SZF-41T-P0.7
SZF-41T-P0.7
    JST
    是可靠、插拔顺畅的线对线连接器
SZF-41T-P0.7 数据手册
ZL CONNECTOR 5.0mm pitch/Disconnectable Crimp style Wire-to-wire connectors Specifications ––––––––––––––––––– • Current rating: 10A AC, DC max. • Voltage rating: 300V AC, DC max. • Temperature range: -25˚C to +90˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/7m Ω max. After environmental testing/10m Ω max. • Insulation resistance: 1,000M Ω min. • Withstanding voltage: 1,500V AC/minute • Applicable wire: AWG #26 to #16 0.13 to 1.25mm2 • Applicable panel thickness: 0.7 to 2.4mm * Compliant with RoHS. * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. Retainer Housing lance Box-shaped contact Note: The current rating varies depending on the number of circuits and the wire size used in each connector. The table below lists the current rating as a function of the number of circuits and wire size. Current unit: A Wire size (AWG) Circuits #16 ZL connectors are reliable, smoothly mating wire-to-wire connectors. • Housing lances • Retainer • Box-shaped contacts • Mountable on a variety of panels #24 #26 2 10 #18 6 #20 5 #22 4 3 2 4 9 5 4 3 3 2 6 8 4 3 3 2 2 8 6 4 3 3 2 2 12 6 4 3 3 2 2 16 5 3 2 2 1 1 Standards –––––––––––––––––––––– 0 Recognized E60389 1 Certified LR20812 Panel layout and Assembly layout Circuits Dimensions A (mm) 2・ 4 18.2 6・8・12・16 17.5 A (41.8)(including retainer) (38.2) Shape I Shape II E B Circuits B 2 D C D C 7.8 4 6 8 2.7 12 A A 16 Receptacle housing Panel Panel hole dimensions (mm) General tolerance ±0.13 Applicable panel hole thickness (mm) A B C D E shape ZLR-02V ZLR-04V ZLR-06V ZLR-08V ZLR-12V ZLR-16V 1 11.5 4.4 13.95 13.2 6.5 1 16.5 5.2 13.95 13.2 11.6 2 21.5 5.2 13.95 13.2 − 2 26.5 5.2 13.95 13.2 − 2 36.5 5.2 13.95 13.2 − 2 46.5 5.2 13.95 13.2 − 0.7∼2.4 Note: 1. Punch holes in the panel according to the figures and table shown above. Burrs must be removed. 2. The strength of the panel must be considered when punching two or more holes. 3. The connector must be inserted from the same side as the hole is punched. 1 ZL CONNECTOR Contact Applicable wire Model No. Pin contact Socket contact SZM-01T-P0.7 SZF-01T-P0.7 SZM-41T-P0.7 SZF-41T-P0.7 1.85 Pin contact mm2 22.5 4.0 2.5 AWG # Insulation O.D. Q´ty / reel (mm) 0.13∼0.5 26∼ 20 1.3∼2.7 0.75∼1.25 18∼16 1.9∼3.1 0.3+0.3∼ 0.5+0.5 22+22∼ 20+20 1.7+1.7∼ 2.0+2.0 3,000 Material and Finish Phosphor bronze, tin-plated (reflow treatment) RoHS compliance Note: 1. Contact JST for special products. 2. Contact JST for brass products. 3.2 Socket contact 4.5 2.5 SZM-01T-P0.7 4.0 Applicator Crimping machine Crimp applicator Contact 14.3 SZF-01T-P0.7 SZM-41T-P0.7 MKS-L Dies − AP-K2N − − MKS-L SZF -41T-P0.7 Crimp applicator with dies MK/SZF/M-01-07 APLMK SZF/M01-07 MK/SZF/M-41-07 APLMK SZF/M41-07 − − − Contact position location numbers Contact position numbers are stamped Retainer Retainer Receptacle housing Plug housing 6 3 5 4 2 3 6 2 5 1 4 16 6 8 1 3 1 2 4 1 3 JST JST 1 JST 2 4 1 5 1 2 2 JST 2 3 6 3 5 2 4 1 1 3 6 JST 4 1 2 JST 2 1 4 2 3 1 4 Plug housing 2 Receptacle housing 7 13 6 12 5 4 9 2 1 3 10 1 11 2 8 1 2 2 3 10 5 4 3 7 6 3 2 12 11 10 9 8 7 1 JST 1 4 8 7 6 5 6 5 4 3 2 1 JST 5 4 3 2 1 JST 6 JST JST 5 7 1 9 2 JST 7 12 3 13 4 14 5 15 6 9 2 10 3 6 11 4 7 4 3 2 1 6 5 4 3 2 1 8 7 6 5 4 3 2 1 4 8 12 8 8 7 6 5 12 11 10 9 8 7 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 16 15 14 13 12 11 10 9 ZL CONNECTOR Contact Material: Housing...PA 6, UL94V-0, white Retainer...Glass-filled PA 66, UL94V-0, ivory Circuits Voltage rating Current rating Receptacle housing(for pin contact) Q'ty / bag 500 12.9 12.4 18.2 500 8.2 21.0 10.45 29.7 Q'ty / bag ZLS-02V (Used with both housings with 2 and 4 circuits) 9.4 10A 6.2 300V Retainer Q'ty / bag ZLP-02V 16.2 ZLR-02V 2 Plug housing(for socket contact) Q'ty / bag 500 Q'ty / bag Q'ty / bag ZLP-06V 8A 500 12.9 Q'ty / bag 12.9 8.8 21.0 Q'ty / bag ZLP-08V 500 29.7 3.3 Q'ty / bag ZLS-08V 21.2 6A 8.2 31.2 300V 21.2 ZLR-08V 1,000 500 12.4 17.5 21.2 29.7 8 Q'ty / bag ZLS-03V 16.2 26.2 16.2 300V 21.0 12.9 ZLR-06V 6 8.8 500 8.2 12.4 18.2 29.7 1,000 6.4 16.2 9A Q'ty / bag 11.7 300V ZLP-04V 21.2 4 11.2 ZLR-04V 1,000 500 12.4 17.5 8.2 3.3 8.8 21.0 RoHS compliance 3 ZL CONNECTOR Contact Material: Housing...PA 6, UL94V-0, white Retainer...Glass-filled PA 66, UL94V-0, ivory Receptacle housing(for pin contact) Q'ty / bag 6A 200 3.3 Q'ty / bag ZLP-16V 51.2 5A 8.2 21.0 12.9 Q'ty / bag ZLS-16V 200 200 29.7 8.8 41.2 Q'ty / bag 41.2 300V 1,000 12.9 ZLR-16V 16 Q'ty / bag ZLS-12V 200 12.4 17.5 29.7 Retainer Q'ty / bag ZLP-12V 41.2 300V 31.2 ZLR-12V 12 Plug housing(for socket contact) 31.2 Current rating 41.2 Voltage rating 31.2 Circuits 12.4 17.5 8.2 21.0 1,000 3.3 8.8 RoHS compliance Note: 1. ZL connectors with any number of circuits can be used either panel mounted or free hanging. See "Panel layout" for the panel dimensions. 2. Contact JST for special products. 4
SZF-41T-P0.7 价格&库存
很抱歉,暂时无法提供与“SZF-41T-P0.7”相匹配的价格&库存,您可以联系我们找货
SZF-41T-P0.7
    • 3000+0.381963000+0.04956
    SZF-41T-P0.7
      库存:12000
      SZF-41T-P0.7
        库存:36000
        SZF-41T-P0.7
        • 10+0.30500
        • 100+0.23825
        • 300+0.20488
        库存:1264
        SZF-41T-P0.7
          库存:23095
          SZF-41T-P0.7
            • 1+0.566101+0.07345
            • 10+0.4528810+0.05876
            • 50+0.3832050+0.04972
            • 100+0.32224100+0.04181
            • 500+0.29611500+0.03842
            • 1000+0.287401000+0.03729
            • 2000+0.278702000+0.03616
            库存:2250
            SZF-41T-P0.7
              库存:87
              SZF-41T-P0.7
                • 3000+0.12300
                库存:27000
                SZF-41T-P0.7
                  库存:126000
