STB60100C
STB60100C
    SMCDIODESOLUTIONS(桑德斯)
    D²PAK
STB60100C 数据手册
ST60100C STB60100C STF60100C Technical Data Data Sheet N1505, Rev. A ST60100C/STB60100C/STF60100C SCHOTTKY RECTIFIER Applications     Features    Switching power supply Converters Free-Wheeling diodes Reverse battery protection       150 C TJ operation Ultralow forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability Trench MOS Schottky technology This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request ST60100C STB60100C STF60100C TO-220AB D2PAK ITO-220AB Maximum Ratings: Characteristics Symbol Condition Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage VRRM VRWM VR - Average Rectified Forward Current IF (AV) Peak One Cycle Non-Repetitive Surge Current(Per Leg) 50% duty cycle @Tc=105°C, rectangular wave form IFSM 8.3ms, Half Sine pulse Max. Units 100 V 30(Per Leg) 60(Per Device) A 300 A  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  ST60100C STB60100C STF60100C Technical Data Data Sheet N1505, Rev. A Electrical Characteristics: Characteristics Symbol Forward Voltage Drop(Per Leg)* VF1 VF2 Reverse Current(Per Leg)* IR1 IR2 Junction Capacitance(Per Leg) CT * Pulse width < 300 µs, duty cycle < 2% Condition @ 5A, Pulse, TJ = 25 C @ 10A, Pulse, TJ = 25 C @ 15A, Pulse, TJ = 25 C @ 20A, Pulse, TJ = 25 C @ 30A, Pulse, TJ = 25 C @ 5A, Pulse, TJ = 125 C @ 10A, Pulse, TJ = 125 C @ 15A, Pulse, TJ = 125 C @ 20A, Pulse, TJ = 125 C @ 30A, Pulse, TJ = 125 C @VR = 70V,TJ = 25 C @VR = 100V,TJ = 25 C @VR = 70V,TJ = 125 C @VR = 100V,TJ = 125 C @VR = 5V, TC = 25 C fSIG = 1MHz Typ. Max. Units 0.47 0.54 0.61 0.68 0.82 0.38 0.51 0.58 0.64 0.74 0.68 0.90 V 0.65 0.80 V 0.012 0.030 10 15 1 75 845 - mA mA pF Thermal-Mechanical Specifications: Characteristics Symbol Junction Temperature ST60100C STB60100C STF60100C Units TJ -55 to +150 C Storage Temperature Tstg -55 to +150 C Typical Thermal Resistance Junction to Case(Per Leg) RJC Tube Specification 2.8 2.8 5 C/W Tube Specification(TO-220AB/ITO-220AB) Device Package Weight Shipping ST60100C TO-220AB 2.0 50pcs / tube STB60100C D²PAK 1.85 800pcs / reel STF60100C ITO-220AB 2.0 50pcs / tube For information on tape and reel specifications, including part orientation and tape sizes, please refer to our tape and reel packaging specification.  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  ST60100C STB60100C STF60100C Technical Data Data Sheet N1505, Rev. A Ratings and Characteristics Curves  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  ST60100C STB60100C STF60100C Technical Data Data Sheet N1505, Rev. A Marking Diagram Where XXXXX is YYWWL ST B/F 60 100 C SSG YY WW L = Device Type = Package type = Forward Current (60A) = Reverse Voltage (100V) = Configuration = SSG = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 Carrier Tape Specification D2PAK SYMBOL Millimeters Min. Max. A 10.70 10.90 B 16.03 16.23 C 5.11 5.31 d 1.45 1.65 E 1.65 1.85 F 11.40 11.60 P0 3.90 4.10 P 15.90 16.10 P1 1.90 2.10 W 23.90 24.30  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  ST60100C STB60100C STF60100C Technical Data Data Sheet N1505, Rev. A Mechanical Dimensions TO-220AB Symbol A A1 A2 b b1 c D D1 E e e1 H1 L L1 ΦP Q Θ1 Θ2 Θ3 Dimensions in millimeters Min Typical Max 4.42 4.57 4.72 1.17 1.27 1.37 2.52 2.69 2.89 0.71 0.81 0.96 1.17 1.27 1.37 0.31 0.38 0.61 14.94 15.24 15.54 8.85 9.00 9.15 10.01 10.16 10.31 2.54 4.98 5.06 5.18 6.04 6.24 6.44 12.7 13.56 13.80 3.56 3.5 3.96 3.74 3.84 4.04 2.54 2.74 2.94 7° 3° 4° Mechanical Dimensions D2PAK Symbol A A1 A2 b b1 c c1 D D1 E E1 E2 e H L L1 L2 L3 e e1 e2 e3 Dimensions in millimeters Min. 4.55 0 2.59 0.71 0.36 1.17 8.55 6.40 10.01 7.6 9.98 14.6 2.00 1.17 0  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  Typical 4.70 0.10 2.69 0.81 1.27 0.38 1.27 8.70 Max. 4.85 0.25 2.89 0.96 10.16 10.31 10.08 2.54 15.1 2.30 1.27 10.18 0.25BSC 5° 4° 4° 0.61 1.37 8.85 15.6 2.70 1.40 2.20 8° ST60100C STB60100C STF60100C Technical Data Data Sheet N1505, Rev. A Mechanical Dimensions ITO-220AB A A1 A2 A3 b b1 b2 b3 b4 c D E e e1 H1 L L1 L2 L3 ΦP1(上口) ΦP2(下口) Q Θ1 Θ2 Θ3 Θ4 Dimensions in millimeters Min. Typical Max. 4.30 4.50 4.70 1.10 1.30 1.50 2.80 3.00 3.20 2.50 2.70 2.90 0.50 0.60 0.75 1.10 1.20 1.35 1.50 1.60 1.75 1.20 1.30 1.45 1.60 1.70 1.85 0.50 0.60 0.75 14.80 15.00 15.20 9.96 10.16 10.36 2.55 5.10 6.50 6.70 6.90 12.70 13.20 13.70 1.60 1.80 2.00 0.80 1.00 1.20 0.60 0.80 1.00 3.30 3.50 3.70 2.99 3.19 3.39 2.50 2.70 2.90 5° 4° 10° 5° Θ5 5° Symbol  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  ST60100C STB60100C STF60100C Technical Data Data Sheet N1505, Rev. A DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC - Sangdest Microelectronics (Nanjing) Co., Ltd sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC - Sangdest Microelectronics (Nanjing) Co., Ltd assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations..  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com 
STB60100C 价格&库存
很抱歉,暂时无法提供与“STB60100C”相匹配的价格&库存,您可以联系我们找货
