ULN2803 series High-voltage
High-current Darlington Transistor Arrays
Features
Relay-Driver Applications
High-Voltage Outputs:50V
output)
Output Clamp Diodes
500-mA-Rated Collector Current(single
Inputs Compatible With Various Types of
Logic
General Description
The ULN2803 is high-voltage high-current
These devices are capable of driving a wide
Darlington transistor arrays each containing
range of loads including solenoids, relays, DC
seven open collector common emitter pairs.
motors, LED displays, filament lamps, thermal
Each pair is rated at 500mA. Suppression
print-heads and high-power buffers.
diodes are included for inductive load driving,
The ULN2803 is available in both a small
the inputs and outputs are pinned in opposition
outline 18-pin package (SOP18).
to simplify board layout.
Connection Diagram
SI
PR
O
IN
Pin Assignments
1
Ver1.1
Shanghai Siproin Microelectronics Co.
Pin Descriptions
Pin Name
Function
1
1B
Input pair1
2
2B
Input pair2
3
3B
Input pair3
4
4B
Input pair4
5
5B
Input pair5
6
6B
Input pair6
7
7B
Input pair7
8
8B
Input pair8
9
E
Common Emitter (ground)
10
COM
Common Clamp Diodes
11
8C
Output pair8
12
7C
Output pair7
13
6C
14
5C
15
4C
16
3C
18
Output pair6
Output pair5
Output pair4
Output pair3
PR
O
17
IN
Pin Number
2C
Output pair2
1C
Output pair1
SI
Functional Block Diagram
Note: All resistor values shown are nominal.
The collentor-emitter diode is a parasitic structure and should not be used to conduct current.If the collector(s) go
below ground an external Schoottky diode should be added to clamp negative undershoots.
2
Ver1.1
Absolute Maximum Ratings
(1)
At 25°C free-air temperature (unless otherwise noted)
Symbol
Parameter
Min
VCC
Collector to emitter voltage
VR
Clamp diode reverse voltage(2)
50
V
VI
Input voltage(2)
30
V
ICP
Peak collector current
500
mA
See typical characteristics
Max
Unit
50
V
IOK
Output clamp current
500
mA
ITE
Total emitter-terminal current
–2.5
A
TA
Operating free-air temperature range
70
°C
ULN2803
–20
θJA
Thermal Resistance Junction-to-Ambient(3)
63
θJC
Thermal Resistance Junction-to-Case(4)
12
TJ
Operating virtual junction temperature
150
°C
TSTG
Storage temperature range
150
°C
°C/W
IN
(1)
–65
Stresses beyond those listed under "absolute maximum ratings" may cause permanent damage to the device.
These are stress ratings only, and functional operation of the device at these or any other conditions beyond
those indicated under "recommended operating conditions" is not implied. Exposure to
PR
O
absolute-maximum-rated conditions for extended periods may affect device reliability.
(2)
All voltage values are with respect to the emitter/substrate terminal E, unless otherwise noted.
(3)
Maximum power dissipation is a function of TJ(max), θJA, and TA. The maximum allowable power dissipation
at any allowable ambient temperature is PD = (TJ(max) – TA)/θJA. Operating at the absolute maximum TJ of
150°C can affect reliability.
(4)
Maximum power dissipation is a function of TJ(max), θJC, and TA. The maximum allowable power dissipation
at any allowable ambient temperature is PD = (TJ(max) – TA)/θJC. Operating at the absolute maximum TJ of
SI
Recommended Operating Conditions
Symbol
Parameter
Min
Max
Unit
VCC
Collector to Emitter voltage
50
V
TA
Operating Ambient Temperature
40
+105
3
Ver1.1
Electrical Characteristics(TA=+25℃, unless otherwise specified)
Parameter
V
I(on)
V
CE(sat)
I
Test
Figure
V
F
I
I(off)
MIN
Unit
MAX
2.4
IC = 250 mA
2.7
IC = 300 mA
3
II = 250 μA,
IC = 100 mA
0.9
1.1
II = 350 μA,
IC = 200 mA
1
1.3
II = 500 μA,
IC = 350 mA
1.2
1.6
Figure 1
VCE = 50 V,
II = 0
50
Figure 2
VCE = 50 V,
TA = +105°C
II = 0
100
Clamp forward voltage
Figure 8
IF = 350 mA
1.7
2
V
Off-state input current
Figure 3
VCE = 50 V,
50
65
μA
0.93
1.35
On-state input voltage
Collector-emitter
saturation voltage
Figure 6
Figure 5
VCE = 2 V
IC = 500 μA
Input current
Clamp reverse current
Ci
Input capacitance
Figure 7
VI = 5 V
VI = 12 V
-100
15
25
VR = 50 V
TA = 70°C
PR
O
IR
Figure 4
IN
VI = 3.85 V
II
TYP
IC = 200 mA
Collector cutoff current
CEX
ULN2803
Test Conditions
VI = 0,
f = 1 MHz
V
V
μA
mA
50
μA
pF
Switching Characteristics (TA = +25°C, unless otherwise specified)
Parameter
Test
MIN
t
t
PHL
V
OH
Propagation delay time,
low- to high-level output
high- to low-level output
See Figure 9
SI
PLH
ULN2803
Conditions
See Figure 9
High-level output voltage VS = 50 V, IO = 300 mA,
after switching
See Figure 9
VS–20
UNIT
TYP
MAX
0.25
1
μs
0.25
1
μs
mV
4
Ver1.1
SI
PR
O
IN
Parameter Measurement Information
5
Ver1.1
Notes:
PR
O
IN
8. The pulse generator has the following characteristics:
Pulse Width=12.5Hz, output impedance 50Ω, tr≤5ns, tr≤10ns.
9. CL includes prove and jig capacitance.
SI
10. VIH=3V
6
Ver1.1
SI
PR
O
IN
SOP18 Outline Dimensions
7
Ver1.1
很抱歉,暂时无法提供与“ULN2803”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.66904
- 50+1.35335
- 150+1.21803
- 1500+0.99911
- 3000+0.92394
- 4500+0.87880
- 国内价格
- 1+0.96250
- 50+0.73920
- 1500+0.68200
- 国内价格
- 5+1.65950
- 50+1.33780
- 150+1.19480
- 1500+0.97990
- 3000+0.90580
- 4500+0.86140
