114990655
114990655
    SEEED(矽递科技)
114990655 数据手册
Crazyflie 2.0 DWM1000 Deck SKU 114990655    The Loco positioning Deck is a Tag in the Loco Positioning system and measures the distance to Anchors. The distances are used to estimate the absolute position of the Crazyflie 2.X in the room, which can be used for autonomous flight. To read more about the Loco positioning deck go to our website. Note: This product is intended to be used together with Loco Positioning Nodes and cannot be used standalone. For more information on the Loco Positioning System please see this Loco Positioning System page. Specifications are based on the standard 2‐way ranging mode. Features   Measures distances to Loco Positioning Node Anchors 4 status LEDs Electrical specifications    Based on the Decawave DWM1000 module Implements IEEE 802.15.4 UWB 1‐wire memory for automatic expansion deck detection Ranging specifications    Ranging accuracy ±10 cm according to DWM1000 spec. See the wiki for measurements. Maximum tested range 10 m Ranging rate 500 Hz, shared over all anchors. Around 80Hz per anchor with 6 anchors Radio specifications   Operates at 3.2 ‐ 7 GHz Channel bandwidth 500 MHz Power consumption   Max 150 mA, depends on operation mode and configuration Crazyflie 2.X flight time with deck 6 minutes Mechanical specifications    Weight: 3.3 g Size (WxHxD): 28x35x4 mm Designed for mounting above or under the Crazyflie 2.X Compatibility See compatibility matrix Loco Positioning Nodes Part List 1 x Loco Positioning deck ECCN/HTS ECCN  EAR99  HSCODE  8526919090 USHSCODE  8517700000 UPC                        https://www.seeedstudio.com/Crazyflie‐2‐0‐DWM1000‐Deck‐p‐2938.html/4‐24‐19
114990655 价格&库存
很抱歉,暂时无法提供与“114990655”相匹配的价格&库存,您可以联系我们找货
