Additional Resources:
Product Page
date
01/27/2022
page
1 of 4
MODEL: CBL-UA-ST-1 │ DESCRIPTION: USB CABLE
FEATURES
USB 2.0
type A male to stripped and tinned
1 meter
PVC jacket
SPECIFICATIONS
parameter
conditions/description
min
rated voltage
typ
max
units
Vdc
rated current
1
A
conductor resistance
5
Ω
insulation resistance
at 300 Vdc
10
operating temperature
storage temperature
flammability rating
UL94V-0
RoHS
yes
cuidevices.com
MΩ
-20
80
°C
-20
80
°C
Product Page
CUI Devices │ MODEL: CBL-UA-ST-1 │ DESCRIPTION: USB CABLE
date 01/27/2022│ page 2 of 4
MECHANICAL DRAWING
units: mm
tolerance:
X.X ±0.5 mm
X.XX ±0.3 mm
X.XXX ±0.1 mm
unless otherwise noted
critical dimension: *
ITEM
DESCRIPTION
MATERIAL
PLATING/COLOR
1
cable
UL 2725
OD: 4.7±0.2 mm
PVC
black
2
connector 1
USB 2.0 Type A
insulator: white
shell: nickel
term.: gold flash
3
over mold
PVC 45P
black
cuidevices.com
Product Page
date 01/27/2022│ page 3 of 4
PACKAGING
units: mm
Carton Size: 546 x 355 x 186 mm
Carton QTY: 100 pcs
cuidevices.com
Product Page
date 01/27/2022│ page 4 of 4
REVISION HISTORY
rev.
description
date
1.0
initial release
12/21/2018
1.01
brand update
02/18/2020
1.02
modified overmold design, updated packaging
02/18/2021
modified design, changed factory
01/27/2022
1.03
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no
responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any
component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or
effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“CBL-UA-ST-1”相匹配的价格&库存,您可以联系我们找货
