独石电容器产品承认书
APPROVAL SPECIFICATIONS FOR
MONOLITHIC CAPACITORS
客户
CUSTOMER
客户料号
CUSTOMER P/N
产品编码
PART NUMBER
1H331JC9I-CH-EE-ZNR
规格描述
DESCRIPTION
50V/331/J/F5.08/L24/NP0/0805/ZNR
日期
DATE
文件编号
DOC. NO.
2022-07-05
德尔创承认栏
APPROVED BY DERSONIC
DEC-WD-WI001(C)
客户承认栏
APPROVED BY CUSTOMER
批 准
APPROVED BY
审核
CHECK BY
制订
FORMULATE BY
彭少雄
吴成爱
陈冬花
批 准
APPROVED BY
审核
CHECK BY
東莞市德尔创电子有限公司
DONGGUAN CITY DERSONIC ELECTRONICS CO., LTD.
广東省東莞市长安镇锦厦河南工业区锦平路 5 号
NO.5, JINGPING ROAD, JINXIA HENAN INDUSTRIAL ZONE, CHANGAN TOWN DONGGUAN CITY, PRC
TEL:86-769-8155 5686
FAX:86-0769-8155 5989
WEBSITE: HTTP://WWW.DERSONIC.COM
E-MAIL:SALES@DERSONIC.COM
独石电容器
目录
CONTENTS
数据表
DATA SHEET
3
特点
FEATURES
4
用途
APPLICATIONS
4
容量规格表
CAPACITANCE LIST
5
尺寸规格
DIMENSION SPECIFICATIONS
5
标准与试验方法
SPECIFICATIONS AND TESTING METHOD
6
请确保我们的产品安装到您的产品上前,已根据您的需求进行了评估。
Please make sure that your product has been evaluated in view of your
specifications with our product being mounted to your product.
请您在使用我们的产品时,不要偏离此标准。
You are requested not to use our product deviating from this specification.
2
独石电容器
数据表
DATA SHEET
产品编码
Part number
1H331JC9I-CH-EE-ZNR
规格描述
Description
客户料号
Customer P/N
介质类别
Dielectric class
Class 1
额定电压
Rated voltage
50Vdc
电容量
Capacitance
损耗角正切
Tangent of loss angle
耐电压
Testing voltage
尺寸
DIMENSIONS
330pF ± 5% @ 1MHz (100kHz) 1.0V 25ºC
0.003 max @ 1MHz (100kHz) 1.0V 25ºC
125Vdc (Charge/discharge 2mA max) 3s PASS
绝缘电阻
Insulation resistance
10000MΩ min @ 50V 60s, RH≤70%
温度特性
Temperature characteristics
NP0
ΔC/C: 0± 60PPM/ºC @ -55ºC~125ºC
W (Weight)
5mm max
H (Height)
3.8mm max
T (Thickness)
3.2mm max
F (Lead spacing)
5.08mm± 0.8mm
L (Lead length)
24mm± 4.0mm
ød (Lead diameter)
3
0.55mm max
独石电容器
特点
FEATURES
独石电容器是用多层陶瓷电容器为芯片,CP线为导线,使用无铅锡焊接、环氧树脂包
封,激光打标而成,因此具有以下特点:
Monolithic capacitors with multilayer ceramic capacitor as chip, copper-clad steel wire as leads, lead-free
soldering and epoxy resin coating, laser marking. So it has the following characteristics:
■ 体积小、容量大,容积率为10µF/cm3,接近电解电容器,且没有极性
Small dimensions, large capacitance, and a capacity volume ratio of 10µF/cm3, close to that of
electrolytic capacitors. These do not have polarity.
■ 频率特性极佳,且电感系数小,适于高频应用
These have excellent frequency characteristics and due to these small internal inductance are suitable
for high frequencies
■ 环氧树脂封装,具有优良的防潮性能、机械强度及耐热性,阻燃性符合UL94 V-0标准
Epoxy resin coating creates excellent performance in humidity resistance, mechanical strength and heat
resistance, nonflammable to the UL94V-0 standard
■ 工作温度高达125°C
Operating temperature range guaranteed up to 125 degrees
■ 产品规格齐全,容量从1pF至22µF
Complete range of capacitance values, 1pF to 22µF
简介
Intro
容量
Capacitance
此类介质材料的电容器为I类电容器,电性能稳定,几乎不随温度、电压和时
间的变化而变化。适用于低损耗、容量稳定性要求高的电路中,如滤波器、
谐振器和计时电路中。
The capacitor of this kind dielectric material is considered as Class I capacitor, including
general capacitor and high frequency C0G capacitor. The electrical properties of C0G
capacitor are the most stable one and have little change with temperature, voltage and
applications where low-losses and high-stability are required, time. They are suited for such
as filters, oscillators, and timing circuits.
1pF to 0.01µF
X7R
X5R
此类介质材料的电容器为II类电容器,具有较高的介电常数,容量比I类电容
器高,具有较稳定的温度特性,适用于容量范围广,稳定性要求不高的电路
中,如隔直、耦合、旁路、鉴频等电路中。
Material is a kind of material has high dielectric constant. The capacitor made of this kind
material is considered as Class II capacitor whose capacitance is higher than that of class I.
These capacitors are classified as having a semi-stable temperature characteristic and used
over a wide temperature range, such in these kinds of circuits, DC-blocking, decoupling,
bypassing, frequency discriminating etc.
100pF to 10µF
Y5V
此类介质材料的电容器为II类电容器,是所有电容器中介电常数最大的电容
器,但其容量稳定性较差,对温度、电压等条件较敏感,适用于要求大容
量,温度变化不大的电路中。
The capacitor made of this kind of material is the highest dielectric constant of all ceramic
capacitors. They are used over a moderate temperature range in application where high
capacitance is required because of its unstable temperature coefficient, but where
moderate losses and capacitance changes can be tolerated. Its capacitance and dissipation
factors are sensible to measuring conditions, such as temperature and voltage,etc.
1000pF to 22µF
特性
Char.
C0G
(NP0)
■ 符合RoHs标准,无卤
Comply with RoHS, Halogen-free available
■ 适合AI自动安装
Cost-saving automatic insertion available
用途
APPLICATIONS
径向引线多层陶瓷电容器广泛应用于计算机、数据处理通信和工业控制仪表设备。
Radial leaded multilayer ceramic capacitor has wide application in computer, data processing telecommunication, and
industrial control instrumentation equipment.
DONGGUAN CITY DERSONIC ELECTRONIC CO., LTD.
4
德信立业,创新开拓
独石电容器
容量规格表
CAPACITANCE
LIST
T.C.
C0G
(NP0)
X7R
Rated
voltage
Capacitance range
010 100
101
102
103
152272
104
105
106
50V
010
100V
010
821152
472
0805
250V
010
471 152
472
1206
500V
010
561
25V
221
50V
221
103
0603
1210
222
684
183
100V
101
250V
101
682
500V
101
682
25V
102
50V
102
100V
102
104
105
104
105
333
223
475
106
225
224
473
105
225
226
475
Y5V
105
474
106
104
如果上表中没有您需求的规格,请向我公司业务咨询。
If you do not have the specifications you need in the above table, please consult our business.
W
T
H+2.0
W
H+2.5
H
H+1.5
■ 标准品尺寸规格
尺寸规格
Dimensions of component for standard product
DIMENSION
W
W
SPECIFICATIONS
脚型代码
Lead style code:
L
L
L
L
Ød
F
F
F
W
A
9
芯片规格
Chip Spec.
脚型代码
Lead style Code
W
mm max.
H
mm max.
T
mm max.
F
±0.8mm
L
mm min.
d
±0.1mm
0603
9
4.2
3.8
3.2
2.54
5.08
20.0
0.47
0805
9
4.5
3.8
3.2
2.54
5.08
20.0
0.47
1206
A
9
6.0
4.5
3.8
2.54
5.08
20.0
0.47
1210
A
9
6.0
5.5
3.8
2.54
5.08
20.0
0.47
尺寸与脚型可以订制。
Size and lead style can be customized.
5
德信立业,创新开拓
独石电容器
标准与试验方法
序
No.
项目
Item
1
工作温度范围
Operating
temperature range
2
额定电压
Rated voltage
(UR)
3
外观与尺寸
Appearance (APP)
and Dimension
4
标志
Marking
5
容量
Capacitance
(CR)
6
损耗角正切
(tanδ)
试验方法
Testing Method
标准
Specifications
X7R / C0G: -55ºC~+125ºC
X5R: -55ºC~+85ºC
Y5V: -25ºC~+85ºC
额定电压是指在工作温度范围内,可连续施加在电容器上的最大直
流电压或最大交流电压有效值或脉冲电压的峰值。
当交流电压附加于直流电压时,Vp-p或Vo-p(以较大者为准)应维
持在额定电压范围内。
The rated voltage is defined as the maximum voltage which may be applied
continuously to the capacitor within the operating temperature range.
When AC voltage is superimposed on DC voltage, Vp-p or Vo-p, whichever is
larger, should be maintained within the rated voltage range.
外观形状没有明显的缺点,尺寸在标准范
围内。
No marked defect on appearance form and
dimensions are within specified range.
电容必须用目视检查其明显的缺点。
The capacitor should be visually inspected for evidence of defect.
尺寸用游标卡尺测量。
Dimensions should be measured with slide calipers.
清晰易于识别。
To be easily legible.
目视检查。
The capacitor should be visually inspected.
在误差范围内。
Within the specified tolerance.
容量与tanδ在25±1℃下,使用下列条件进行测量。
The capacitance, tanδ should be measured at 25°C±1°C with the following
conditions.
特性
Char.
C0G, ≥30pF: Q≥1,000
25V: ≤0.035
25V: ≤0.050
Y5V,
≥100V: ≤0.050
>25V & 1000pF
1kHz
1Vrms
X7R, X5R
Y5V
100V
≤200V
>200V
≤500V
>500V
测试电压
Testing voltage
(TV)
2.5UR
1.5UR
+100V
1.3UR
+100V
1.3UR
在引线出口处沿一个方向施加5N、90°的弯曲压力,再恢复至初始
状态。之后,在2至3秒内再以相反方向施加一次90°的弯曲压力。
Each lead wire should be subjected to 5N of weight and bent 90° at the point of
egress, in one direction, then returned to its original position and bent 90° in
the opposite direction at the rate of one bent in 2 to 3s.
导线必须有3/4以上的面积均匀附着焊锡
Lead wire should be soldered with uniform coating
on the axial direction over 3/4 of the
circumferential direction.
额定电压
Rated voltage
固定住电容器,在引线上逐步施加径向拉力直至10N,并保持
10±1秒钟。
Fix the body of the capacitor and apply a tensile weight gradually to each lead
wire in the radial direction of the capacitor up to 10N and keep it for 10±1s.
导线抗张强度
Terminal
tensile strength
导线抗折强度
Terminal
bending strengt
频率
Frequency
C0G
C0G,
绝缘电阻
(IR)
容量
Capacitance
6
引线必须浸入焊料中3±0.5秒钟,浸入深度离导线根部1.5-2.0mm。
The lead wire of a capacitor should be dipped into molten solder for 3±0.5s.
The depth of immersion is up to about 1.5~2.0mm from the root of lead wires.
焊锡温度:
无铅焊(Sn-3Ag-0.5Cu) 245±5°C
Temp. of solder: Lead Free Solder (Sn-3Ag-0.5Cu) 245±5°C
德信立业,创新开拓
独石电容器
标准与试验方法
序
No.
12
焊锡
耐热性
Soldering
effect
APP
没有可见损伤
No marked defect
ΔC/C
C0G:
