JC40S 1K 0.3%
JC40S 1K 0.3%
    NIDEC(尼得科)
    可调电阻/电位器 1KΩ ±15% 1.5W ±400ppm/℃
JC40S 1K 0.3% 数据手册
CONDUCTIVE PLASTIC SINGLE TURN TYPE JC Basic construction Conductive plastic single turn type RoHS compliant Input/outptu terminal Bearing Wiper Conductive plastic ■ FEATURES ● ● ● ● ● ● Compact Cost effective (JC22E) in house comparison Long life High following characteristics High resolution (Essentially infinite) RoHS compliant ■ PART NUMBER DESIGNATION J C 2 2 E 2 k 1 % Series name JC22E:Linear JC22S:Linear JC30S:Linear JC40S:Linear Independent linearity φ φ φ φ 0.3 %:± 0.3 % 0.5 %:± 0.5 % 1 %: ± 1 % 22 mm 22 mm 30 mm 40 mm Nominal resistance value(Ω) 200, 500, 1 k, 2 k, 5 k, 10 k, 20 k ■ LIST OF PART NUMBERS Size Nominal Item resistance value Independent linearity 1 kΩ 2 kΩ 5 kΩ φ 22 mm ±1 % Part number 500 Ω JC22E 2 k 1 % 1 kΩ JC22E 5 k 1 % 2 kΩ 10 kΩ JC22E 10 k 1 % JC22S 200 0.5 % 1 kΩ 2 kΩ ±0.5 % φ 30 mm 5 kΩ Independent linearity Part number JC30S 500 0.5 % JC30S 1 k 0.5 % ±0.5 % JC30S 2 k 0.5 % JC30S 5 k 0.5 % 10 kΩ JC30S 10 k 0.5 % JC22S 500 0.5 % 20 kΩ JC30S 20 k 0.5 % JC22S 1 k 0.5 % 500 Ω JC40S 500 0.3 % JC22S 2 k 0.5 % 1 kΩ 5 kΩ JC22S 5 k 0.5 % 10 kΩ JC22S 10 k 0.5 % ※ Verify the above part numbers when placing orders. The products indicated by receipt of order basis. Nominal Item resistance value JC22E 1 k 1 % 200 Ω 500 Ω Size mark are manufactured upon φ 40 mm 2 kΩ 5 kΩ JC40S 1 k 0.3 % ±0.3 % JC40S 2 k 0.3 % JC40S 5 k 0.3 % 10 kΩ JC40S 10 k 0.3 % 20 kΩ JC40S 20 k 0.3 % JC POTENTIOMETERS ■ STANDARD SPECIFICATIONS Single turn Output Item Part number JC22E JC30S JC40S Refer to LIST OF PART NUMBERS Nominal resistance value % Resistance torelance ± 20 ± 15 Essentially infinite Resolution % Independent linearity Effective electrical angle ± 1 320° ± 5° ± 0.3 ± 0.5 340° ± 5° 343° ± 5° 345° ± 5° 360° continuous Mechanical angle W 0.5 Power rating (at 40 °C) 1000 Vrms Dielectric strength MΩ minimum Insulation resistance mN·m {gf·cm} maximum 4.9 {50} Strength of tighten screw N·m {kgf·cm} maximum 0.98 {10} Temp. coefficient of resistance Operating temp. range Maximum rotational speed 0.7 1.5 1 min 1000 (at DC500 V) Rotational torque 0.98 {10} 1.18 {12} 1.47 {15} — ± 400 ppm/°C −40 ~ 85 °C min-1 100 JCF/JCL 定格電力軽減曲線 Rotational life (cycles) 10 million 300 20 million 30 million 0.1 % maximum Output smoothness Net weight JC22S g Approx. 15 Approx. 17 Approx. 24 IP40 Protection grade ■ RATED POWER DERATING CURVE Power rating ratio (%) 100 – 40 + 40 Ambient temperature (℃) + 85 Approx. 56 JC, JP, M結線図 ֎‫ܗ‬ਤ JC POTENTIOMETERS 5–2 6 5 4 3 2 1 ϐϯ/P (Unit mm) Pin :No. 16 14 14 (23) 5 1.5 8 12 (34) 5.55 φ 22±1 3 0 φ 10.3 –0.06 10 0 10.3 – 0.05 5.5 0 x. M 9 (P = 0.75) φ 6 – 0.02 0.5 16 ma 1.6 3 – φ 1.5 Terminal width 3 0 φ 6 –0.1 4.7 6.5 (30°) 2 (30°) 3 1 R1 P = 0.75 結線図 Wiring diagram 12 P = 0.75 φ 9.4 2 0.5 1 φ 12.9 1. Nut S 外形図 3 30° 30° 2 0 φ 19.5 –0.02 φ 15 ± 0.05 3–M2 15 23.8 D = 3.0 min. ● JC30S ma φ 20 0 φ 4 –0.01 12 0 ° 19 0 φ 27 –0.03 φ 30 R 外形図 11.5 20 A x. en Green Re Gre 1 2d 3 x. ppro 50° 19° 19° 12 0° 1.57 1.57 15 3 – M 3 P = 0.5 D = 3.0 min. 1.5 17 32 φ 30 m 20 13.3 0 φ 40 R 25 以 下 0 φ 6 –0.01 A 20 3 - M 3 (P = 0.5) D = 3.0 min. φ 37 –0.03 Green en 1 Gre 2 . 3 Re x d o ° r 45 16° 16° p p ● JC40S ax 12 0° . 12 0° 1.57 2.36 1.86 φ 22.5 0 ax. φ 19.5 7m 13.4 1.57 1.57 3.66 φ 22.2 R1 2. Washer φ 3 –0.01 1 ③ 10 ± 0.5 ② M9 25 JC22E, JC22S JC30S, JC40S ① (4.5) (JC22E Accessories) ● JC22S 6 – ˘0.5 5 0. ● JC22E 4֎‫ܗ‬ਤ M9 γϟϑτʢथࢷʣ Shaft (Plastic) C ■ OUTLINE DIMENSIONS (4.8) CW
JC40S 1K 0.3% 价格&库存
很抱歉,暂时无法提供与“JC40S 1K 0.3%”相匹配的价格&库存,您可以联系我们找货
