BST23C712V
Transient Voltage Suppressors
ROHS
Features
400 watts peak pulse power (tp = 8/20μs)
Protects two -7V to 12V lines
Low capacitance
Low clamping voltage
Solid-state silicon avalanche technology
IEC COMPATIBILITY (EN61000-4)
IEC 61000-4-2 (ESD) ±15kV (air), ±8kV (contact)
IEC 61000-4-4 (EFT) 40A (5/50ns)
Mechanical Characteristics
JEDEC SOT23 package
Applications
Protection of RS-485 transceivers with
Molding compound flammability rating: UL
extended common-mode range
94V-0
Security systems
Marking : Making Code
Automatic Teller Machines
Packaging : Tape and Reel per EIA 481
HFC systems
Net works
Circuit Diagram
Schematic & PIN Configuration
I/O1
I/O2
1
2
1
12V
12V
3
7V
7V
SM712
2
GND
3
SOT23(Top View)
1/5
BST23C712V
ROHS
Absolute Maximum Rating
Rating
Symbol
Value
Units
Peak Pulse Power ( tp =8/20μs)
PPP
400
Watts
Lead Soldering Temperature
TL
260(10 sec.)
°C
Peak Pulse Current ( tp =8/20μs)
Ipp
Operating Temperature
TJ
-55 to + 125
°C
TSTG
-55 to +150
°C
Storage Temperature
17/12
A
Electrical Parameters (T=25 ℃)
Symbol
I
Parameter
IPP
Maximum Reverse Peak Pulse Current
VC
Clamping Voltage @ IPP
VRWM
IR
VBR
IPP
Working Peak Reverse Voltage
VC VBR V RWM
Maximum Reverse Leakage Current @
IT
IR
Breakdown Voltage @ IT
IT
Test Current
IF
Forward Current
VF
Forward Voltage @ IF
IR
IT
V
VRWM VBR VC
IPP
Electrical Characteristics
BST23C712V
Parameter
Pins 1 to 3 and 2 to 3
(12V TVS)
Pins 3 to 1 and 3 to
2(7V TVS)
Min
Min
Symbol
Conditions
V RWM
Pin 3 to 1 or Pin 2
to 1
V BR
I PT = 1mA
Reverse Leakage
Current
IR
V R = V RWM
1
μA
Clamping Voltage
VC
I PP = 5A,
tp = 8/20μs
V
Clamping Voltage
VC
I PP = 17A,
tp = 8/20μs
26
15
V
VR = 0V, f = 1MHz
75
75
pF
Junction Capacitance
Cj
Reverse Stand-Off
Voltage
Reverse Breakdown
Voltage
VR = V RWM , f =
1MHz
Typ
Max
Typ
12
13.3
Max
Units
7
V
7.5
45
V
45
pF
2/5
BST23C712V
ROHS
Typical Characteristics
Figure 1 Non-Repetitive Peak Pulse Power vs.
Pulse Time
Figure 2 Power Derating curve
110
100
% of R ated P owe r or I PP
400W 8/20µs
Waveform
1
0.1
0.01
0.1
1
10
100
1000
90
80
70
60
50
40
30
Waveform
Parameters:
tr=8us
td=20us
80
Clamping voltage – Vc (V)
Percent of Ipp
110
100
90
e-t
60
50
td=IPP/2
40
30
10
100
125
150
175
Figure 4 Clamping Voltage vs. Peak Pulse
Current
Figure 3 PulseWaveform
70
75
Ambient Temperature - TA( ℃ )
Pulse Duration - tp (us)
25
30
Time(us)
24
22
16
14
12
10
8
6
4
2
Pin 1 to 3 and 2 to 3
Pin 3 to 1 and 3 to 2
Waveform
Parameters:
Tr=8us
Td=20us
4
6
8
10
12
Peak Pulse Current - Ipp(A)
Figure 5 Capacitance vs. Reverse Voltage
80
70
Capacitance - C J (pF)
Peak Pulse Power - Ppp (KW)
10
60
50
40
30
f=1MHz
2
3
4
5
6
7
8
9
10 11 12 13
Reverse Voltage - VR (V)
3/5
14
16
BST23C712V
ROHS
Application Information
Device Connection for Protection of Two RS-485 DataLines
EIA RS-485 specifies a ±7V ground difference between devices on the bus. This permits the bus voltage
to range from +12V (5V + 7V) to -7V (0 - 7V).
The BST23C712V is designed to protect two RS-485 data lines in extended comm on mode applications. The
BST23C712V may be used to protect devices from transient voltages resulting from ESD, EFT, and lightning.
The device is designed with asymmetrical operating voltages for optimum protection. The TVS diodes at
pins 1 and 2 have a working voltage of 12 volts. These pins are connected to the differential data line
pairs. The TVS diodes at pin 3 have a working voltage of 7 volts. Pin 3 is connected to ground. The
internalTVS diodes of the BST23C712V will protect the transceiver input from positive transient voltage
spikes greater than 12V and Negative spikes greater than 7V.
A series current limiting resistor may be added in applications requiring enhanced surge immunity.
RS-485 Common Mode Voltages
Vcc 1
5V
Vcc 2
5V
Twisted Pair
B
A
100
INPUT
100
B
GND
OUTPUT
A
12V to -7V
COMMON-MODE VOLTAGE
RS-485 Protection Circuit
Vcc
5V
RT
D
12V
7V
12V
7V
R
BST23C712V
4/5
BST23C712V
ROHS
Outline Drawing – SOT23
PACKAGE OUTLINE
D
SOT23
3
DIMENSIONS
E1 E
0.25
θ
1
b
L
2
A
e
A
A2
b
C
e
e1
INCHES
MAX
MIN
MAX
0.900
1.150
0.035
0.045
A1
0.000
0.100
0.900
1.050
0.035
0.000
0.041
D
2.800
3.000
0.110
0.118
b
0.300
0.500
0.012
0.020
E
2.250
2.550
0.089
0.100
E1
1.200
1.400
0.047
0.055
0.950 BSC
0.004
0.037 BSC
L
0.300
0.500
0.012
0.020
θ
8○
8○
Notes
DIMENSIONS
M
MILLIMETER
MIN
A2
e
A1
Z
SYMBOL
DIM
INCHES
MILLIMETERS
M
0.088
2.20
C
0.0058
0.15
Z
0.093
2.35
e
0.037 BSC
0.95 BSC
e1
0.074 BSC
1.9 BSC
b
0.0389
0.35
1. Dimensioning and tolerances per ANSI Y14.5M,
1985.
2. Controlling Dimension: Inches
3. Pin 3 is the cathode (Unidirectional Only).
4. Dimensions are exclusive of mold flash and metal
burrs.
Marking Codes
Part Number
Marking Code
BST23C712V
7AM
Package Information
Qty:3k/Reel
5/5
很抱歉,暂时无法提供与“BST23C712V”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.68372
- 50+0.54691
- 600+0.42721
- 1200+0.42080
- 3000+0.33127
- 国内价格
- 1+0.58960
- 200+0.40700
- 1500+0.36960
- 3000+0.34540
- 国内价格
- 5+0.83900
- 50+0.67030
- 150+0.58640
- 500+0.52350
- 3000+0.40580
- 6000+0.38060
- 国内价格
- 5+0.84608
- 50+0.67684
- 150+0.59217
- 500+0.52866
- 3000+0.40986
- 6000+0.38448
