2210-T210-K0M1-H121-10A
    E-T-A
2210-T210-K0M1-H121-10A 数据手册
Thermal-Magnetic Circuit Breaker 2210-T2.. Description One, two and three pole thermal-magnetic circuit breakers with trip-free mechanism and toggle actuation (S-type TM CBE to EN 60934/IEC 934). Featuring a combi-foot design for both symmetric and asymmetric rail mounting. Available with auxiliary contact (1 x N/O or 1 x N/C) for status signalling. Two and three pole models are internally linked to ensure that both/all poles trip in the event of an overload on one pole, even if the actuator is held in the ON position. This CBE can be supplied in current ratings up to 32 A with a choice of characteristic curves. All screw terminals are recessed for safety. Approved to CBE standard EN 60934 (IEC 60934). Typical applications 1 2210-T2.. 2-pole Process control equipment, robotics, machine tool control, communications systems, instrumentation. Features Your benefits l l l Comprehensive approvals allow global use Current rating range from 0.1 A to 32 A l Very small width of only 12.5 mm including auxiliary contacts l High vibration resistance to DNV GL Class B for mounting with combustion engines, pumps, compressors l Compliant with the relevant requirements of the railway standards DIN EN 50155, DIN EN 61373 and EN 45545 (detailed information upon request) Space and weight savings of at least 50 % compared to conventional MCBs l Reduced assembly times thanks to integral auxiliary contacts l Optimum equipment protection through fine grading of current ratings Preferred types – for more details on all configurations please see order numbering code Preferred types are E-T-A products most frequently used by E-T-A customers. We manufacture E-T-A preferred types in particularly high Preferred types 1-pole 2210-T210-K0M1-H1212-pole 2210-T220-K0M1-H221- Approvals volumes. Our preferred types are supplied at shorter lead times than non-standard versions. Standard current ratings (A) 0.5 1 2 3 4 5 6 8 10 16 x x x x x x x x x x x 0.5 1 2 3 4 5 6 8 10 16 20 x x x x x x 20 Data sheet For access to the latest documents please follow:www.e-t-a.de/en053 Compliances 2011 www.e-t-a.de 1 Thermal-Magnetic Circuit Breaker 2210-T2.. Technical data 1 Standard current ratings and typical internal resistance values For further details please see: www.e-t-a.de/ti_e Voltage rating AC 250 V; 3 AC 433 V (50/60 Hz); DC 65 V (UL: AC 277/480 V; DC 65 V) Current rating range 0.1...32 A for curves M1, T1 0.1...16 A for curves F1, F2 Auxiliary circuit 1 A, AC 240 V / DC 65 V, resistive (min. 10 V / 10 mA) Typical life 3 AC 433 V; AC 250 V: 0.1...25 A 10,000 operations at 1 x IN, inductive DC 65 V: 0.1...32 A 10,000 operations at 1 x IN, inductive 3 AC 433 V; AC 250 V: 32 A 6,000 operations at 1 x IN, resistive Ambient temperature -30...+60 °C (-22...+140 °F) T 60 Insulation co-ordination rated impulse pollution (IEC 60664 and 60664 A) withstand voltage degree 2.5 kV 2 reinforced insulation in operating area Dielectric strength (IEC 60664 and 60664A) test voltage operating area AC 3,000 V main/aux. circuit AC 3,000 V pole/pole AC 1,500 V Insulation resistance > 100 MΩ (DC 500 V) Interrupting capacity Icn 0.1...5 A 400 A 6...32 A 800 A curves F1, F2, M1, T1: 0.1...16 A 2,500 A (at DC 32 V) Interrupting capacity (UL 1077) Current rating (A) Internal resistance (Ω) F1 F2 M1 T1 fast acting for DC only fast acting delay for AC + DC standard for AC+DC delayed low resistance for AC only 0.1 162 162 92 81 0.2 39.3 39.3 26.1 24.2 0.3 17.5 17.5 11.6 10.4 0.4 9.2 9.2 6.6 6.0 0.5 6.8 6.8 4.1 3.9 0.6 4.2 4.2 3 2.7 0.8 2.8 2.8 1.65 1.53 1 1.6 1.6 1.10 0.98 1.5 0.78 0,78 0.47 0.42 2 0.42 0,42 0.28 0.24 2.5 0.26 0.26 0.183 0.17 3 0.18 0.18 0.124 0.12 4 0.12 0.12 0.077 0.073 5 0.092 0.092 0.063 0.055 6 0.054 0.054 0.045 0.039 8 0.025 0.025 ≤ 0.02 ≤ 0.02 10 0.022 0.02 ≤ 0.02 ≤ 0.02 IN 0.1...16 A 20...32 A 12 ≤ 0.02 ≤ 0.02 ≤ 0.02 ≤ 0.02 AC 277 V 1-pole AC 277/480 V 2-/3-pole DC 65 V 5,000 A 5,000 A 2,000 A 2,000 A 2,000 A 2,000 A 16 ≤ 0.02 ≤ 0.02 ≤ 0.02 ≤ 0.02 Degree of protection operating area IP30 (IEC 60529/DIN 40050) terminal area IP20 Vibration curves F1, F2: 3 g (57-500 Hz), ± 0.23 mm (10-57 Hz) curves M1, T1: 5 g (57-500 Hz), ± 0.38 mm (10-57 Hz) to IEC 60068-2-6, test Fc 10 frequency cycles/axis Shock curves F1, F2: 25 g (11 ms), directions 1, 2, 3, 4, 5 10 g (11 ms), direction 6 curves M1, T1: 25 g (11 ms), directions 1, 2, 3, 4, 5 20 g (11 ms), direction 6 to IEC 60068-2-27, test Ea Corrosion 96 hours at 5 % salt mist to IEC 60068-2-11, test Ka Humidity 240 hours at 95 % RH to IEC 60068-2-78, test Cab Mass approx. 60 g per pole 2 20 - - ≤ 0.02 ≤ 0.02 25 - - ≤ 0.02 ≤ 0.02 32 - - ≤ 0.02 ≤ 0.02 Approvals Authority Standard Rated voltage Current ratings VDE IEC/EN 60934 3 AC 433 V AC 250 V DC 65 V 0.1 A…32 A 0.1 A…32 A 0.1 A…32 A UL UL 1077 AC 277/480 V AC 277 V DC 65 V 0.1 A…32 A 0.1 A…32 A 0.1 A…32 A CSA C22.2 No 235 AC 277/480 V AC 277 V DC 65 V 0.1 A…32 A 0.1 A…32 A 0.1 A…32 A CQC GB 17701 AC 250/433 V AC 250 V DC 65 V 0.1 A…32 A 0.1 A…32 A 0.1 A…32 A DNV GL IEC 60934, DNVGLCG 0339 3 AC 433 V AC 250 V DC 65 V 0.1 A…32 A 0.1 A…32 A 0.1 A…32 A KTL KC60934 AC 250 V, 1-pole AC 433 V, 2-pole 0.1 A...16 A 0.1 A...16 A www.e-t-a.de 2011 Thermal-Magnetic Circuit Breaker 2210-T2.. Preferred types Preferred types are E-T-A products most frequently used by E-T-A customers. We manufacture E-T-A preferred types in particularly high Preferred types 1-pole 2210-T210-K0M1-H1212-pole volumes. Our preferred types are supplied at shorter lead times than non-standard versions. Standard current ratings (A) 0.5 1 2 3 4 5 6 8 10 16 x x x x x x x x x x x 0.5 1 2 3 4 5 6 8 10 16 20 x x x 2210-T220-K0M1-H221- x x x 20 1 Ordering information Type No. 2210 single and multipole thermal-magnetic circuit breaker Mounting T rail mounting Actuator design 2 toggle Number of poles 1 single pole protected 2 2-pole protected 3 3-pole protected Accessories 0 without accessories Terminal design (main contacts) K0 screw terminals Characteristic curve F1 fast acting: therm.1.01-1.4xIN; magn.2-4xIN DC (DC only) F2 fast acting: therm.1.01-1.4xIN; magn.3,5-6,5xIN AC/4,5-8,5xIN DC M1 standard delay: therm. 1.01-1.4xIN; magn. 6-12xIN AC, 7.8-15.6xIN DC T1 delayed: therm. 1.01-1.4xIN; magn. 10-20xIN AC Auxiliary contact design H without intermediate position Auxiliary contacts 1 with auxiliary contacts 2 auxiliary contacts on pole 1 only (multipole devices) Auxiliary contact function (see diagrams) 2 1 N/O contact 3 1 N/C contact Auxiliary contact - terminal design 1 screw terminals Current ratings 0.1...32 A 2210 - T 2 1 0 - K0 M1- H 1 2 1 - 10 A ordering example Please be informed that we have minimum ordering quantities to be observed. Custom designed versions Looking for a version you cannot find in our ordering number code? Please get in touch. We will be pleased to find a solution for you. 2011 www.e-t-a.de 3 Thermal-Magnetic Circuit Breaker 2210-T2.. Dimensions Internal connection diagrams 37.5 1.48 toggles linked for multipole devices 20 .787 11.5 .453 1 slot fitting labels from Phoenix Weidmüller Wieland 45 1.77 OFF ...-H131-... 30.5 1.20 25 .984 18 .709 OFF position line (Si) I 1 11 0 11.5 .453 78.5 3.09 88.5 3.48 ...-H121-... 12-14 Si 2 .472-.551 I> I> 2 2 line 1 (Si) 13 N/O contact 0 I line 1 14 (Si) 15 .591 12 .472 42.5 1.67 G-profile EN 50035-G32 12.5 12.5 .492 .492 7.5 .295 5.5 .217 I 12 (Si) 40 1.57 symmetric rail EN 50022-35x7.5 EN 50022-35x15/1.5 main contact terminal max. 6 mm2 (AWG 10) (rigid conductor) tightening torque 0.5 Nm unit I rigid flexible I> 2 2 5 6 12.5 .492 1 2 3 4 Cable cross section Conductor I> 5.5 .217 12A 12A 12A M1 M1 M1 unit II 14 (Si) Shock directions Si-terminal M3 max. 1.5 mm2 (AWG 16) (rigid conductor) tightening torque 0.5 Nm unit III (Si) 13 44 1.73 0 Si 1 ON position line (Si) I 1 11 0 12 (Si) ON 9-12 .354-.472 N/C contact Main contacts 1 & 2 Aux. contact IN 0.2 mm² min. 0.2 mm² max. 6 mm² 1.5 mm² 0.2 mm² min. 0.2 mm² max. 4 mm² 1.0 mm² flexible with wire end ferrule min. 0.25 mm² without plastic sleeve max. 4 mm² flexible with wire end ferrule min. 0.25 mm² with plastic sleeve max. 2.5 mm² 0.25 mm² 1.0 mm² 0.25 mm² 0.75 mm² Installation drawing operating area (reinforced insulation) Si 1 Si 2 mounting area 4 This is a metric design and millimeter dimensions take precedence ( mm ) inch www.e-t-a.de 2011 Thermal-Magnetic Circuit Breaker 2210-T2.. Typical time/current characteristics -F1 0.1…16 A DC only 10000 Trip time in seconds 1000 100 10 1 1 0.1 0.01 0.001 1 2 4 6 8 10 20 406080100 … times rated current -F2 0.1…7.5 A AC/ DC1) 10000 Trip time in seconds 1000 100 10 1 0.1 0.01 0.001 1 2 4 6 8 10 20 406080100 … times rated current -F2 8…16 A AC/ DC1) 10000 Trip time in seconds 1000 100 10 1 0.1 0.01 0.001 1 +60 °C +140 °F 1) 2 4 6 8 10 20 40 6080100 … times rated current +23 °C +73.4 °F -30 °C -22 °F Magnetic tripping currents are increased by 30% on DC supplies. 2011 www.e-t-a.de 5 Thermal-Magnetic Circuit Breaker 2210-T2.. Typical time/current characteristics 1 AC/DC 1) 10000 1000 1000 100 10 1 10 1 0.1 0.01 0.01 1 0.001 2 4 6 8 10 20 40 6080100 … times rated current -T1 0.1…6 A AC only 1000 1000 Trip time in seconds 10000 100 10 1 2 4 6 8 10 20 40 6080100 … times rated current 10 1 0.1 0.01 0.01 0.001 2 4 6 8 10 20 40 6080100 … times rated current AC only 100 0.1 1 1 -T1 8…32 A 10000 0.001 AC/DC 1) 100 0.1 0.001 Trip time in seconds -M1 8…32 A 10000 Trip time in seconds Trip time in seconds -M1 0.1…6 A 60 °C 23 °C -30 °C 1 2 4 6 8 10 20 40 6080100 … times rated current The time/current characteristic curve depends on the ambient temperature prevailing. In order to eliminate nuisance tripping, please multiply the circuit breaker current ratings by the derating factor shown below. See also section Technical information. Ambient °F temp. °C -22 -30 -4 -20 +14 -10 +32 +73.4 +86 0 +23 +30 +104 +122 +140 +40 +50 +60 Derating factor 0.76 0.79 0.83 0.88 1.11 6 1 1.04 1.19 Multi pole devices: all poles symmetrically loaded. With single pole overload, thermal tripping will be at max. 1.7 x IN with curves F1, F2 and M1. 1) Magnetic tripping currents are increased by 30 % on DC supplies (curves F2, M1). 1.29 www.e-t-a.de 2011 Thermal-Magnetic Circuit Breaker 2210-T2.. Accessories Plug-on cap, busbar 2/3-pole Y 308 506 01 Connector bus links -K10 X210 589 01/ 2.5 mm2, (AWG 14) (black) up to 20 A max. load X210 589 02/ 1.5 mm2, (AWG 16) (brown) up to 13 A max. load ø2.5 .099 50 pin lugs to DIN 46230 tinned copper L 3 L 1 L 2 L 3 L 1 L 2 L 3 L 1 L 2 L 3 L 1 L 2 L 3 16 L 3 16-1 6.30-.394 L 2 4.6 1.81 20-1 7.87-394 L 2 L2 L2 L1 L1 L3 L3 L2 L2 L1 X22254011 16 mm2 L1 L3 79 x 12.7 = 1003.3 31.1 x 5 = 3950 G E R M A N Y D-90518 Altdorf Made in Germany G E R M A N Y D-90518 Altdorf Made in Germany L3 3±0.2 1.81±.079 1.5 .590 12.7 5 L2 G E R M A N Y D-90518 Altdorf Made in Germany X22254011 16 mm2 L1 L2 3±0.2 1.81±.079 Y30850001 2 16 mm ° L1 5.79 1030+2 405+.787 Y30850001 16 mm2 Busbar 1-pole, 90° X 222 540 11 The one metre long busbars can be cut to suitable lengths. Plug-on caps can be fitted on the ends to provide brush contact protection. cross section: 16 mm² 14.7 12.7 5 1 15.8 6.22 17.3 6.81 33.3±0.4 13.1±.157 ~70 ~2.76 Busbar 3-pole Y 308 500 01 cross section: 16 mm² 1.5 .591 80 x 12.7 = 1016 31.5 x 5 = 400 Plug-on cap, busbar 2/3-pole Y 308 506 01 G E R M A N Y D-90518 Altdorf Made in Germany +2 1016 400+.787 1016+2 400+.787 1.5 .591 16 6.30 12.7 5 79 x 12.7 = 1003.3 31.1 x 5 = 3950 3 .118 33.7 1.327 3±0.2 1.81±.079 G E R M A N Y D-90518 Altdorf Made in Germany 14.7 5.79 Y30849801 16 mm2 G E R M A N Y D-90518 Altdorf Made in Germany 30,7±0,4 12.1±.157 Y30849801 16 mm2 4.6 1.81 Supply terminal Y 308 503 01 Imax 63 A with 1-pole busbar, 50 A with multipole busbar Max. tightening torque of terminal screw 2 Nm Max. cable cross section: 25 mm2 / single strand 16 mm2 / multistrand with wire end ferrule Busbar for 1-pole devices Firmly mounted supply terminals, placed at fixed distances (1 supply terminal every 7 modules) For cable feed from the side Ideal for applications with high vibration requirements Y31270901 cross section: 16 mm² 1.5 .059 16.2 .638 Busbar 1-pole Y 308 498 01 cross section: 16 mm² 13 .512 18.4 .724 1012.8+2 399+.787 Y31270901 16 mm2 Y31270901 16 mm2 G E R M A N Y D-90518 Altdorf Made in Germany 79x12.7=1003,3 31.1 x 5 = 3950 3 1.18 1.5 .591 35 13.8 12.7 5 G E R M A N Y D-90518 Altdorf Made in Germany 76.2 30 23.5 9.25 12x76.2=914.4 4.72x30=360 Plug-on cap, 1-pole Y 307 851 01 Caution: When using multipole busbars please leave at least one pole’s width between two adjacent line entry terminals. Busbar 2-pole Y 308 499 01 cross section: 16 mm² 1016+2 400+.787 L 2 L 1 L 2 L 1 L 2 L 1 L 2 L 1 L 2 16 6.30 L2 79x12.7 = 1003.3 4.72x30=360 17.3 6.81 L 1 L1 L2 L2 L1 L1 L2 L2 L 1 L 2 L 1 L 2 3±0.2 1.81±.079 L1 L1 L2 33.3±0.4 13.1±.157 G E R M A N Y D-90518 Altdorf Made in Germany L 1 L 2 2011 L1 L2 12.7 5 G E R M A N Y D-90518 Altdorf Made in Germany L2 L1 L1 Y30849901 16 mm2 Y30849901 16 mm2 15.8 6.22 1.5 .591 This is a metric design and millimeter dimensions take precedence ( mm ) inch All dimensions without tolerances are for reference only. In the interest of improved design, performance and cost effectiveness the right to make changes in these specifications without notice is reserved.Product markings may not be exactly as the ordering codes. Errors and omissions excepted. www.e-t-a.de 7
2210-T210-K0M1-H121-10A 价格&库存
很抱歉,暂时无法提供与“2210-T210-K0M1-H121-10A”相匹配的价格&库存,您可以联系我们找货
