LoRa/GPS Shield For Arduino
SKU 113990296
The LoRa/GPS Shield is an expension board for LoRa™/GPS for using with the Arduino.This
product is intended for those interested in developing LoRa™/GPS solutions.The LoRa/GPS
Shield is composed of LoRa/GPS Shield mother board and LoRa BEE.
In the LoRa part,the LoRa/GPS Shield is based on the SX1276/SX1278 transceiver.The
transceivers of the LoRa/GPS Shield feature the LoRa™ long range modem that provides ultra‐
long range spread spectrum communication and high interference immunity whilst minimising
current consumption. LoRa™ also provides significant advantages in both blocking and
selectivity over conventional modulation techniques, solving the traditional design compromise
between range,interference immunity and energy consumption.
In the GPS part,the add on L80 GPS (base on MTK MT3339) is designed for applications that use
a GPS connected via the serial ports to the arduino such as timing applications or general
applications that require GPS information.This GPS module can calculate and predict orbits
automatically using the ephemeris data (up to 3 days) stored in internal flash memory, so the
shield can fix position quickly even at indoor signal levels with low power consumption. With
AlwaysLocate™ technology, the LoRa/GPS Shield can adaptively adjust the on/off time to
achieve balance between positioning accuracy and power consumption according to the
environmental and motion conditions.The GPS also supports automatic antenna switching
function. It can achieve the switching between internal patch antenna and external active
antenna.Moreover, it keeps positioning during the switching process.
Frequency Band: 868 MHZ
Low power consumption
Compatible with Arduino Leonardo, Uno, Mega,etc.
LoRa™ Modem
FSK, GFSK, MSK, GMSK, LoRa™ and OOK modulation
Preamble detection
Baud rate configurable
Built‐in temperature sensor and low battery indicator
Excellent blocking immunity
Automatic RF Sense and CAD with ultra‐fast AFC
Support DGPS, SBAS(WAAS/EGNOS/MSAS/GAGAN)
GPS automatic switching between internal patch antenna and external active antenna
PPS VS. NMEA can be used in time service
Support SDK command
Built‐in LNA for better sensitivity
EASY™, advanced AGPS technology without external memory
AlwaysLocate™, an intelligent controller of periodic mode
GPS FLP mode, about 50% power consumption of normal mode
GPS support short circuit protection and antenna detection
LoRa Spec
168 dB maximum link budget.
+20 dBm ‐ 100 mW constant RF output vs.
+14 dBm high efficiency PA.
Programmable bit rate up to 300 kbps.
High sensitivity: down to ‐148 dBm.
Bullet‐proof front end: IIP3 = ‐12.5 dBm.
Excellent blocking immunity.
Low RX current of 10.3 mA, 200 nA register retention.
Fully integrated synthesizer with a resolution of 61 Hz.
FSK, GFSK, MSK, GMSK, LoRaTM and OOK modulation.
Built‐in bit synchronizer for clock recovery.
Preamble detection.
127 dB Dynamic Range RSSI.
Automatic RF Sense and CAD with ultra‐fast AFC.
Packet engine up to 256 bytes with CRC.
GPS Spec
Based on MT3339.
Power Acquisition:25mA,Power Tracking:20mA.
Compliant with GPS, SBAS.
Serial Interfaces UART: Adjustable 4800~115200 bps,Default: 9600bps.
Update rate:1Hz (Default), up to10Hz.
I/O Voltage:2.7V ~ 2.9V.
Protocols:NMEA 0183,PMTK.
Horizontal Position Accuracy:Autonomous
很抱歉,暂时无法提供与“113990296”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 20+271.6675220+35.13400
