USB3155-30-A
USB3155-30-A
    GCT
    USB3155-30-A
USB3155-30-A 数据手册
0.65 1.30±0.08 0.28±0.05 1.90 Specification: 1.52 2.15 1.40 4.50 5 1 G PCB Mount Orientation 0.22 0.43 4.52 2.60±0.08 5.00±0.2 5.47 H Material: Plastic Housing: Thermoplastic, UL94V-0, Black Contact Terminal: Copper Alloy Metallic Shell: Stainless Steel PCB Edge 0.60 Mylar F 8.00 9.88 0.65 4.00 4.75 Recommended PCB Layout 6.90+0.05 -0.02 6.20 ref. R0 .2 E 5 A Plating: Underplating: Ni overall 50µ" min. Contact Terminal: Contact Area: See ordering grid Solder area : Gold Flash Metallic Shell: Matte Tin 50µ" min. PCB Thickness = 0.6mm 2.51 (Offset) 7.50+0.10 -0.30 Solder Area Component Outline 0.90 A 1.30 2.60 2.47 5.32 0.50+0.03 -0.02 Mechanical & Environment : Operating Temperature: -30°C to +85°C Mating Force: 35N max. Unmating Force: 10N min. Durability: 10,000 cycles 2.10+0.20 -0.05 2.70+0.05 -0.08 Ordering Grid 3.50±0.10 4.00 2.51 (Offset) 9.88 1.05±0.20 ° 60 C USB3155 Section A-A Designed to comply with physical, electrical and environmental requirements of Micro USB Standard (USB2.0). 0.80 B Electrical: Voltage Rating: 30 V AC max. Current Rating: Signal Pins (2,3,4) 1.0 A Power Pins (1,5) 1.8 A Dielectric Withstanding: 500V AC Insulation Resistance: 1000 MΩ min. Contact Resistance: 30 mΩ max. 2.55±0.10 0.51 1.85+0.08 -0.02 D 0.86 5 1 2.49 0.10 Contact Plating 30 = 30µ" Gold Product Description USB3155 Micro USB Receptacle, Type B SMT, Horizontal, Mid-Bottom Mount 9th April 2015 By Detail 2 3 4 Packing Options A = Tape & Reel w/Film Part Number 7.90 1 Request Samples and Quotation (1,500 per reel) Drawing Date A A 30 Revision Date 5 CC Tolerances (Except as Noted) USB3155 B PCN B3 20/03/19 X.X ± 0.30 X.X° ± 2° X.XX ± 0.20 X.XX° ± 1° X.XXX ± 0.10 X.XXX° ± 0.5° Length Angle 6 Units: Metric (mm) C 3rd Angle Projection 7 This drawing is confidential and copyright of Global Connector Technology, Ltd (GCT). This drawing must not be copied or disclosed without written consent. E & OE www.gct.co Not to Scale Drawn By AJO 8 Sheet No. 1/2 H 24.00 G 24.00 12.00 First Approximately 20 pcs Empty Carrier The End Approximately 20 pcs Empty Carrier Packing 1500 pcs Product 3.30 F 200mm The Direction Of Product Packing Vacuum Bag Cover Tape (450x490x0.15) Protection Tape Desiccant 1PC Carrier Tape Total 3 Layers Detail "F" 1500Pcs/Reel Ø2 3 6 ° 120 D OUTER Ø330 Vacuum Bag E Plastic Reel P S Ø13.5 120° Round Sproket Hole 24+4 Detail :F-F Carton Pull out Direction Pull Out Direction 160mm 10° C 35 0m 0m 35 m m B Part Number Pcs./Reel Reels/Carton Pcs./Carton USB3155 1500 3 4500 Part Number Product Description USB3155 Micro USB Receptacle, Type B SMT, Horizontal, Mid-Bottom Mount Drawing Date 9th April 2015 A By Detail Revision Date 1 2 3 4 5 CC Tolerances (Except as Noted) USB3155 B PCN B3 20/03/19 X.X ± 0.50 X.X° ± 2° X.XX ± 0.30 X.XX° ± 1° X.XXX ± 0.20 X.XXX° ± 0.5° Length Angle 6 Units: Metric (mm) C 3rd Angle Projection 7 This drawing is confidential and copyright of Global Connector Technology, Ltd (GCT). This drawing must not be copied or disclosed without written consent. E & OE www.gct.co Not to Scale Drawn By AJO 8 Sheet No. 2/2
USB3155-30-A 价格&库存
很抱歉,暂时无法提供与“USB3155-30-A”相匹配的价格&库存,您可以联系我们找货
USB3155-30-A
    USB3155-30-A
    • 1+6.078591+0.78681
    • 10+5.1322010+0.66431
    • 25+4.8139025+0.62311
    • 50+4.5814050+0.59302
    • 100+4.36306100+0.56476
    • 250+4.08907250+0.52929
    • 500+3.89381500+0.50402
    库存:28956
    USB3155-30-A
    • 1500+3.603191500+0.46640
    • 3000+3.431193000+0.44414
    • 4500+3.334444500+0.43161
    • 7500+3.216467500+0.41634
    • 10500+3.1410410500+0.40658
    • 15000+3.0630515000+0.39648
    库存:28956
    USB3155-30-A
    • 50+4.5816250+0.59305
    • 100+4.36317100+0.56477
    • 250+4.08920250+0.52931
    • 500+3.89394500+0.50403
    库存:28956
