PRODUCT SPECIFICATION SHEET
Customer
Customer P/N
TBA
Product Type
Voltage Controlled Temperature Compensated Crystal
Oscillator
Part Number
9T26000H28
Part Description
Nominal Frequency
Prepared
Li Xiang
Reviewed
Jin Zhe
Approved
Xing Yue
Date
Version
S1
SMD VC-TCXO 2.0 x 1.6
26.000000MHz
Customer's Approval & Date:
2022-6-13
廣東惠倫晶體科技股份有限公司
中 国 广 东 省 东 莞 市 黄 江 镇 东 环 路 鸡 啼 岗 段 68 号
68 Donghuan Road, Jitigang Village, Huangjiang,
Dongguan, Guangdong Province, P. R. China
WEB : http://www.dgylec.com/
TEL : +86 ( 0 ) 769 - 38879888
FAX : +86 ( 0 ) 769 - 38879889
EMAIL : yl@dgylec.com
FAITH LONG CRYSTAL Proprietary and Confidential Information
Pb
RoHS
COMPLIANT
Lead-Free
Moisture Sensitivity Level 1
Page 1 of 6
PN: 9T26000H28
Ver.
S1
CONTENTS
Item
1
History of Specification Revision
3
2
Electrical Specifications
4
3
4
Page
2.1 Operation conditions
4
2.2 Output characteristics
4
2.3 Frequency characteristics
4
2.4 Auto frequency control (AFC) characteristics
4
2.5 Phase noise characteristics
4
Product Design
5
3.1 Package dimensions and pad functions
5
3.2 Recommended land pattern
5
3.3 Recommended reflow profile
5
Testing Circuit
6
Page 2 of 6
PN: 9T26000H28
Ver.
S1
1. History of Specification Revision
Ver.
Contents
Date
Reviser
S0
Initial release
2020-6-29
Han Shuang
S1
Marking information update
2022-6-13
Li Xiang
NOTE
Page 3 of 6
PN: 9T26000H28
Ver.
S1
2. Electrical Specification
Parameters
1
Nominal frequency
Supply voltage (VCC)
2
3
Current consumption
4
Operating temperature range
5
Storage temperature range
Parameters
1
Output type
2
3
4
5
6
7
Standard output Load
Output level
Duty cycle
Harmonics
Start-up time vs. frequency
Start-up time vs. output level
Parameters
1
Nominal frequency
Min.
Max.
1.71
-40
-40
Typ.
26.000000
Remark
1.89
2.0
+85
+90
Unit
MHz
V
mA
°C
°C
Min.
Typ.
Max.
Unit
Remark
Clipped sine wave
10 KΩ//10 pF
Vpp
dBc
ms
ms
0.8
40
50
60
-5
2.0
2.0
Min.
Typ.
26.000000
Max.
Unit
MHz
Decoupling capacitor is
required in external circuit
Within ±0.5 ppm
90% of Vpp
9T26000H28
Remark
2
Frequency tolerance after reflow
-2.0
+2.0
ppm
At 25±2°C after 2 times
reflow, refer to nominal
frequency
3
Frequency stability vs. temperature
-0.5
+0.5
ppm
Refer to frequency at 25°
C within operating
temperature range
4
5
Frequency stability vs. supply voltage
Frequency stability vs. load variation
Slope of frequency drift over
temperature
Aging over 1st year
-0.1
-0.1
+0.1
+0.1
ppm
ppm
±5% VCC variation
±5% load variation
-0.2
+0.2
ppm/°C
-1.0
+1.0
ppm
Parameters
AFC control voltage range (VAFC)
1
AFC frequency tuning range at Min. VAFC
2
AFC frequency tuning range at Max. VAFC
3
Min.
0.3
-12.0
+8.0
Typ.
0.9
Max.
1.5
-8.0
+12.0
Unit
V
ppm
ppm
Parameters
1
Phase noise at 1kHz offset
2
Phase noise at 100kHz offset
Min.
Typ.
-135
-152
Max.
Unit
dBc/Hz
dBc/Hz
6
7
Remark
Refer to VAFC=0.9V
Refer to VAFC=0.9V
Remark
At 25±2°C
At 25±2°C
Page 4 of 6
PN: 9T26000H28
Ver.
S1
3. Product Design
Top view
Bottom view
Unit : mm
2.00±0.15
0.22
0.425
Pad 4
Pad 3
Pad 3
Pad 4
0.425
0.625
1.60±0.15
YL xxx
0.40
0.625
Pad 1
Pad 2
Pad 2
Pad 1 index
0.15
Pad 1
1.20
Lateral view
0.8 Max.
Pad
1
2
3
4
Function
AFC control voltage
Ground
Output
Supply voltage
Symbol
VAFC
GND
OUT
VDD
0.60
0.60
0.80
0.40
0.80
Unit : mm
1.20
10 sec. Max.
Temp.
260 5
(1) Total time : 360 sec. Max.
(2) Solder melting point : 225℃
220
60 sec. Max.
180
150
120 sec. Max.
Time (sec.)
Page 5 of 6
PN: 9T26000H28
Ver.
S1
4. Testing Circuit
C3
A
VDD
Output
VDD
Power
Supply
_
V
OUT
VC-TCXO
C1
VAFC
RL
CL
GND
VAFC
C2
GND
External Components:
Parts
Function
C1
AC noise bypass for VDD
AC noise bypass for VAFC
C2
C3
DC block for output
RL
Load resistance
CL
Load capacitance
Recommended
10nF
1nF
10nF
10KΩ
10pF
Page 6 of 6
很抱歉,暂时无法提供与“9T26000H28”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2.16000
- 30+2.08800
- 100+1.94400
- 500+1.80000
- 1000+1.72800
