Additional Resources:
Product Page
3D Model
date
04/26/2021
page
1 of 5
SERIES: SWI15-N │ DESCRIPTION: AC-DC POWER SUPPLY
FEATURES
compact design
up to 15 W continuous power
DoE Level VI compliant
no load power consumption < 0.075 W
universal input voltage range
over voltage, over current, and short circuit protections
UL/cUL and PSE safety approvals
Class II construction
IEC 62368 compliant
MODEL
SWI15-5-N
SWI15-9-N
output
voltage
output
current
output
power
ripple
and noise1
efficiency
level
(Vdc)
max
(A)
max
(W)
max
(mVp-p)
5
2
10
50
VI
9
1.4
12.6
90
VI
SWI15-12-N
12
1
12
100
VI
SWI15-15-N
15
1
15
100
VI
SWI15-24-N
24
0.63
15.1
100
VI
Notes:
1. At full load, nominal input, 20 MHz bandwidth oscilloscope, output terminated with 0.1 µF ceramic and 10 µF electrolytic capacitors.
2. All specifications are measured at Ta=25°C, nominal input voltage, and 75% rated output load unless otherwise specified.
PART NUMBER KEY
SWI15 - XX - N - XXX - CXX
Reserved for Custom
Configurations
Base Number
Output Voltage
AC Input Type:
North America
cui.com
DC Plug Type:
XXX = See output plug options
on page 4 for more details
Product Page
3D Model
CUI Inc │ SERIES: SWI15-N │ DESCRIPTION: AC-DC POWER SUPPLY
date 04/26/2021 │ page 2 of 5
INPUT
parameter
conditions/description
min
voltage
90
frequency
47
typ
current
inrush current
at 240 Vac, 25°C, cold start
leakage current
max
units
264
Vac
63
Hz
0.5
A
50
A
0.25
mA
0.075
W
max
units
OUTPUT
parameter
min
typ
voltage set point accuracy
at 60% load
±2
line regulation
measured from 100~240 Vac, full load
±1
load regulation
measured from 60~100% load and 60~20% load
5 Vdc output model
all other models
±4
±2
hold-up time
at 115 Vac
10
ms
PROTECTIONS
parameter
min
over voltage protection
hiccup mode, auto recovery
5 Vdc output model
9 Vdc output model
12 Vdc output model
15 Vdc output model
24 Vdc output model
over current protection
continuous, hiccup mode, auto recovery
typ
120
max
units
7.14
12.1
15.8
19.5
28.4
Vdc
Vdc
Vdc
Vdc
Vdc
140
max
units
SAFETY & COMPLIANCE
parameter
min
isolation voltage
input to output for 1 minute
isolation resistance
input to output
safety marks
UL (North America), PSE (Japan), FCC (USA)
safety approvals
62368: UL/cUL
60950: J (PSE)
safety class
Class II
EMI/EMC
FCC Part 15 Class B
J55022
MTBF
as per MIL-HDBK-217F at 115 Vac, full load, 25°C
RoHS
2011/65/EU
typ
3,000
4,242
Vac
Vdc
100
MΩ
330,000
hours
ENVIRONMENTAL
parameter
max
units
operating temperature
min
-20
40
°C
storage temperature
-20
85
°C
cui.com
typ
Product Page
3D Model
date 04/26/2021 │ page 3 of 5
MECHANICAL
parameter
dimensions
71.00 x 33.00 x 48.40 (2.795 x 1.299 x 1.906 inches)
min
inlet plug
North America
weight
units: mm [inch]
tolerance: X.XX: ±0.50 [±0.020]
DC CORD
cord length
Plug: 5.5 x 2.1 x 9.5 mm
Table 1
MODEL NO.
CABLE
CORD LENGTH
SWI15-5-N
20 AWG
1,800 mm ±50
SWI15-9-N
18 AWG
1,800 mm ±50
SWI15-12-N
24 AWG
1,800 mm ±50
SWI15-15-N
24 AWG
1,800 mm ±50
SWI15-24-N
24 AWG
1,800 mm ±50
cui.com
max
units
mm
100
MECHANICAL DRAWING
units: mm
typ
g
Product Page
3D Model
date 04/26/2021 │ page 4 of 5
DC PLUG TYPE PART NUMBER KEY
XXX
Plug Polarity:
P = Center Positive
Plug Code:
X = Choose a code from the
options below
Plug Angle:
“blank” = Straight
R = Right Angle
N = Center Negative
Plug Polarity
Code
Dimensions (mm)
Plug Angle
Center Pos.
Center Neg.
Option
Type
A
B
C
Straight
Right
5
Standard
5.5
2.1
9.5
6
Standard
5.5
2.5
9.5
7
Standard
3.5
1.35
9.5
8
Standard
3.8
1.35
9.5
Standard
3.8
1.05
9.5
9
N/A
N/A
ST
N/A
MUB
N/A
Note:
Stripped & Tinned
USB
Micro USB Type B
1. Contact CUI for additional plug options
cui.com
N/A
N/A
N/A
Product Page
3D Model
date 04/26/2021 │ page 5 of 5
REVISION HISTORY
rev.
description
date
1.0
initial release
03/08/2017
1.01
company logo updated
09/18/2020
1.02
updated safeties
10/02/2020
1.03
dc plug chart added
03/11/2021
safety marks updated
04/26/2021
1.04
The revision history provided is for informational purposes only and is believed to be accurate.
Headquarters
20050 SW 112th Ave.
Tualatin, OR 97062
800.275.4899
Fax 503.612.2383
cui.com
techsupport@cui.com
This device complies with part 15 of the FCC Rules. Operation is subject to the following two conditions:
(1) This device may not cause harmful interference, and
(2) this device must accept any interference received, including interference that may cause undesired operation.
CUI offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI reserves the right to make changes to the product at any time without notice. Information provided by CUI is believed to be accurate and reliable. However, no responsibility is
assumed by CUI for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a
life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness.
很抱歉,暂时无法提供与“SWI15-9-N-P5”相匹配的价格&库存,您可以联系我们找货
