SJD12C90L01
SJD12C90L01
    LIOWN(里阳)
    SOD-123FL
    双向 90V 1.4A
SJD12C90L01 数据手册
SJD Series TVS Diodes Description The SJD series is designed specifically to protect sensitive electronic equipment from voltage transients induced by lightning and other transient voltage events. SJD12 package is 50% smaller in footprint when compare to SMA package and deliverying one of the low height profiles (1.2mm) in the industry. Features       IEC-61000-4-2 ESD 15kV(Air), 8kV (Contact) SOD-123FL surface mount package Protects one I/O line Peak power dissipation of 1000W under 8/20μs waveform Low leakage current Solid-state silicon avalanche technology    RoHS compliant Solder reflow temperature: Pure Tin-Sn, 260~270℃ Flammability rating UL 94V-0  Meet MSL level1, per J-STD-020 Applications SJD12 devices are ideal for the protection of I/O interfaces, VCC bus and other vulnerable circuit used in cellular phones, portable devices, business machines, power supplies and other consumer applications. Maximum Ratings and Characteristics (TA=25℃) Rating Symbol Value Peak pulse power dissipation at 10/1000μs waveform (Note1, Note2, Fig.1) PPPM 200W Peak pulse power (tp=8/20μs waveform) PPPM 1000W Peak pulse current of at 10/1000μs waveform (Note 1, Fig.3) IPPM See Table(A) PM(AV) 1.0W VF 3.5V IFSM 20A TJ,TSTG -55℃ to +150℃ Typical thermal resistance junction to lead RθJL 100℃/W Typical thermal resistance junction to ambient RθJA 220℃/W Steady state power dissipation at TL=75℃ (Fig.5) Maximum Instantaneous Forward Voltage at 12A for Unidirectional Only Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load, (JEDEC Method) (Note3, Fig.6) Operating junction and Storage Temperature Ranges Notes:1. Non-repetitive current pulse, per Fig.3 and derating above TA=25℃ per Fig.2. 2. Each terminal is surface Mounted on the 5.0mm×5.0mm (0.03mm thick) copper pads. 3. 8.3ms single half sine-wave or equivalent square wave, duty cycle=4 pulses per minutes maximum. SJD Series TVS Diodes Electrical Characteristics (TA=25℃) Device Marking Code Part Number Reverse Stand-Off Voltage Breakdown Voltage @IT Test Current Maximum Clamping Voltage @IPP Peak Pulse Current Reverse Leakage @VR Uni. Bi. Uni. Bi. VR(V) VB MIn.(V) VB Max.(V) IT(mA) VC(V) IPP(A) IR(μA) SJD12A05L01 SJD12C05L01 KE AE 5 6.4 7 10 9.2 21.8 500 SJD12A06L01 SJD12C06L01 KG AG 6 6.67 7.37 10 10.3 19.4 400 SJD12A6.5L01 SJD12C6.5L01 KK AK 6.5 7.22 7.98 10 11.2 17.9 350 SJD12A07L01 SJD12C07L01 KM AM 7 7.78 8.6 10 12.0 16.7 200 SJD12A7.5L01 SJD12C7.5L01 KP AP 7.5 8.33 9.21 1 12.9 15.5 100 SJD12A08L01 SJD12C08L01 KR AR 8 8.89 9.83 1 13.6 14.7 50 SJD12A8.5L01 SJD12C8.5L01 KT AT 8.5 9.44 10.4 1 14.4 13.9 20 SJD12A09L01 SJD12C09L01 KV AV 9 10 11.1 1 15.4 13.0 10 SJD12A10L01 SJD12C10L01 KX AX 10 11.1 12.3 1 17.0 11.8 5 SJD12A11L01 SJD12C11L01 KZ AZ 11 12.2 13.5 1 18.2 11.0 3 SJD12A12L01 SJD12C12L01 LE BE 12 13.3 14.7 1 19.9 10.1 1 SJD12A13L01 SJD12C13L01 LG BG 13 14.4 15.9 1 21.5 9.3 1 SJD12A14L01 SJD12C14L01 LK BK 14 15.6 17.2 1 23.2 8.6 1 SJD12A15L01 SJD12C15L01 LM BM 15 16.7 18.5 1 24.4 8.2 1 SJD12A16L01 SJD12C16L01 LP BP 16 17.8 19.7 1 26.0 7.7 1 SJD12A17L01 SJD12C17L01 LR BR 17 18.9 20.9 1 27.6 7.3 1 SJD12A18L01 SJD12C18L01 LT BT 18 20 22.1 1 29.2 6.9 1 SJD12A20L01 SJD12C20L01 LV BV 20 22.2 24.5 1 32.4 6.2 1 SJD12A22L01 SJD12C22L01 LX BX 22 24.4 26.9 1 35.5 5.7 1 SJD12A24L01 SJD12C24L01 LZ BZ 24 26.7 29.5 1 38.9 5.2 1 SJD12A26L01 SJD12C26L01 ME CE 26 28.9 31.9 1 42.1 4.8 1 SJD12A28L01 SJD12C28L01 MG CG 28 31.1 34.4 1 45.4 4.4 1 SJD12A30L01 SJD12C30L01 MK CK 30 33.3 36.8 1 48.4 4.2 1 SJD12A33L01 SJD12C33L01 MM CM 33 36.7 40.6 1 53.3 3.8 1 SJD12A36L01 SJD12C36L01 MP CP 36 40 44.2 1 58.1 3.5 1 SJD Series TVS Diodes Electrical Characteristics (TA=25℃) Device Marking Code Part Number Reverse Stand-Off Voltage Breakdown Voltage @IT Test Current Maximum Clamping Voltage @IPP Peak Pulse Current Reverse Leakage @VR Uni. Bi. Uni. Bi. VR(V) VB MIn.(V) VB Max.(V) IT(mA) VC(V) IPP(A) IR(μA) SJD12A40L01 SJD12C40L01 MR CR 40 44.4 49.1 1 64.5 3.1 1 SJD12A43L01 SJD12C43L01 MT CT 43 47.8 52.8 1 69.4 2.9 1 SJD12A45L01 SJD12C45L01 MV CV 45 50 55.3 1 72.7 2.8 1 SJD12A48L01 SJD12C48L01 MX CX 48 53.3 58.9 1 77.4 2.6 1 SJD12A51L01 SJD12C51L01 MZ CZ 51 56.7 62.7 1 82.4 2.5 1 SJD12A54L01 SJD12C54L01 NE DE 54 60 66.3 1 87.1 2.3 1 SJD12A58L01 SJD12C58L01 NG DG 58 64.4 71.2 1 93.6 2.2 1 SJD12A60L01 SJD12C60L01 NK DK 60 66.7 73.7 1 96.8 2.1 1 SJD12A64L01 SJD12C64L01 NM DM 64 71.1 78.6 1 103.0 2.0 1 SJD12A70L01 SJD12C70L01 NP DP 70 77.8 86 1 113.0 1.8 1 SJD12A75L01 SJD12C75L01 NR DR 75 83.3 92.1 1 121.0 1.7 1 SJD12A78L01 SJD12C78L01 NT DT 78 86.7 95.8 1 126.0 1.6 1 SJD12A85L01 SJD12C85L01 NV DV 85 94.4 104 1 137.0 1.5 1 SJD12A90L01 SJD12C90L01 NX DX 90 100 111 1 146.0 1.4 1 SJD12A100L01 SJD12C100L01 NZ DZ 100 111 123 1 162.0 1.3 1 SJD12A110L01 SJD12C110L01 PE EE 110 122 135 1 177.0 1.2 1 SJD12A120L01 SJD12C120L01 PG EG 120 133 147 1 193.0 1.1 1 SJD12A130L01 SJD12C130L01 PK EK 130 144 159 1 209.0 1.0 1 SJD12A150L01 SJD12C150L01 PM EM 150 167 185 1 243.0 0.8 1 SJD12A160L01 SJD12C160L01 PP EP 160 178 197 1 259.0 0.8 1 SJD12A170L01 SJD12C170L01 PR ER 170 189 209 1 275.0 0.8 1 SJD Series TVS Diodes Ratings and Characteristic Curves (TA=25℃) Figure 1. Peak Pulse Power Rating Curve Figure 2. Pulse Derating Curve Figure 3. Pulse Waveform Figure 4. Typical Junction Capacitance 150 tr=10µs 1000 Peak Value IPPM Uni-directional V=0V Cj (pF) 100 Half Value IPPM (IPPM/2) 50 0 10000 TJ=25℃ Pulse Width(td) is defined as the point where the peak current decays to 50% of IPPM 10/1000µs Waveform as defined by R.E.A 1 1.0 2.0 3.0 Bi-directional V=0V 10 td 0 100 4.0 Time (ms) Figure 5. Steady State Power Dissipation Derating Curve TJ=25℃ f=1.0MHz Vsig=50mVp-p 1 10 100 VBR-Reverse Breakdown Voltage (V) 1000 Figure 6. Maximum Non-Repetitive Forward Surge Current Uni-Directional Only SJD Series TVS Diodes Soldering Parameters Reflow Soldering Profile Feature Pb-Free Assembly Average ramp-up rate (TL to TP) 3℃/second max. Preheat -Temperature Min (TS min) -Temperature Max (TS max) -Time (min to max) ( tS) 150℃ 200℃ 60-180 seconds TS max to TL -Ramp-up Rate 3℃/second max. Time maintained above: -Temperature (TL) -Time (tL) 217℃ 60-150 seconds Peak Temperature (TP) 260℃ Time within 5℃ of actual Peak Temperature (tP) Ramp-down Rate Time 25℃ to Peak Temperature 20-40 seconds 6℃/second max. 8 minutes max. SJD Series TVS Diodes Marking Code Bidirectional Unidirectional Dimensions (SOD-123FL) Symbol Cathode Band E 1.00 Max. Min. Max. A 3.50 3.90 0.138 0.154 B 2.60 3.00 0.102 0.118 C 0.75 1.10 0.030 0.043 D 1.60 2.00 0.063 0.079 E h Inches Min. (for uni-directional products only) B A Millimeters 0.80Typ. 0.031Typ. 2.00 Recommended Soldering Pad Layout H 0.90 1.35 0.035 0.053 h 0.12 0.22 0.005 0.009 SJD Series Packaging Specification Tape For Uni-Devices 7 Inches Reel Quantity:3000pcs/reel TVS Diodes
SJD12C90L01 价格&库存
很抱歉,暂时无法提供与“SJD12C90L01”相匹配的价格&库存,您可以联系我们找货
