USB3160-30-0170-1-C
USB3160-30-0170-1-C
    GCT
    USB3160-30-0170-1-C
USB3160-30-0170-1-C 数据手册
2x .85 Ø0 2x R Ø1 5x 1.50 Pin5 .25 5x 0.45 1.30 2.60 6.36 Recommended PCB Layout Material Plastic Housing: High Temp Plastic , UL94V-0, Black Contact Terminal: Copper Alloy Metallic Shell: Stainless Steel. 5x 0.30±0.08 1.30±0.08 Optional Mating Entry Faces 2.60±0.08 Plating Underplating: 50µ" Nickel min Finish: Contact Area: 30µ" Gold Solder Tails: Gold Flash Metallic Shell: Matte Tin Ø 5.85 8.50 max. 1.54±0.10 C 5± 0. 04 T=0.30 0. 55 0.50 D Ø0 .6 0.6 3.2 Specifications 0.10 4 .0 ±0 0 5 0. Cap PCB Mount & Cap Information As viewed from component side General tolerance: ±0.05 Component Outline Solder Area S±0.10 E S±0.10 (1.60mm Stake shown) F Pin1 Optional Mating Entry Faces 7.50 5.30 6.6 (With Mating Entry Face) 5.8 (Without Mating Entry Face) .7 5 Ø0 0.55 2x0.50 2x 0.65 1.75 0. 2 5 * 11.00 2.60 2.45 G 3.00 0.60 1.85+0.08 -0.02 Pin5 .60 Ø0 15 0. 5± .2 R0 Pin1 3.50 5.85 2.80 2.40 0.50 0.90 * 8.00 6.90+0.06 -0.02 3.5 (With Mating Entry Face) 2.7 (Without Mating Entry Face) only applicable to parts * Dimensions with an optional mating entry face H Electrical Voltage Rating : 30 V AC Current Rating: Signal (Pins 2,3,4): 1.0 A. Power (Pins1,5): 2.8A. Operating Temperature: -30°C to +85°C. Contact Resistance: 30mΩ max. Insulating Resistance: 1000MΩ min. Dielectric Withstand Voltage: 100V AC/minute Mating View Ordering Grid USB3160 2.00 30 XXXX X C Request Samples and Quotation Contact Plating 30 = 30µ" Gold Packing Options C = Tape & Reel with Cap Shell Stake Length "S" 0070 = 0.60mm 0120 = 1.10mm (recommended for 0.80mm PCB) 0170 = 1.60mm (recommended for 1.00mm PCB) Mating Entry Face 1 = With Mating Entry Face 0 = Without Mating Entry Face (500 per reel) H 5.30 0.79 5.80 B Designed to comply with physical, electrical and environmental requirements of Micro USB Standard (USB2.0) * A Part Number Product Description USB3160 Micro USB Receptacle, Type B,Surface Mount, Vertical, With Locating Peg & Through-Hole Shell Stakes Drawing Date 2nd November 2016 By Detail 1 2 3 4 Mechanical & Environmental Mating Force: 35N max. Unmating Force: 8N min. Durability: 10,000 Cycles Revision Date 5 CC USB3160 C PCN C3 31/12/21 Tolerances (Except as Noted) Length Angle X. ± 0.50 X.X ± 0.30 X.XX ± 0.20 X.XXX ± 0.10 ± 2° Units: Metric (mm) C 3rd Angle Projection 6 7 This drawing is confidential and copyright of Global Connector Technology, Ltd (GCT). This drawing must not be copied or disclosed without written consent. E & OE www.gct.co Not to Scale Drawn By CC 8 Sheet No. 1/2 30.4 H Tape & Reel Label 24.4 Peeling Angle 165° ~ 180° Ø330 G 400 min Vacuum Bag F 22pcs Empty End of reel 22pcs Empty Start of reel Packing 500pcs product User Direction of Unreeling 2.00±0.10 4.00±0.10 Cover Tape. Box dimensions: 355mm x 355mm x 305mm T=0.50 C B Inner carton dimensions: 340mm x 340mm x 285mm 12.00±0.10 21.30 D 0 .1 +0 .00 0 0 .5 Ø1 24.00±0.30 E 1.75±0.15 12.00±0.15 Void filler Notes: Peeling off force of top tape: 0.1-1.3N (Peeling direction as shown) Pcs / Reel Reels / Carton 500 Materials: Carrier Tape: Polystyrene (PS) Top Tape: PE Reel Tape: Polystyrene (PS) Bag: PE Product Description Micro USB Receptacle, Type B,Surface Mount, Vertical, With Locating Peg & Through-Hole Shell Stakes By Detail 2 3 4 4500 pcs USB3160 2nd November 2016 1 Total Quantity Part Number Drawing Date A 9 Revision Date 5 CC USB3160 C PCN C3 31/12/21 Tolerances (Except as Noted) Length Angle X. ± 0.20 X.X ± 0.15 X.XX ± 0.10 X.XXX ± 0.05 ± 2° Units: Metric (mm) C 3rd Angle Projection 6 7 This drawing is confidential and copyright of Global Connector Technology, Ltd (GCT). This drawing must not be copied or disclosed without written consent. E & OE www.gct.co Not to Scale Drawn By CC 8 Sheet No. 2/2
USB3160-30-0170-1-C 价格&库存
很抱歉,暂时无法提供与“USB3160-30-0170-1-C”相匹配的价格&库存,您可以联系我们找货
USB3160-30-0170-1-C
    USB3160-30-0170-1-C
      USB3160-30-0170-1-C
      • 1+6.970261+0.90290
      • 10+5.9316610+0.76836
      • 25+5.5574225+0.71988
      • 50+5.2927050+0.68559
      • 100+5.03940100+0.65278
      • 250+4.72317250+0.61182
      库存:29402
      USB3160-30-0170-1-C
      • 500+4.49739500+0.58257
      • 1000+4.282621000+0.55475
      • 1500+4.161841500+0.53911
      • 2500+4.014512500+0.52002
      • 3500+3.920333500+0.50782
      • 5000+3.822935000+0.49521
      库存:29402
      USB3160-30-0170-1-C
      • 1+5.92073
      • 10+4.98764
      • 25+4.68460
      • 50+4.45222
      • 100+4.24860
      • 250+3.99945
      • 500+3.82338
      • 1000+3.66647
      • 1500+3.59220
      • 2500+3.46404
      库存:470
      USB3160-30-0170-1-C
        库存:5000
