2.1mm Center Pin DC Power Jacks
NEW
721A Series!
ELECTRICAL:
Voltage Rating:
Current Rating:
Insulation Resistance:
Contact Resistance:
Dielectric Withstanding:
NPB 648
SWITCHCRAFT QUALITY JACKS: NOW WITH A 2.1mm OPTION!
Switchcraft’s DC Power Jacks are the most trusted brand because of their
unbeatable Made-In-USA quality. For expanded compatibility, they are now
available with a 2.1mm center pin: the ideal mate for 2.1mm-style DC power
plugs!
30V DC resistive
5A (current carry only)
1,000 MΩ min.
0.01Ω max. (initial)
0.02Ω max. (after humidity/ durability)
0.10Ω max. (after salt spray)
500 VAC max.
MATERIAL
Bushing:
Terminals:
Hardware:
Electrical Insulators:
Contacts:
Copper Alloy, nickel plated
Copper Alloy, silver plated
P2439 nickel plated copper alloy hex nut
P2441 nickel plated steel flat washer
Thermoplastic, Phenolic
MECHANICAL/ ENVIRONMENTAL:
Life:
5,000 insertion/withdrawal cycles min
Operating Forces:
3 pound maximum insertion
4 ounce minimum withdrawal
Temperature Limits:
-40°C to 65°C (-40°F to 149°F)
Part
Number
Pin
Diameter
Bushing
Length
Contact
Type
Compatible
Mating Plugs
721A
PC721A
721RA
L721A
PCL721A
L721RA
2.1mm
2.1mm
2.1mm
2.1mm
2.1mm
2.1mm
5.5mm
5.5mm
5.5mm
8.1mm
8.1mm
8.1mm
Solder
Straight PC
Right Angle PC
Solder
Straight PC
Right Angle PC
762, 763, 762K, or 763K
767K, 768K
767K, 768K
767K, 768K
VISIT WWW.SWITCHCRAFT.COM FOR DRAWINGS AND DETAILED SPECIFICATIONS
很抱歉,暂时无法提供与“721RA”相匹配的价格&库存,您可以联系我们找货
