TS5204CQ33 RFG
TS5204CQ33 RFG
    TAIWANSEMICONDUCTOR(台湾半导体)
    VDFN6_EP
    TS5204CQ33 RFG
TS5204CQ33 RFG 数据手册
TS5204 Taiwan Semiconductor 80mA Low Noise Ultra Low Dropout Voltage Regulator DESCRIPTION FEATURES The TS5204 series is an efficient linear voltage regulator with ultra-low noise output, very low dropout voltage (typically 20mV at light loads and 300mV at 80mA), and very low power consumption (500µA at 50mA), providing high output current even when the application requires very low dropout voltage. The TS5204 series is included a precision voltage reference, error correction circuit, a current limited output driver, over temperature shutdown and revered battery protection. ● Ultra-Low Noise Output ● Output Current up to 80mA ● Low Dropout Voltage ● Low Power Consumption ● ● ● Internal Current Limit Thermal Shutdown Protection Compliant to RoHS Directive 2011/65/EU and in accordance to WEEE 2002/96/EC. Halogen-free according to IEC 61249-2-21 ● APPLICATION SOT-23 Pin Definition: 1. Output 2. Input 3. Ground ● Cellular Telephones ● Palmtops, Notebook Computers ● Battery Powered Equipment ● Consumer and Personal Electronics ● SMPS Post Regulator and DC to DC Modules ● High-efficiency Linear Power Supplies ● Portable Application Pin Definition: 1. Output 2. Ground 3. Input SOT-89 DFN2x2 Pin Definition: 1. Output 2. N/C 3. Ground 4. N/C 5. N/C 6. Output TYPICAL APPLICATION CIRCUIT 1 Version: L1609 TS5204 Taiwan Semiconductor ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) (Note 1) PARAMETER SYMBOL LIMIT UNIT Input Supply Voltage VIN -20~ +20 V Recommend Operating Input Voltage VIN +2.5 ~ +16 V PD Internal limited Io 80 Power Dissipation (Note 2) Output Current SOT-23 Junction to Ambient Thermal Resistance mA 220 SOT-89 180 RӨJA DFN2x2 °C/W 80 Operating Junction Temperature Range Storage Temperature Range TJ -40 ~ +150 °C TSTG -65 ~ +150 °C Notes: 1. Exceeding the absolute maximum rating may damage the device. 2. The maximum allowable power dissipation at any TA is PD(MAX) = [TJ(MAX) - Ta] + RӨJA. Exceeding the maximum allowable power dissipation will result in excessive die temperature, and the regulator will go into thermal shutdown. 3. The device is not guaranteed to function outside its operating rating. ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS Output Voltage Output Voltage Temp. Coefficient MIN VIN=VO + 1V 0.97|Vo| VIN=VO + 1V, IO= 80mA 0.96|Vo| (Note 3) TYP VOUT MAX 1.03|Vo| 1.04|Vo| UNIT V -- 50 -- ppm/°C VO+1V ≤ VIN ≤ 16V -- 0.1 0.5 % 0.1mA ≤ IO ≤ 80mA -- 1 2 % IO=100μA -- 20 -- IO=50mA -- 250 400 IO=80mA -- 300 600 IO=100μA -- 180 -- IO=50mA -- 850 1250 IO=80mA -- 2600 3100 Output Current Limit VOUT=0V -- 180 -- mA Power Supply Rejection Ratio At f=100Hz, IO=100μA, -- 65 -- dB -- 0.05 -- %/W -- 260 -- nV√Hz Line Regulation Load Regulation (Note 4) Dropout Voltage (Note 6) Ground Pin Current Thermal Regulation Output Noise (Note 7) (Note 8) IO=50mA, COUT =2.2μF, mV μA Note: 4. Output voltage temperature coefficient is defined as the worst case voltage change divided by the total temperature range. 5. Regulation is measured at constant junction temperature using low duty cycle pulse testing. Parts are tested for load regulation in the load range from 1mA to 80mA. Changes in output voltage due to heating effects are covered by the thermal regulation specification. 6. Dropout voltage is defined as the input to output differential at which the output voltage drops 2% below its nominal value measured at 1V differential. 7. Ground pin current is the regulator quiescent current plus pass transistor base current. The total current drawn from the supply is the sum of the load current plus the ground pin current. 8. Thermal regulation is defined as the change in output voltage at a time “t” after a change in power dissipation is applied, excluding load or line regulation effects. Specifications are for a 80mA load pulse at VIN =16V for t=10ms. 2 Version: L1609 TS5204 Taiwan Semiconductor ORDERING INFORMATION OUTPUT VOLTAGE PART NO. 3.3V 5V PACKAGE PACKING TS5204CQ33 RFG DFN2x2 3,000pcs / 7” Reel TS5204CX33 RFG SOT-23 3,000pcs / 7” Reel TS5204CY50 RMG SOT-89 1,000pcs / 7” Reel TS5204CX50 RFG SOT-23 3,000pcs / 7” Reel APPLICATION INFORMATION TS5204 series is designed to provide 80mA of continuous current in a very small package. Maximum power dissipation can be calculated based on the output current and the voltage drop across the part. To determine the maximum power dissipation of the package, use the junction-ambient thermal resistance of the device and the following basic equation: PD(MAX) = [ TJ(MAX) – TA ] /RΘJA Tj(max) is the maximum junction temperature of the die(125°C), and Ta is the ambient operating temperature. RΘJA is layout dependent, the actual power dissipation of the regulator circuit can be determined using the equation: PD = (VIN – VOUT) * IOUT + VIN * IGND Substituting PD(MAX) for PD and solving for the operating conditions that are critical to the application will give the maximum operating conditions for the regulator circuit. For example, when operating the TS5204CX33 at room temperature with a minimum footprint layout, the maximum input voltage for a set output current can be determined as follows: o o o PD(MAX) = (125 C – 25 C) / 220 C/W The junction to ambient thermal resistance for the minimum footprint is 220°C/W, the maximum power dissipation must not be exceeded for proper operation. Using the output voltage of 3.3V and an output current of 80mA, the maximum input voltage can be determined. From the electrical characteristics table, the maximum ground current for 80mA output current is 2.5mA. 445mW = (VIN – 3.3V ) * 120mA + VIN * 2.5mA 445mW = VIN * 120mA – 3.3 * 120mA + VIN * 2.5mA 445mW = VIN * 120mA – 395mW + VIN * 2.5mA 840mW = VIN * 122.5mA VIN (max) = 6.85V Therefore, a 3.3V application at 80mA of output current can accept a maximum input voltage of 6.85V in a SOT23 package. Input Capacitor Requirement An input capacitor of 0.1μF or greater is recommended when the device is more than 10” away from the bulk AC supply capacitance or when the supply is a battery. 3 Version: L1609 TS5204 Taiwan Semiconductor APPLICATION INFORMATION (CONTINUE) Output Capacitor Requirement The TS5204 series requires an output capacitor to maintain stability and improve transient response is necessary. 2.2μF minimum is recommended. Larger values improve the regulator’s transient response. The output capacitor value may be increased without limit. The output capacitor should have an ESR (effective series resistance) less than 5Ω and a resonant frequency above 1MHz. Ultra-low ESR capacitors can cause a low amplitude oscillation on the output and/or under damped transient response. Most of tantalum or aluminum electrolytic capacitors are adequate; film types will work. Since many aluminum electrolytic have electrolytes that freeze at about –30°C, solid tantalums are recommended for operation below –25°C. At lower values of output current, less output capacitance is required for output stability. The capacitor can be reduced to 0.47μF for current below 10mA or 0.33μF for currents below 1mA. No Load Stability The TS5204 series will remain stable and in regulation with no load, unlike many other voltage regulators. This is especially important in CMOS RAM keep alive applications. Dual Supply Operation When used in dual supply systems where the regulator load is returned to a negative supply, the output voltage must be diode clamped to ground. ELECTRICAL CHARACTERICS CURVES (TA=25oC, unless otherwise noted) Figure 1. Dropout Voltage vs. Output Current Figure 2. Ground Current vs. Output Current Figure 3. Dropout Voltage vs. Output Current Figure 4. Short Circuit Current vs. Input Voltage 4 Version: L1609 TS5204 Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS (Unit: Millimeters) SOT-23 SUGGESTED PAD LAYOUT (Unit: Millimeters) MARKING DIAGRAM = Device Code = Voltage Code (5 = 5.0V, S = 3.3V) Y = Year Code M = Month Code for Halogen Free Product O =Jan P =Feb Q =Mar R =Apr S =May T =Jun U =Jul V =Aug W =Sep X =Oct Y =Nov Z =Dec L = Lot Code J x 5 Version: L1609 TS5204 Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS (Unit: Millimeters) SOT-89 SUGGESTED PAD LAYOUT (Unit: Millimeters) MARKING DIAGRAM = Year Code = Month Code for Halogen Free Product O =Jan P =Feb Q =Mar R =Apr S =May T =Jun U =Jul V =Aug W =Sep X =Oct Y =Nov Z =Dec L = Lot Code xx = Voltage (50 = 5.0V) Y M 6 Version: L1609 TS5204 Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS (Unit: Millimeters) DFN2x2 SUGGESTED PAD LAYOUT (Unit: Millimeters) MARKING DIAGRAM = Device Code = Fixed Output Voltage Code (33 =3.3V) Y = Year Code M = Month Code for Halogen Free Product O =Jan P =Feb Q =Mar R =Apr S =May T =Jun U =Jul V =Aug W =Sep X =Oct Y =Nov Z =Dec L = Lot Code J xx 7 Version: L1609 TS5204 Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 8 Version: L1609
TS5204CQ33 RFG 价格&库存
很抱歉,暂时无法提供与“TS5204CQ33 RFG”相匹配的价格&库存,您可以联系我们找货
TS5204CQ33 RFG
  • 1+6.132701+0.79270
  • 10+4.3001010+0.55580
  • 25+3.8569025+0.49850
  • 100+3.37780100+0.43660
  • 250+3.13820250+0.40570
  • 500+2.99450500+0.38710
  • 1000+2.886701000+0.37310
  • 3000+2.754903000+0.35610
  • 6000+2.515406000+0.32520
库存:11970
