TVS Diodes
5KP Series
Description
The 5KP series is designed specifically to protect sensitive electronic equipment from voltage transients induced
by lightning and other transient voltage events.
Features
Halogen free and RoHS compliant
Glass passivated junction
Low incremental surge resistance
Excellent clamping capability
5000W peak pulse power capability at 10/1000μs waveform,
repetition rate (duty cycle): 0.05%
Fast response time
Typical IR less than 2μA above 10V devices
High Temperature soldering guaranteed: 265℃/10 seconds/.375″,
(9.5mm) lead length, 5lbs (2.3kg) tension
Plastic package has underwriters laboratory flammability 94V-0
Meet MSL level1, per J-STD-020
IEC-61000-4-2 ESD 30kV(Air), 30kV (Contact)
Unit Weight: 2.1g
Applications
TVS components are ideal for the protection of I/O Interfaces, VCC bus and other vulnerable circuits used in telecom,
computer, Industrial and consumer electronic applications.
Maximum Ratings and Characteristics (TA=25℃)
Rating
Symbol
Value
Peak pulse power dissipation at 10/1000μs waveform
(Note1, Fig.1)
PPPM
5000W
Peak pulse current of at 10/1000μs waveform (Note 1, Fig.3)
IPPM
See Table(A)
PM(AV)
8.0W
IFSM
400A
TJ,TSTG
-55℃ to +150℃
Typical thermal resistance junction to lead
RθJL
8℃/W
Typical thermal resistance junction to ambient
RθJA
40℃/W
Steady state power dissipation at TL=75℃ (Fig.5)
Peak forward surge current, 8.3ms single half sine-wave superimposed on
rated load, (JEDEC Method) (Note2, Fig.6)
Operating junction and Storage Temperature Ranges
Notes:1. Non-repetitive current pulse, per Fig.3 and derating above TA=25℃ per Fig.2.
2. 8.3ms single half sine-wave or equivalent square wave, duty cycle=4 pulses per minutes maximum.
www.liownsemi.com
掌握芯技术Core Technology
(V3)
TVS Diodes
5KP Series
Electrical Characteristics (TA=25℃)
Reverse
Stand-Off
Voltage
Part Number
Breakdown
Voltage
@IT
Test
Current
Maximum
Clamping
Voltage
@IPP
Peak
Pulse
Current
Reverse
Leakage
@VR
Uni.
Bi.
VR(V)
VB MIn.(V)
VB Max.(V)
IT(mA)
VC(V)
IPP(A)
IR(μA)
5KP5.0A
5KP5.0CA
5.0
6.40
7.00
50
9.2
554.3
3000
5KP6.0A
5KP6.0CA
6.0
6.67
7.37
50
10.3
495.1
2000
5KP6.5A
5KP6.5CA
6.5
7.22
7.98
50
11.2
455.4
1000
5KP7.0A
5KP7.0CA
7.0
7.78
8.60
50
12.0
425.0
800
5KP7.5A
5KP7.5CA
7.5
8.33
9.21
5
12.9
395.3
250
5KP8.0A
5KP8.0CA
8.0
8.89
9.83
5
13.6
375.0
150
5KP8.5A
5KP8.5CA
8.5
9.44
10.40
5
14.4
354.2
50
5KP9.0A
5KP9.0CA
9.0
10.00
11.10
5
15.4
331.2
5KP10A
5KP10CA
10.0
11.10
12.30
5
17.0
300.0
10
5KP11A
5KP11CA
11.0
12.20
13.50
5
18.2
280.2
2
5KP12A
5KP12CA
12.0
13.30
14.70
5
19.9
256.3
2
5KP13A
5KP13CA
13.0
14.40
15.90
5
21.5
237.2
2
5KP14A
5KP14CA
14.0
15.60
17.20
5
23.2
219.8
2
5KP15A
5KP15CA
15.0
16.70
18.50
5
24.4
209.0
2
5KP16A
5KP16CA
16.0
17.80
19.70
5
26.0
196.2
2
5KP17A
5KP17CA
17.0
18.90
20.90
5
27.6
184.8
2
5KP18A
5KP18CA
18.0
20.00
22.10
5
29.2
174.7
2
5KP20A
5KP20CA
20.0
22.20
24.50
5
32.4
157.4
2
5KP22A
5KP22CA
22.0
24.40
26.90
5
35.5
143.7
2
5KP24A
5KP24CA
24.0
26.70
29.50
5
38.9
131.1
2
5KP26A
5KP26CA
26.0
28.90
28.90
5
42.1
121.1
2
5KP28A
5KP28CA
28.0
31.10
34.40
5
45.4
112.3
2
5KP30A
5KP30CA
30.0
33.30
36.80
5
48.4
105.4
2
5KP33A
5KP33CA
33.0
36.70
40.60
5
53.3
95.7
2
5KP36A
5KP36CA
36.0
40.00
44.20
5
58.1
87.8
2
5KP40A
5KP40CA
40.0
44.40
49.10
5
64.5
79.1
2
www.liownsemi.com
(V3)
TVS Diodes
5KP Series
Reverse
Stand-Off
Voltage
Part Number
Breakdown
Voltage
@IT
Test
Current
Maximum
Clamping
Voltage
@IPP
Peak
Pulse
Current
Reverse
Leakage
@VR
Uni.
Bi.
VR(V)
VB MIn.(V)
VB Max.(V)
IT(mA)
VC(V)
IPP(A)
IR(μA)
5KP43A
5KP43CA
43.0
47.80
52.80
5
69.4
73.5
2
5KP45A
5KP45CA
45.0
50.00
55.30
5
72.7
70.2
2
5KP48A
5KP48CA
48.0
53.30
58.90
5
77.4
65.9
2
5KP51A
5KP51CA
51.0
56.70
62.70
5
82.4
61.9
2
5KP54A
5KP54CA
54.0
60.00
66.30
5
87.1
58.6
2
5KP58A
5KP58CA
58.0
64.40
71.20
5
93.6
54.5
2
5KP60A
5KP60CA
60.0
66.70
73.70
5
96.8
52.7
2
5KP64A
5KP64CA
64.0
71.10
78.60
5
103.0
49.5
2
5KP70A
5KP70CA
70.0
77.80
86.00
5
113.0
45.1
2
5KP75A
5KP75CA
75.0
83.30
92.10
5
121.0
42.1
2
5KP78A
5KP78CA
78.0
86.70
95.80
5
126.0
40.5
2
5KP85A
5KP85CA
85.0
94.40
104.0
5
137.0
37.2
2
5KP90A
5KP90CA
90.0
100.0
111.0
5
146.0
34.9
2
5KP100A
5KP100CA
100.0
110.0
123.0
5
162.0
31.5
2
5KP110A
5KP110CA
110.0
122.0
135.0
5
177.0
28.8
2
5KP120A
5KP120CA
120.0
133.0
147.0
5
193.0
26.4
2
5KP130A
5KP130CA
130.0
144.0
159.0
5
209.0
24.4
2
5KP150A
5KP150CA
150.0
167.0
185.0
5
243.0
21.0
2
5KP160A
5KP160CA
160.0
178.0
197.0
5
259.0
19.7
2
5KP170A
5KP170CA
170.0
189.0
209.0
5
275.0
18.5
2
5KP180A
5KP180CA
180.0
201.0
222.0
5
292.0
17.5
2
5KP190A
5KP190CA
190.0
211.0
233.0
5
310.0
16.5
2
5KP200A
5KP200CA
200.0
224.0
247.0
5
329.2
15.5
2
5KP210A
5KP210CA
210.0
237.0
263.0
5
349.5
14.6
2
5KP220A
5KP220CA
220.0
246.0
272.0
5
371.1
13.7
2
5KP250A
5KP250CA
250.0
277.0
306.0
5
425.0
12.0
2
www.liownsemi.com
(V3)
TVS Diodes
5KP Series
Ratings and Characteristic Curves (TA=25℃)
Figure 2. Pulse Derating Curve
Figure 1. Peak Pulse Power Rating Curve
1000
100
10
1
1
10
100
td-Pulse Width (µs)
1000
Figure 3. Pulse Waveform
150
Figure 4. Typical Junction Capacitance
tr=10µs
TJ=25℃
Pulse Width(td) is defined as
the point where the peak
current decays to 50% of IPPM
Peak Value IPPM
100
Half Value IPPM (IPPM/2)
50
10/1000µs Waveform
as defined by R.E.A
td
2.0
3.0
4.0
Time (ms)
Figure 5. Steady State Power Dissipation Derating
Curve
www.liownsemi.com
Figure 6. Maximum Non-Repetitive Forward Surge
Current Uni-Directional Only
(V3)
TVS Diodes
5KP Series
Wave Soldering
300
Preheating
Maximum Wave 265℃
Soldering
Cooling
250
200
150
100
Peak Temperature: 265℃
Dipping Time: 10 seconds (max.)
Soldering: 1 time
50
1
1.5
2
2.5
3
3.5
4
Time (minutes)
Part Number Code and Marking Code
Dimensions (P600)
Symbol
www.liownsemi.com
Millimeters
Inches
Min.
Max.
Min.
Max.
A
25.40
1.000
B
8.60
9.10
0.340
0.360
C
8.60
9.10
0.340
0.360
d
1.19
1.35
0.047
0.053
(V3)
TVS Diodes
5KP Series
Packaging Specification
Tape
Quantity: 800pcs/reel
Box
Quantity:300pcs/box
www.liownsemi.com
(V3)
很抱歉,暂时无法提供与“5KP6.5CA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.95000
- 10+1.80000
- 30+1.77000
- 100+1.68000
- 国内价格
- 1+4.49388
- 10+3.64230
- 30+3.21138
- 300+2.77020
- 600+2.51370
- 900+2.38032
