DB3C-B1RC
DB3C-B1RC
    ZF
    检测开关 AC125V
DB3C-B1RC 数据手册
Subminiature Snap Switch Single Pole DB Series Features • • • • Precision switch with high repeat accuracy O Models available for operating temperature up to 120 C Various contact materials available RoHS compliant • • • Various aux actuators (can be retrofitted) Two mounting positions Mechanical life up to 15,000,000 operations 1 Standard Parts DB1C-A1AA DB1C-A1LB DB1C-A1LC DB1C-A1MC DB1C-A1RB DB1C-A1RC DB1C-B1AA DB1C-B1LB DB1C-B1LC DB1C-B1MC DB1C-B1RC DB1C-C1AA DB2C-A1AA DB2C-A1LB DB2C-A1LC DB2C-A1MC DB2C-A1RC DB2C-B1AA DB2C-B1LC DB2C-B1RC DB2C-C1AA DB3C-A1AA DB3C-A1LB DB3C-A1LC DB3C-A1RC DB3C-B1AA DB3C-B1LB DB3C-B1LC DB3C-B1MC DB3C-B1RC DB3C-C1AA 1 The part number configuration matrix below provides details to the part numbers above. For configurable part numbers that are not listed above, not listed in your region, or for custom part numbers, contact the factory or your distributor. DB1B-B1AA Part Number Breakdown Series DB Contact Rating2 O Configuration O O 120 C or 85 C Terminal Type millimeters (inches) 120 C A1 Solder, short 1 5 Amp A SPST NO B1 2.8 x 0.5 (0.110 x 0.020) QC, straight 2 10.1 Amp 0.1 Amp B SPST NC C1 1.3 x 0.5 (0.051 x 0.020) PCB, straight C SPDT D1 0.6 x 0.5 (0.024 x 0.020) PCB, straight 3 O O 85 C only 85 C D2 5 1 Amp E SPST NO D3 6 5 Amp F SPDT NC D4 7 10.1 Amp G SPDT D5 Actuator Type Spherical-head, no AA auxiliary actuator Radius, no auxiliary BA actuator For others, see actuator table at www.cherryswitches.com 0.6 x 0.5 (0.024 x 0.020) PCB, RH side w/location pins 0.6 x 0.5 (0.024 x 0.020) PCB, LH side w/location pins 0.6 x 0.5 (0.024 x 0.020) PCB, RH side 0.6 x 0.5 (0.024 x 0.020) PCB, LH side 2 UL current rating; see table below for complete details Electrical Specifications – Contact Ratings Contact 1 2 3 4 5 6 7 EN61058 6 A, 250 VAC; 0.1 A, 80 VDC 10 (1.5) A, 250 VAC; 0.1 A, 80 VDC 0.1 A, 250 VAC; 0.1 A, 80 VDC 4 A, 250 VAC 1 A, 250 VAC 6 A, 250 VAC 10 (1.5) A, 250 VAC UL file number E314201 www.cherryswitches.com Page 1 of 2, Last update 2015-04-06, Specifications subject to change without notice. UL1054 5 A, 125/250 VAC; 1 A, 48 VDC 10.1 A, 125/250 VAC; ¼ HP, 125 VAC 0.1 A, 125/250 VAC 4 A, 125/250 VAC; 1 A, 48 VDC 1 A, 125/250 VAC; 1 A, 48 VDC 5 A, 125/250 VAC 10.1 A, 125/250 VAC, ¼ HP, 125 VAC Mechanical Specifications Contact Gap Operating Force Total Travel Operating life < 3 mm (µ) 70 – 280 cN (model dependent, without actuator) 1.6 mm Operation Cycles Contact 1 2 3 4 5 6 7 EN61058 10,000 10,000 50,000 50,000 50,000 50,000 50,000 UL1054 6,000 6,000 100,000 6,000 6,000 6,000 6,000 Mechanical Life 15,000,000 10,000,000 15,000,000 15,000,000 15,000,000 15,000,000 10,000,000 Material Specifications Base Cover Actuator Contacts Terminals Auxiliary Actuator Switching parameters PET (UL 94 V-0) PBT (UL 94 V-0); PET (UL 94 V-0) PBT (UL 94 V-0) 120 OC, POM (UL 94 HB) 85 OC AgSnO2, AgNi, AuAgPt (Crosspoint) CuZn (silver-plated) Stainless Steel or plastic Complete chart available at www.cherryswitches.com Environmental Specifications Ambient Temperature Operating Force Total Travel Ingress Protection Dimensions mm (inches) www.cherryswitches.com Page 2 of 2, Last update 2015-04-06, Specifications subject to change without notice. -40 OC to 85 OC/120 OC (-40 OF to 185 OF/248 OF) 70 – 280 cN (model dependent, without actuator) 1.6 mm IP50
DB3C-B1RC 价格&库存
很抱歉,暂时无法提供与“DB3C-B1RC”相匹配的价格&库存,您可以联系我们找货
