KUSBVLPX-AS1N-W
KUSBVLPX-AS1N-W
    KYCON
    插件
    USB连接器 插件
KUSBVLPX-AS1N-W 数据手册
2D Drawing IGES STEP 3D PDF Solder Profile CofC RoHS Compliant CofC REACH Compliant UL Plastic File Certificate of Origin Check Stock Request a Sample Send Us An Email Generated Part Number KUSBVLPX-AS1N-B Part Number Builder KUSBVLPX UNIVERSAL SERIAL BUS: KUSBVLPX Series Series B AS1N Type VERTICAL, A TYPE, LOW PROFILE USB Insulator Color Option Plating Option Series KUSBVLPX - Vertical Low Profile Product Features Vertical Low Profile 10mm Height Through hole Type AS1N - Single A Type Insulator Color Option B - Black W - White Performance Specifications Materials and Finish Insulator UL94V-0 Rated, Thermoplastic, Color White or Black Contact Material Copper Alloy Plating Options Standard: Gold flash on contact area, Tin on Soldertails all over 40µ" nickel min. 30 Option: 30µ" Gold on contact area, Tin on Soldertails all over 40µ" nickel min. Plating Option Blank - Gold Flash 30 - 30µ" Gold Plating Contact Kycon for other options KUSBVLPX Dimensions in mm Shield Nickel Plating Electrical Characteristics Rated Voltage: 30V AC Contact Current Rating: 3A Max. Contact Resistance: 30 milliohms Max Insulation Resistance: 1000 Megohms Min. Dielectric Withstanding: 250V AC for 1 minute Mechanical Characteristics Insertion Force: 3.57kg max. Extraction Force: 1.02kg min. Durability: 1500 Mating Cycles OperatingTemperature: -55°C to +85°C Phone: +1.408.494.0330 l Fax: +1.408.494.0325 l WWW.KYCON.COM l 0918
KUSBVLPX-AS1N-W 价格&库存
很抱歉,暂时无法提供与“KUSBVLPX-AS1N-W”相匹配的价格&库存,您可以联系我们找货
