SJD Series
TVS Diodes
Description
The SJD series is designed specifically to protect sensitive electronic equipment from voltage transients induced by
lightning and other transient voltage events. SJD12 package is 50% smaller in footprint when compare to SMA
package and deliverying one of the low height profiles (1.2mm) in the industry.
Features
IEC-61000-4-2 ESD 15kV(Air), 8kV (Contact)
SOD-123FL surface mount package
Protects one I/O line
Peak power dissipation of 1000W under 8/20μs waveform
Low leakage current
Solid-state silicon avalanche technology
RoHS compliant
Solder reflow temperature: Pure Tin-Sn, 260~270℃
Flammability rating UL 94V-0
Meet MSL level1, per J-STD-020
Applications
SJD12 devices are ideal for the protection of I/O interfaces, VCC bus and other vulnerable circuit used in cellular
phones, portable devices, business machines, power supplies and other consumer applications.
Maximum Ratings and Characteristics (TA=25℃)
Rating
Symbol
Value
Peak pulse power dissipation at 10/1000μs waveform
(Note1, Note2, Fig.1)
PPPM
200W
Peak pulse power (tp=8/20μs waveform)
PPPM
1000W
Peak pulse current of at 10/1000μs waveform (Note 1, Fig.3)
IPPM
See Table(A)
PM(AV)
1.0W
VF
3.5V
IFSM
20A
TJ,TSTG
-55℃ to +150℃
Typical thermal resistance junction to lead
RθJL
100℃/W
Typical thermal resistance junction to ambient
RθJA
220℃/W
Steady state power dissipation at TL=75℃ (Fig.5)
Maximum Instantaneous Forward Voltage at 12A for Unidirectional Only
Peak forward surge current, 8.3ms single half sine-wave superimposed on
rated load, (JEDEC Method) (Note3, Fig.6)
Operating junction and Storage Temperature Ranges
Notes:1. Non-repetitive current pulse, per Fig.3 and derating above TA=25℃ per Fig.2.
2. Each terminal is surface Mounted on the 5.0mm×5.0mm (0.03mm thick) copper pads.
3. 8.3ms single half sine-wave or equivalent square wave, duty cycle=4 pulses per minutes maximum.
SJD Series
TVS Diodes
Electrical Characteristics (TA=25℃)
Device
Marking
Code
Part
Number
Reverse
Stand-Off
Voltage
Breakdown
Voltage
@IT
Test
Current
Maximum
Clamping
Voltage
@IPP
Peak
Pulse
Current
Reverse
Leakage
@VR
Uni.
Bi.
Uni.
Bi.
VR(V)
VB MIn.(V)
VB Max.(V)
IT(mA)
VC(V)
IPP(A)
IR(μA)
SJD12A05L01
SJD12C05L01
KE
AE
5
6.4
7
10
9.2
21.8
500
SJD12A06L01
SJD12C06L01
KG
AG
6
6.67
7.37
10
10.3
19.4
400
SJD12A6.5L01
SJD12C6.5L01
KK
AK
6.5
7.22
7.98
10
11.2
17.9
350
SJD12A07L01
SJD12C07L01
KM
AM
7
7.78
8.6
10
12.0
16.7
200
SJD12A7.5L01
SJD12C7.5L01
KP
AP
7.5
8.33
9.21
1
12.9
15.5
100
SJD12A08L01
SJD12C08L01
KR
AR
8
8.89
9.83
1
13.6
14.7
50
SJD12A8.5L01
SJD12C8.5L01
KT
AT
8.5
9.44
10.4
1
14.4
13.9
SJD12A09L01
SJD12C09L01
KV
AV
9
10
11.1
1
15.4
13.0
10
SJD12A10L01
SJD12C10L01
KX
AX
10
11.1
12.3
1
17.0
11.8
5
SJD12A11L01
SJD12C11L01
KZ
AZ
11
12.2
13.5
1
18.2
11.0
3
SJD12A12L01
SJD12C12L01
LE
BE
12
13.3
14.7
1
19.9
10.1
1
SJD12A13L01
SJD12C13L01
LG
BG
13
14.4
15.9
1
21.5
9.3
1
SJD12A14L01
SJD12C14L01
LK
BK
14
15.6
17.2
1
23.2
8.6
1
SJD12A15L01
SJD12C15L01
LM
BM
15
16.7
18.5
1
24.4
8.2
1
SJD12A16L01
SJD12C16L01
LP
BP
16
17.8
19.7
1
26.0
7.7
1
SJD12A17L01
SJD12C17L01
LR
BR
17
18.9
20.9
1
27.6
7.3
1
SJD12A18L01
SJD12C18L01
LT
BT
18
1
29.2
6.9
1
SJD12A20L01
SJD12C20L01
LV
BV
24.5
1
32.4
6.2
1
SJD12A22L01
SJD12C22L01
LX
BX
22
24.4
26.9
1
35.5
5.7
1
SJD12A24L01
SJD12C24L01
LZ
BZ
24
26.7
29.5
1
38.9
5.2
1
SJD12A26L01
SJD12C26L01
ME
CE
26
28.9
31.9
1
42.1
4.8
1
SJD12A28L01
SJD12C28L01
MG
CG
28
31.1
34.4
1
45.4
4.4
1
SJD12A30L01
SJD12C30L01
MK
CK
30
33.3
36.8
1
48.4
4.2
1
SJD12A33L01
SJD12C33L01
MM
CM
33
36.7
40.6
1
53.3
3.8
1
SJD12A36L01
SJD12C36L01
MP
CP
36
40
44.2
1
58.1
3.5
1
SJD Series
TVS Diodes
Device
Marking
Code
Part
Number
Reverse
Stand-Off
Voltage
Breakdown
Voltage
@IT
Test
Current
Maximum
Clamping
Voltage
@IPP
Peak
Pulse
Current
Reverse
Leakage
@VR
Uni.
Bi.
Uni.
Bi.
VR(V)
VB MIn.(V)
VB Max.(V)
IT(mA)
VC(V)
IPP(A)
IR(μA)
SJD12A40L01
SJD12C40L01
MR
CR
40
44.4
49.1
1
64.5
3.1
1
SJD12A43L01
SJD12C43L01
MT
CT
43
47.8
52.8
1
69.4
2.9
1
SJD12A45L01
SJD12C45L01
MV
CV
45
50
55.3
1
72.7
2.8
1
SJD12A48L01
SJD12C48L01
MX
CX
48
53.3
58.9
1
77.4
2.6
1
SJD12A51L01
SJD12C51L01
MZ
CZ
51
56.7
62.7
1
82.4
2.5
1
SJD12A54L01
SJD12C54L01
NE
DE
54
60
66.3
1
87.1
2.3
1
SJD12A58L01
SJD12C58L01
NG
DG
58
64.4
71.2
1
93.6
2.2
1
SJD12A60L01
SJD12C60L01
NK
DK
60
66.7
73.7
1
96.8
2.1
1
SJD12A64L01
SJD12C64L01
NM
DM
64
71.1
78.6
1
103.0
2.0
1
SJD12A70L01
SJD12C70L01
NP
DP
70
77.8
86
1
113.0
1.8
1
SJD12A75L01
SJD12C75L01
NR
DR
75
83.3
92.1
1
121.0
1.7
1
SJD12A78L01
SJD12C78L01
NT
DT
78
86.7
95.8
1
126.0
1.6
1
SJD12A85L01
SJD12C85L01
NV
DV
85
94.4
104
1
137.0
1.5
1
SJD12A90L01
SJD12C90L01
NX
DX
90
100
111
1
146.0
1.4
1
SJD12A100L01
SJD12C100L01
NZ
DZ
100
111
123
1
162.0
1.3
1
SJD12A110L01
SJD12C110L01
PE
EE
110
122
135
1
177.0
1.2
1
SJD12A120L01
SJD12C120L01
PG
EG
120
133
147
1
193.0
1.1
1
SJD12A130L01
SJD12C130L01
PK
EK
130
144
159
1
209.0
1.0
1
SJD12A150L01
SJD12C150L01
PM
EM
150
167
185
1
243.0
0.8
1
SJD12A160L01
SJD12C160L01
PP
EP
160
178
197
1
259.0
0.8
1
SJD12A170L01
SJD12C170L01
PR
ER
170
189
209
1
275.0
0.8
1
SJD Series
TVS Diodes
Ratings and Characteristic Curves (TA=25℃)
Figure 1. Peak Pulse Power Rating Curve
Figure 2. Pulse Derating Curve
Figure 3. Pulse Waveform
Figure 4. Typical Junction Capacitance
150
tr=10µs
1000
Peak Value IPPM
Uni-directional V=0V
Cj (pF)
100
Half Value IPPM (IPPM/2)
50
TJ=25℃
Pulse Width(td) is defined as
the point where the peak
current decays to 50% of IPPM
10/1000µs Waveform
as defined by R.E.A
1
1.0
2.0
3.0
Bi-directional V=0V
10
td
4.0
Time (ms)
Figure 5. Steady State Power Dissipation Derating
Curve
TJ=25℃
f=1.0MHz
Vsig=50mVp-p
1
10
100
VBR-Reverse Breakdown Voltage (V)
1000
Figure 6. Maximum Non-Repetitive Forward Surge
Current Uni-Directional Only
SJD Series
TVS Diodes
Soldering Parameters
Reflow Soldering
Profile Feature
Pb-Free Assembly
Average ramp-up rate (TL to TP)
3℃/second max.
Preheat
-Temperature Min (TS min)
-Temperature Max (TS max)
-Time (min to max) ( tS)
150℃
200℃
60-180 seconds
TS max to TL
-Ramp-up Rate
3℃/second max.
Time maintained above:
-Temperature (TL)
-Time (tL)
217℃
60-150 seconds
Peak Temperature (TP)
260℃
Time within 5℃ of actual Peak Temperature (tP)
Ramp-down Rate
Time 25℃ to Peak Temperature
20-40 seconds
6℃/second max.
8 minutes max.
SJD Series
TVS Diodes
Marking Code
Bidirectional
Unidirectional
Dimensions (SOD-123FL)
Symbol
Cathode Band
E
1.00
Max.
Min.
Max.
A
3.50
3.90
0.138
0.154
B
2.60
3.00
0.102
0.118
C
0.75
1.10
0.030
0.043
D
1.60
2.00
0.063
0.079
E
h
Inches
Min.
(for uni-directional products only)
B
A
Millimeters
0.80Typ.
0.031Typ.
2.00
Recommended Soldering Pad Layout
H
0.90
1.35
0.035
0.053
h
0.12
0.22
0.005
0.009
SJD Series
Packaging Specification
Tape
For Uni-Devices
7 Inches Reel
Quantity:3000pcs/reel
TVS Diodes
很抱歉,暂时无法提供与“SJD12C100L01”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.12090
- 10+0.11160
- 30+0.10974
- 100+0.10416
- 国内价格
- 20+0.25753
- 200+0.20983
- 600+0.18334
- 3000+0.16221
- 9000+0.14847
- 21000+0.14098
