TVS Diodes
P6KE Series
Description
The P6KE series is designed specifically to protect sensitive electronic equipment from voltage transients induced
by lightning and other transient voltage events.
Features
Halogen free and RoHS compliant
Low incremental surge resistance
Excellent clamping capability
600W peak pulse power capability at 10/1000μs waveform,
repetition rate (duty cycle): 0.01%
Fast response time
Typical IR less than 1μA above 12V devices
High Temperature soldering guaranteed: 265℃/10 seconds/.375″,
(9.5mm) lead length, 5lbs (2.3kg) tension
Plastic package has underwriters laboratory flammability 94V-0
Meet MSL level1, per J-STD-020
IEC-61000-4-2 ESD 30kV(Air), 30kV (Contact)
Unit Weight: 0.42g
Applications
TVS components are ideal for the protection of I/O Interfaces, VCC bus and other vulnerable circuits used in telecom,
computer, Industrial and consumer electronic applications.
Maximum Ratings and Characteristics (TA=25℃)
Rating
Symbol
Value
Peak pulse power dissipation at 10/1000μs waveform
(Note1, Fig.1)
PPPM
600W
Peak pulse current of at 10/1000μs waveform (Note 1, Fig.3)
IPPM
See Table(A)
PM(AV)
5.0W
Maximum Instantaneous Forward Voltage at 50A for Unidirectional Only
VF
3.5V/5.0V
Peak forward surge current, 8.3ms single half sine-wave superimposed on
rated load, (JEDEC Method) (Note2, Fig.6)
IFSM
100A
TJ,TSTG
-55℃ to +150℃
Typical thermal resistance junction to lead
RθJL
20℃/W
Typical thermal resistance junction to ambient
RθJA
75℃/W
Steady state power dissipation at TL=75℃ (Fig.5)
Operating junction and Storage Temperature Ranges
Notes:1. Non-repetitive current pulse, per Fig.3 and derating above TA=25℃ per Fig.2.
2. 8.3ms single half sine-wave or equivalent square wave, duty cycle=4 pulses per minutes maximum.
3. VF < 3.5V for single die parts and VF< 5.0V for stacked-die parts.
www.liownsemi.com
掌握芯技术Core Technology
(V3)
TVS Diodes
P6KE Series
Electrical Characteristics (TA=25℃)
Reverse
Stand-Off
Voltage
Part Number
Breakdown
Voltage
@IT
Test
Current
Maximum
Clamping
Voltage
@IPP
Peak
Pulse
Current
Reverse
Leakage
@VR
Uni.
Bi.
VR(V)
VB MIn.(V)
VB Max.(V)
IT(mA)
VC(V)
IPP(A)
IR(μA)
P6KE6.8A
P6KE6.8CA
5.80
6.45
7.14
10
10.5
58.1
1000
P6KE7.5A
P6KE7.5CA
6.40
7.13
7.88
10
11.3
54.0
500
P6KE8.2A
P6KE8.2CA
7.02
7.79
8.61
10
12.1
50.4
200
P6KE9.1A
P6KE9.1CA
7.78
8.65
9.55
1
13.4
45.5
50
P6KE10A
P6KE10CA
8.55
9.50
10.50
1
14.5
42.1
10
P6KE11A
P6KE11CA
9.40
10.50
11.60
1
15.6
39.1
5
P6KE12A
P6KE12CA
10.20
11.40
12.60
1
16.7
36.5
5
P6KE13A
P6KE13CA
11.10
12.40
13.70
1
18.2
33.5
1
P6KE15A
P6KE15CA
12.80
14.30
15.80
1
21.2
28.8
1
P6KE16A
P6KE16CA
13.60
15.20
16.80
1
22.5
27.1
1
P6KE18A
P6KE18CA
15.30
17.10
18.90
1
25.2
24.2
1
P6KE20A
P6KE20CA
17.10
19.00
21.00
1
27.7
22.0
1
P6KE22A
P6KE22CA
18.80
20.90
23.10
1
30.6
19.9
1
P6KE24A
P6KE24CA
20.50
22.80
25.20
1
33.2
18.4
1
P6KE27A
P6KE27CA
23.10
25.70
28.40
1
37.5
16.3
1
P6KE30A
P6KE30CA
25.60
28.50
31.50
1
41.4
14.7
1
P6KE33A
P6KE33CA
28.20
31.40
34.70
1
45.7
13.3
1
P6KE36A
P6KE36CA
30.80
34.20
37.80
1
49.9
12.2
1
P6KE39A
P6KE39CA
33.30
37.10
41.00
1
53.9
11.3
1
P6KE43A
P6KE43CA
36.80
40.90
45.20
1
59.3
10.3
1
P6KE47A
P6KE47CA
40.20
44.70
49.40
1
64.8
9.4
1
P6KE51A
P6KE51CA
43.60
48.50
53.60
1
70.1
8.7
1
P6KE56A
P6KE56CA
47.80
53.20
58.80
1
77.0
7.9
1
P6KE62A
P6KE62CA
53.00
58.90
65.10
1
85.0
7.2
1
P6KE68A
P6KE68CA
58.10
64.60
71.40
1
92.0
6.6
1
www.liownsemi.com
(V3)
TVS Diodes
P6KE Series
Reverse
Stand-Off
Voltage
Part Number
Breakdown
Voltage
@IT
Test
Current
Maximum
Clamping
Voltage
@IPP
Peak
Pulse
Current
Reverse
Leakage
@VR
Uni.
Bi.
VR(V)
VB MIn.(V)
VB Max.(V)
IT(mA)
VC(V)
IPP(A)
IR(μA)
P6KE75A
P6KE75CA
64.10
71.30
78.80
1
103.0
5.9
1
P6KE82A
P6KE82CA
70.10
77.90
86.10
1
113.0
5.4
1
P6KE91A
P6KE91CA
77.80
86.50
95.50
1
125.0
4.9
1
P6KE100A
P6KE100CA
85.50
95.00
105.0
1
137.0
4.5
1
P6KE110A
P6KE110CA
94.00
105.0
116.0
1
152.0
4.0
1
P6KE120A
P6KE120CA
102.0
114.0
126.0
1
165.0
3.7
1
P6KE130A
P6KE130CA
111.0
124.0
137.0
1
179.0
3.4
1
P6KE150A
P6KE150CA
128.0
143.0
158.0
1
207.0
2.9
1
P6KE160A
P6KE160CA
136.0
152.0
168.0
1
219.0
2.8
1
P6KE170A
P6KE170CA
145.0
162.0
179.0
1
234.0
2.6
1
P6KE180A
P6KE180CA
154.0
171.0
189.0
1
246.0
2.5
1
P6KE200A
P6KE200CA
171.0
190.0
210.0
1
274.0
2.2
1
P6KE220A
P6KE220CA
185.0
209.0
231.0
1
328.0
1.9
1
P6KE250A
P6KE250CA
214.0
237.0
263.0
1
344.0
1.8
1
P6KE300A
P6KE300CA
256.0
285.0
315.0
1
414.0
1.5
1
P6KE350A
P6KE350CA
300.0
332.0
368.0
1
482.0
1.3
1
P6KE400A
P6KE400CA
342.0
380.0
420.0
1
548.0
1.1
1
P6KE440A
P6KE440CA
376.0
418.0
462.0
1
602.0
1.0
1
P6KE480A
P6KE480CA
408.0
456.0
504.0
1
658.0
0.9
1
P6KE510A
P6KE510CA
434.0
485.0
535.0
1
698.0
0.9
1
P6KE530A
P6KE530CA
450.0
503.5
556.5
1
725.0
0.8
1
P6KE540A
P6KE540CA
459.0
513.0
567.0
1
740.0
0.8
1
P6KE550A
P6KE550CA
467.0
522.5
577.5
1
760.0
0.8
1
P6KE600A
P6KE600CA
510.0
575.2
628.4
1
828.0
0.75
1
www.liownsemi.com
(V3)
TVS Diodes
P6KE Series
Ratings and Characteristic Curves (TA=25℃)
Figure 1. Peak Pulse Power Rating Curve
Figure 2. Pulse Derating Curve
Figure 3. Pulse Waveform
Figure 4. Typical Junction Capacitance
150
tr=10µs
TJ=25℃
Pulse Width(td) is defined as
the point where the peak
current decays to 50% of IPPM
Peak Value IPPM
100
Half Value IPPM (IPPM/2)
50
10/1000µs Waveform
as defined by R.E.A
td
2.0
3.0
4.0
Time (ms)
Figure 5. Steady State Power Dissipation Derating
Curve
www.liownsemi.com
Figure 6. Maximum Non-Repetitive Forward Surge
Current Uni-Directional Only
(V3)
TVS Diodes
P6KE Series
Wave Soldering
300
Preheating
Maximum Wave 265℃
Soldering
Cooling
250
200
150
100
Peak Temperature: 265℃
Dipping Time: 10 seconds (max.)
Soldering: 1 time
50
1
1.5
2
2.5
3
3.5
4
Time (minutes)
Part Number Code and Marking Code
Dimensions (DO-204AC/DO-15)
Symbol
www.liownsemi.com
Millimeters
Inches
Min.
Max.
Min.
Max.
A
25.40
1.000
B
5.80
7.60
0.230
0.300
C
2.60
3.60
0.104
0.140
d
0.71
0.86
0.028
0.034
(V3)
TVS Diodes
P6KE Series
Packaging Specification
Tape
Box
Quantity: 2000pcs/box
Reel
Quantity:4000pcs/reel
www.liownsemi.com
(V3)
很抱歉,暂时无法提供与“P6KE7.5CA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.23400
- 10+0.21600
- 30+0.21240
- 100+0.20160
- 国内价格
- 10+0.46776
- 100+0.36977
- 300+0.32084
- 2000+0.28400
- 4000+0.25466
- 10000+0.23999
