JIANGMEN ORIENT OPTOELECTRONICS Co., Ltd
ORH-G35A
SPECIFICATION
Customer Name
Customer No.
0805 Top View Green LED
Product Description
ORH-G35A
Product Model
Orient Confirm
Customer Confirm
Approved
by
Checked by
Prepared by
Linshixiu
Sushiheng
Zhaowanbao
Judge outcome:
OK
Approved
by
Quality
Engineering
Judge outcome:
Add:Building 1,21 Jinhui Road, Jianghai district, Jiangmen
TEL:+86-750-3697838
URL:www.orient-opto.com
Copyright© 2020 Orient Photoelectric Corporation.
1
Ver, A4
ORH-G35A
1、Features
● Emitted Color : Super Green.
● Lens Appearance : Water Clear.
● Mono-color type.
● 2.0x1.25x0.8mm(0805) standard package.
● Suitable for all SMT assembly methods.
● Compatible with infrared and vapor phase reflow solder process.
● Compatible with automatic placement equipment.
● This product doesn’t contain restriction substance, comply RoHS standard.
2、Applications
● Automotive : Dashboards, stop lamps,turn signals.
● Backlighting : LCDs, Key pads advertising.
● Status indicators : Comsumer & industrial electronics.
● General use.
2
Ver, A4
ORH-G35A
3、Package Outline Dimensions
Notes:
1).All dimensions are in millimeters (inches).
2).Tolerance is ± 0.10mm (0.004”) unless otherwise specified.
3).Specifications are subject to change without notice.
3
Ver, A4
ORH-G35A
4、Absolute maximum ratings at Ta=25℃
Parameter
Symbol
Rating
Unit
Power Dissipation
PD
120
mW
Forward Current
IF
30
mA
IFP
100
mA
Reverse Voltage
VR
5
V
O p e r a t i n g Te m p e r a t u r e R a n g e
Topr
-40~+85
Storage Temperature Range
Tstg
-40~+100
Electrostatic Discharge
ESD
2000(HBM)
V
Soldering Temperature
Tsld
Peak Forward Current
Notes:
*1
*1
Reflow Soldering:260℃ for 10 secs
Hand Soldering: 350℃ for 3 secs
Condition for IFP is pulse of 1/10 duty and 0.1msec width.
5、Electrical-optical characteristics at Ta=25℃
Parameter
Condition
Symbol
Forward Voltage
IF=20mA
VF
2.8
3.0
3.3
V
Luminous Intensity
IF=20mA
IV
800
1000
1100
mcd
VR=5V
IR
1
uA
Peak Wave Length
IF=20mA
λP
525
nm
Dominant Wave Length
IF=20mA
λD
522
525
531
nm
Spectral Line Half-width
IF=20mA
Δλ
30
nm
Viewing Angle
IF=20mA
2θ1/2
132
deg
Reverse Current
Min. Typ. Max. Unit
Notes:
1、Tolerance of luminous flux is ±10%.
2、Tolerance of forward voltage is ±0.1V.
4
Ver, A4
ORH-G35A
6、Typical optical characteristics curves
Fig.2 Forward current derating curve
Fig.1 Relative intensity vs. wavelength
vs. ambient temperature
1.0
60
Forward current (mA)
Relative radiant intensity
50
0.5
40
30
525
Wavelength (nm)
50
100
2.5
Relative Luminous intensity
(Normalized @20mA)
80
3.0
40
30
2.0
1.5
1.0
0.5
1
2
3
4
5
-20
Forward voltage(V)
60
Ambient temperature Ta( C)
Fig.5 Relative luminous intensity
vs. forward current
Fig.6 Radiation diagram
10
1.5
Relative luminous intensity (@20mA)
60
Fig.4 Relative luminous intensity vs.
ambient temperature
Fig.3 Forward current vs. forward voltage
1.0
0.5
1.0
40
0.9
50
0.8
60
70
0.7
80
90
40
50
0.5
0.3
0.1
0.2
0.4
0.6
5
Ver, A4
ORH-G35A
7、Bin Limits
Intensity Bin Limits (At 20mA)
BIN CODE
Min.(mcd)
Max.(mcd)
Q
800
900
W
900
1000
E
1000
1100
Notes: Tolerance for each Bin limit is ±10%.
Color Bin Limits (At 20mA)
BIN CODE
Min.(nm)
Max.(nm)
1
522
525
2
525
528
3
528
531
Notes: Tolerance for each Bin limit is ±1nm.
VF Bin Limits (At 20mA)
BIN CODE
Min.(V)
Max.(V)
S
2.8
2.9
D
2.9
3.0
F
3.0
3.1
G
3.1
3.2
H
3.2
3.3
Notes: Tolerance for each Bin limit is ±0.1V.
6
Ver, A4
ORH-G35A
8、Packaging Specification
●Dimensions for Reel (Unit: mm)
13.0± 0.5
TRAILER
179± 1
13.0± 0.5
71.0± 1
8.0 ± 0.3
2.26± 0.1
1.0± 0.1
LEADER
0.3
FIXING TAPE
OTE: 4000 pcs PER REEL
●Dimensions of Tape (Unit: mm)
USER DIRECTION OF FEED
1.0± 0.1
1.5± 0.1
4.0 ± 0.1
2.0± 0.05
2.26± 0.1
8.0 ± 0.3
3.5 ± 0.05
CATHODE
4.0 ± 0.1
71.0± 1
END
5.3 ± 0.05
START
1.75 ± 0.1
ANODE
1.42 ± 0.1
0.3
NOTE: 4000 pcs PER REEL
Notes:
1、All dimensions are in mm, tolerance is±0.1mm unless otherwise noted.
2、Specifications are subject to change without notice.
3、Loaded quantity:3000 pcs/reel.
7
Ver, A4
ORH-G35A
●Package Method: Vacuum (Unit: mm)
9、Label description
●BIN description: X - X - X
Forward voltage BIN CODE
Color BIN CODE
Intensity BIN CODE
8
Ver, A4
ORH-G35A
10、Reliability Test Items and Conditions
Test Item
Test
Test
Hours
Conditions
Times
Units
Failed
Tested
Ac/
Re
Reflow
Soldering
260℃(Max.),
within
10seconds.
(Max.)
3 times
0/20
0/1
Temperature
cycle
-40℃ 30min
↑↓25℃(5min)
100℃ 30min
10
cycles
0/20
0/1
Thermal Shock
-40℃ 20min
↑↓ 5sec
100℃ 20min
10
cycles
0/20
0/1
Operation Life
IF=20mA
Ta=25℃
1000
hours
0/20
0/1
High
Temperature
High Humidity
Storage
Ta=100℃
RH=90-95%
240
hours
0/20
0/1
High
Temperature
Storage
Ta=100℃
1000
hours
0/20
0/1
Low
Temperature
Storage
Ta=-40℃
1000
hours
0/20
0/1
Criteria
IV@
20mA
VF@
20mA
很抱歉,暂时无法提供与“ORH-G35A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.10293
- 500+0.07960
- 3000+0.07010
- 6000+0.06232
- 24000+0.05552
- 51000+0.05195
- 国内价格
- 50+0.09435
- 600+0.07296
- 1200+0.07187
- 3000+0.06425
- 15000+0.05712
- 30000+0.05089
- 国内价格
- 1+0.28490
- 200+0.09482
- 1500+0.05929
- 3000+0.04708
