GBU808GTB
GBU808GTB
    SMCDIODESOLUTIONS(桑德斯)
    GBU808GTB
GBU808GTB 数据手册
GBU8005G THRU GBU810G Technical Data Data Sheet N1919, Rev. A GBU8005G THRU GBU810G Single-Phase 8.0A Glass Passivated Bridge Rectifier Features Glass passivated die construction Low forward voltage drop High current capability High surge current capability Plastic material-UL flammability 94V-0 This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request         GBU Circuit Diagram Mechanical Data      Case: GBU, Molded plastic Terminals: Plated leads solderable per MIL-STD-202, Method 208 Polarity: as marked on case Mounting Position: Any Lead Free: For RoHS / Lead Free Version Maximum Ratings:@TA=25°C unless otherwise specified Single Phase, half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. Type Number Symbol Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage VRRM VRWM VDC RMS Reverse Voltage VRMS Average forward rectified output current (Note 1) @TC = 90°C Non-Repetitive Peak Forward Surge Current 8.3ms Single half sine-wave superimposed on rated load (JEDEC Method) GBU 8005G 50 35 GBU 801G 5 3 GBU 802G GBU 804G GBU 806G GBU 808G GBU Units 810G 100 1 200 2 400 4 600 6 800 8 1000 1 V 70 7 140 1 280 2 420 4 560 5 700 1 V IO 8.0 A IFSM 200 A  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  GBU8005G THRU GBU810G Technical Data Data Sheet N1919, Rev. A Electrical Characteristics:@TA=25°C unless otherwise specified Type Number Symbol GBU 8005G GBU 801G GBU 802G GBU 804G GBU 806G GBU 808G GBU Units 810G VF 1.0 1.1 V IRM 5.0 500 µA I2t Rating for fusing (t
GBU808GTB 价格&库存
很抱歉,暂时无法提供与“GBU808GTB”相匹配的价格&库存,您可以联系我们找货
GBU808GTB
  • 1+6.67774
  • 5+4.67382
  • 20+4.21865
  • 100+3.35025
  • 500+3.12386
