSCP-TH18L1 Peak Gain Average Gain Average Gain (dBi) 1609 5 0 -5 -10 1560 1570 1580 1590 Frequency (MHz) Figure 5.  GNSSCP-TH18L1 Antenna Average Gain 4 1601 1602 1592 1593 1590 1587 1584 1575 10 1567 Average gain (Figure 5), is the average of all antenna gain in 3-dimensional space at each frequency, providing an indication of overall performance without expressing antenna directionality. 1600 1610 Datasheet ANT-GNSSCP-TH18L1 Axial Ratio 1609 1601 1602 1592 1593 1590 1587 1584 1575 20 1567 Axial ratio provides a measure of the quality of circular polarization of an antenna, the lower the value (in dB), the better the circular polarization. A circularly polarized antenna field comprises two orthogonal E-field components.These fields are ideally of equal amplitude, resulting in an axial ratio equal to unity (0 dB). In practice, no antenna is perfectly circular in polarization, the polarization is elliptical as one field has larger magnitude. As the axial ratio increases the antenna gain degrades away from the main beam orthogonal to the antenna surface. The axial ratio for the TH18L1 antenna is shown in Figure 6. Axial Ratio (dB) 15 10 5 0 1560 1570 1580 1590 Frequency (MHz) 1600 1610 Figure 6.  Axial Ratio of the GNSSCP-TH18L1 Radiation Efficiency 1609 1601 1602 1592 1593 1590 1587 1584 1575 100 1567 Radiation efficiency (Figure 7), shows the ratio of power delivered to the antenna relative to the power radiated at the antenna, expressed as a percentage, where a higher percentage indicates better performance at a given frequency. 90 80 Efficiency (%) 70 60 50 40 30 20 10 0 1560 1570 1580 1590 1600 Frequency (MHz) Figure 7.  GNSSCP-TH18L1 Antenna Radiation Efficiency 1610 5 ANT-GNSSCP-TH18L1 Datasheet Radiation Patterns Radiation patterns provide information about the directionality and 3-dimensional gain performance of the antenna by plotting gain at specific frequencies in three orthogonal planes. Antenna radiation patterns are shown in Figure 8 using polar plots covering 360 degrees. The antenna graphic at the top of the page provides reference to the plane of the column of plots below it. Note: when viewed with typical PDF viewing software, zooming into radiation patterns is possible to reveal fine detail. XZ-Plane Gain YZ-Plane Gain XY-Plane Gain 1567.24 MHz to 1583.60 MHz (1576 MHz) 34 35 33 32 31 30 29 28 36 5 0 -5 -10 -15 -20 -25 -30 -35 -40 -45 -50 1 2 3 4 34 5 33 6 32 7 31 8 27 26 30 9 29 10 28 11 27 12 25 21 20 19 18 17 2 3 4 34 5 6 32 7 31 8 30 9 29 10 28 11 27 12 24 XZ-Plane Gain 21 20 19 18 17 1 2 3 4 5 6 7 8 9 10 26 12 25 13 24 15 22 16 36 5 0 -5 -10 -15 -20 -25 -30 -35 -40 -45 -50 11 14 23 35 33 13 15 22 1 25 14 23 36 5 0 -5 -10 -15 -20 -25 -30 -35 -40 -45 -50 26 13 24 35 14 23 16 15 22 21 YZ-Plane Gain 20 19 18 17 16 1567 MHz 1576 MHz 1584 MHz XY-Plane Gain 1587.69 MHz to 1591.79 MHz (1590 MHz) 34 35 33 32 31 30 29 28 36 5 0 -5 -10 -15 -20 -25 -30 -35 -40 -45 -50 1 2 3 4 34 5 33 6 32 7 31 8 27 26 13 14 23 15 22 21 20 19 18 XZ-Plane Gain 6 30 9 29 10 28 11 27 12 25 24 17 16 35 36 5 0 -5 -10 -15 -20 -25 -30 -35 -40 -45 -50 1 2 3 4 34 5 33 6 32 7 31 8 26 30 9 29 10 28 11 27 12 25 13 24 14 23 15 22 21 20 19 18 17 YZ-Plane Gain 16 35 36 5 0 -5 -10 -15 -20 -25 -30 -35 -40 -45 -50 1 2 3 4 5 6 7 8 9 10 11 26 12 25 13 24 14 23 15 22 21 20 19 18 17 XY-Plane Gain 16 1587 MHz 1590 MHz 1592 MHz Datasheet ANT-GNSSCP-TH18L1 Radiation Patterns 1593.31 MHz to 1608.68 MHz (1601 MHz) 34 35 33 32 31 30 29 28 36 5 0 -5 -10 -15 -20 -25 -30 -35 -40 -45 -50 1 2 3 4 34 5 33 6 32 7 31 8 27 26 30 9 29 10 28 11 27 12 25 13 24 14 23 15 22 21 20 19 18 17 16 XZ-Plane Gain 35 36 5 0 -5 -10 -15 -20 -25 -30 -35 -40 -45 -50 1 2 3 4 34 5 33 6 32 7 31 8 26 30 9 29 10 28 11 27 12 25 13 24 14 23 21 20 19 18 17 36 5 0 -5 -10 -15 -20 -25 -30 -35 -40 -45 -50 1 2 3 4 5 6 7 8 9 10 11 26 12 25 13 24 15 22 35 16 YZ-Plane Gain 14 23 15 22 21 20 19 18 17 16 1593 MHz 1601 MHz 1609 MHz XY-Plane Gain Figure 8.  GNSSCP-TH18L1 Radiation Patterns Ground Plane Ceramic patch antennas are directional in signal transmission and reception orthogonal to the surface plane of the antenna, and require a ground plane for proper operation. The larger the ground plane, the narrower the antenna signal beam, and generally, the better the VSWR performance of the antenna. Relatively smaller ground planes produce wider signal beams. Linx recommends the ground plane size shown in the Electrical Specifications table to achieve performance similar to that shown in this datasheet. Other ground plane sizes and antenna mounting locations are possible. The antenna should be mounted at the center of the ground plane for best performance. Linx offers PCB design reviews to help optimize solution performance. Antenna Installation The GNSSCP-TH18L1 attaches to the PCB surface using a double-sided adhesive (0.12 mm thick) which consists of a flexible pressure sensitive adhesive that adheres to metal, plastic and other non-porous surfaces. The mounting surface should be clean and free of moisture and oily residues for ideal adhesive strength. The 4 optional PCB solder pads and their dimensions are provided for use where the adhesive used to attach the antenna is not adequate to maintain the bond between the antenna and the PCB such as in installations that are exposed to excessive vibration. To facilitate soldering the adhesive must be removed. 7 ANT-GNSSCP-TH18L1 ANT-GNSSCP-TH18L1 Datasheet Recommended Layout The recommended printed circuit board (PCB) layout for the GNSSCP-TH18L1 is demonstrated by the AEKGNSSCP-TH18L1 evaluation board shown in Figure 9. Contact Linx for availability of PCB layout design files. The recommended layout includes a matching network, ground plane and PCB transmission line from the antenna to the matching network, and to the connector or radio circuitry. The connector used for the AEK-GNSSCP-TH18L1 www.linxtechnologies.com evaluation board is optional, the transmission line may be run directly to the radio if on the same PCB. Copyright © 2020 Linx Technologies Linx recommends inclusion of at least a 3-element, surface mount pi matching network of two parallel capacitors, (C1, C2) and one serial inductor, (L1) in all designs (Figure 10). Surface mount components should be 0603 size. 0402 size components are also supported. The GNSSCP series antennas, as designed, do not require matching, but matching may improve end-product antenna performance depending on the effects of the enclosure, PCB and other electronic components. If no matching is necessary, the serial element may be populated with a zero-ohm resistor and no components in the two capacitor positions. This is the configuration of the Linx evaluation board as supplied. Linx believes in wireless made simple® and offers matching network design support. PCB Top Side PCB Bottom Side 70x70mm ANT-GNSSCP-TH18L1 TECHNOLOGIES ANT-GNSSCP-TH18L1 Pi matching circuit C2 ANTENNA C1 SMA jack 2-Element (female socket) L1 L1 C2 Ground plane L1 layer on bottom for counterpoise C1 C1 AEK-GNSSCP-TH18L1 www.linxtechnologies.com Copyright © 2020 Linx Technologies GND GND Figure 9.  ANT-GNSSCP-TH18L1 Recommended Layout 3-Element L1 C1 4-Element C1 C2 C2 L1 L2 Figure 10.  Matching Network Recommendation C2 L1 C1 8 Datasheet ANT-GNSSCP-TH18L1 Recommended PCB Footprint Figure 11 shows the recommended printed circuit board footprint for the GNSSCP-TH18L1 antenna. The footprint recommendation should be used in conjunction with the recommended layout configuration shown in Figure 9. PCB Bottom Side Detail View Scale 2 : 1 PCB Top Side C2 11.5 mm (0.45 in) L1 1.8 mm (0.07 in) C2 Through hole for antenna feed Ø0.95 mm (0.04 in) C1 L1 C1 11.5 mm (0.45 in) 4x PCB Solder Pads 6.5 mm x 6.5 mm (0.26 in x 0.26 in) Figure 11.  ANT-GNSSCP-TH18L1 Antenna Placement on PCB Transmission Lines for Embedded Antennas For most designs, Linx recommends a microstrip transmission line for the GNSSCP-TH18L1 antenna. A microstrip transmission line is a PCB trace that runs over a ground plane to maintain the characteristic impedance for optimal signal transfer between the antenna and radio circuitry. Linx designs all antennas with a characteristic impedance of 50 Ω. Important practices to observe when designing a transmission line are: • Keep all transmission lines to a minimum length for best signal performance. • Use RF components that also operate at a 50 Ω impedance. • If the radio is not on the same PCB as the antenna, the microstrip should be terminated in a connector, enabling a shielded cable to complete the antenna connection to the radio. • For designs subject to significant electromagnetic interference, a coplanar waveguide transmission line may be used on the PCB. The design of a PCB transmission line can be aided by many commercially available software packages which can calculate the correct transmission line width and gap dimensions based upon the PCB thickness and dielectric constant used. Linx offers PCB design reviews to help optimize solution performance. 9 ANT-GNSSCP-TH18L1 Datasheet Packaging Specifications The GNSSCP-TH18L1 antennas are packaged in protective plastic trays as shown in Figure 12. Antennas are packaged 25 per tray, 200 antennas (8 trays) are packed in a carton 10.4 in x 6.1 in x 3.8 in (263 mm x 154 mm x 96 mm). 800 antennas packaged in a shipping box 12.9 in x 11.0 in x 8.6 in (327 mm x 280 mm x 218 mm). Top View Front View Figure 12.  Packaging Specifications for the ANT-GNSSCP-TH18L1 10 Datasheet VSWR = 10 Return Loss 20 +1 ANT-GNSSCP-TH18L1 Return Loss Antenna Definitions and Useful Formulas −1 10 20 VSWR - Voltage Standing Wave Ratio. VSWR is a unitless ratio that describes the power reflected from the antenna back to the radio. A lower VSWR value indicates better antenna performance at a given frequency. VSWR is easily derived from Return Loss. VSWR − 1 Return Loss = −20 log10Loss Return + 1+ 1 10 Return 20 VSWR Loss VSWR = 10 Return20 Loss + 1 VSWR = 10 −1 20 Return Loss − 1 due to reflected signals, measured in 10 Return Loss - Return loss represents the loss power at 20 the(G) antenna 10 log G in = db 10 decibels. A lower return loss value indicates better antenna performance at a given frequency. Return Loss is easily derived from VSWR. GdBd = GdBi − 2.51dB VSWR − 1 Return Loss = −20 log10 VSWR − 1 VSWR + 1 Return Loss = −20 log10 VSWR + 1 Return Loss 2 Efficiency (η) - The total power radiated from anVSWR antenna by the input power at the feed point of the +1 10 − divided 20 1 VSWR = antenna as a percentage. (G) = 10Return log Gdb VSWR 10Loss + 120 1 (G) −solution 10 Gdb =10 Total Radiated Efficiency - (TRE) The total efficiency of log an 10 antenna comprising the radiation = G − 2.51dB G dBiefficiency from the transmitter. efficiency of the antenna and the transmitteddBd (forward) GdBd = GdBi − 2.51dB 2 VSWRVSWR −1 −1 Loss TRELoss = η •= 1 −Return Return −20 log 10 11 10 VSWR 20 2 + + VSWR =VSWR − 1 VSWR + 1 Return Loss Gain - The ratio of an antenna’s efficiency in a given direction power produced by a theoretical VSWR − 20 1 2(G) to−the 1 10 + VSWR 1 lossless (100% efficient) isotropic antenna. The gain of an antenna is almost always expressed in decibels. VSWR + 1 log10 (G) Gdb = 10/4 VSWR VSWR − 1 2− 1 = −20 GdBi log − 2.51dB GdBd = Return Loss TRE = η • 1 − VSWR 10 − 1 2frequency +1 VSWR + 1 Peak Gain - The highest antenna gain TRE across for aVSWR given range. A directional antenna = all η •directions 1− VSWR + 1 will have a very high peak gain compared to average gain. 2 Average Gain - The average gain across all directions frequency range. VSWRfor−a1given log10 (G) Gdb = 10/4 Maximum Power - The maximum signal power which VSWRmay + 1be applied to an antenna feed point, typically measured in watts (W). GdBd = GdBi/4− 2.51dB Reflected Power - A portion of the forward power reflected back toward the amplifier due to a mismatch at the antenna port. VSWR − 1 2 TRE = η • 1 − VSWR −VSWR 1 2 +1 VSWR + 1 decibel (dB) - A logarithmic unit of measure of the power of an electrical signal. /4 decibel isotropic (dBi) - A comparative measure in decibels between an antenna under test and an isotropic VSWR − 1 2 radiator. TRE = η • 1 − VSWR + 1 between an antenna under test and decibel relative to a dipole (dBd) - A comparative measure in decibels an ideal half-wave dipole. Dipole - An ideal dipole comprises a straight electrical conductor measuring 1/2 wavelength from end to end connected at the center to a feed point for the radio. /4 Isotropic Radiator - A theoretical antenna which radiates energy equally in all directions as a perfect sphere. Omnidirectional - Term describing an antenna radiation pattern that is uniform in all directions. An isotropic antenna is the theoretical perfect omnidirectional antenna. An ideal dipole antenna has a donutshaped radiation pattern and other practical antenna implementations will have less perfect but generally omnidirectional radiation patterns which are typically plotted on three axes. 11 ANT-GNSSCP-TH18L1 Datasheet Website: http://linxtechnologies.com Linx Offices: 159 Ort Lane, Merlin, OR, US 97532 Phone: +1 (541) 471-6256 E-MAIL: info@linxtechnologies.com Linx Technologies reserves the right to make changes to the product(s) or information contained herein without notice. No liability is assumed as a result of their use or application. No rights under any patent accompany the sale of any such product(s) or information. Wireless Made Simple is a registered trademark of Linx Acquisitions LLC. Other product and brand names may be trademarks or registered trademarks of their respective owners. Copyright © 2020 Linx Technologies All Rights Reserved Doc # DS20213-76ANT Replaces (DS20175-76ANT)
ANT-GNSSCP-TH18L1 价格&库存
很抱歉,暂时无法提供与“ANT-GNSSCP-TH18L1”相匹配的价格&库存,您可以联系我们找货
