PESD3V3L4BHCYL
PESD3V3L4BHCYL
    NEXPERIA(安世)
    SOT8006
    PESD3V3L4BHCYL
PESD3V3L4BHCYL 数据手册
PESD3V3L4BHC 4-fold bidirectional ESD protection array 7 June 2019 Product data sheet 1. General description 4-fold bidirectional ElectroStatic Discharge (ESD) protection array designed to protect up to four lines from the damage caused by ESD and other transients. The device is housed in a leadless extremely thin small DFN1308-6 (SOT8006) Surface-Mounted Device (SMD) plastic package. 2. Features and benefits • • • • • Bidirectional ESD protection of up to 4 lines Very high surge robustness; IPP = 6 A for 8/20 µs pulse Very low clamping voltage: VCL = 7.3 V typ. for 6 A 8/20 µs pulse ESD protection up to 20 kV Very low dynamic resistance Rdyn = 0.2 Ω (TLP) 3. Applications ESD protection for low-speed lines in portable communication, consumer devices and computing devices. 4. Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VRWM reverse standoff voltage Tamb = 25 °C - - 3.3 V IPPM rated peak pulse current tp = 8/20 µs; Tamb = 25 °C - - 6 A Vt1 trigger voltage Tamb = 25 °C - 6.7 - V [1] Device stressed with 8/20 µs exponential decay waveform according to IEC 61000-4-5. [1] PESD3V3L4BHC Nexperia 4-fold bidirectional ESD protection array 5. Pinning information Table 2. Pinning information Pin Symbol Description 1 K1 cathode (diode 1) 2 CC common cathode 3 K2 cathode (diode 2) 4 K3 cathode (diode 3) 5 CC common cathode 6 K4 cathode (diode 4) Simplified outline Graphic symbol 1 2 3 6 5 4 DFN1308-6 (SOT8006) K1 K4 CC CC K2 K3 aaa-030022 6. Ordering information Table 3. Ordering information Type number Package PESD3V3L4BHC Name Description Version DFN1308-6 DFN1308-6, plastic, leadless extremely thin small package; 6 terminals; body 1.3 x 0.8 x 0.38 mm SOT8006 7. Marking Table 4. Marking codes Type number Marking code PESD3V3L4BHC L4 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134) Symbol Parameter Conditions Min Max Unit IPPM rated peak pulse current tp = 8/20 µs; Tamb = 25 °C - 6 A Tj junction temperature - 150 °C Tamb ambient temperature -55 150 °C Tstg storage temperature -65 150 °C [1] ESD maximum ratings VESD [1] [2] electrostatic discharge voltage IEC 61000-4-2 (contact discharge) [2] - 20 kV IEC 61000-4-2 (air discharge) [2] - 20 kV Device stressed with 8/20 µs exponential decay waveform according to IEC 61000-4-5. Device stressed with ten non-repetitive ESD pulses. PESD3V3L4BHC Product data sheet All information provided in this document is subject to legal disclaimers. 7 June 2019 © Nexperia B.V. 2019. All rights reserved 2 / 11 PESD3V3L4BHC Nexperia 4-fold bidirectional ESD protection array 001aaa630 120 IPP 100 % 100 % IPP; 8 µs IPP (%) 80 90 % e-t 50 % IPP; 20 µs 40 10 % 0 Fig. 1. 0 10 20 30 t (µs) 8/20 µs pulse waveform according to IEC 61000-4-5 t tr = 0.6 ns to 1 ns 40 30 ns 60 ns Fig. 2. 001aaa631 ESD pulse waveform according to IEC 61000-4-2 9. Characteristics Table 6. Characteristics Symbol Parameter Conditions Min Typ Max Unit VRWM reverse standoff voltage Tamb = 25 °C - - 3.3 V IRM reverse leakage current VRWM = 3.3 V; Tamb = 25 °C - 3 100 nA Cd diode capacitance f = 1 MHz; VR = 0 V; Tamb = 25 °C - 7.2 9 pF VCL clamping voltage IPPM = 1 A; tp = 8/20 µs; Tamb = 25 °C [1] - 5.9 - V IPPM = 6 A; tp = 8/20 µs; Tamb = 25 °C [1] - 7.3 8.5 V [2] - 0.2 - Ω - 6.7 - V 4 - - V Rdyn dynamic resistance IR = 10 A; Tamb = 25 °C Vt1 trigger voltage Tamb = 25 °C Vh holding voltage [1] [2] Device stressed with 8/20 µs exponential decay waveform according to IEC 61000-4-5. Non-repetitive current pulse, Transmission Line Pulse (TLP); square pulse; ANSI/ESD STM5.5.1-2008. PESD3V3L4BHC Product data sheet All information provided in this document is subject to legal disclaimers. 7 June 2019 © Nexperia B.V. 2019. All rights reserved 3 / 11 PESD3V3L4BHC Nexperia 4-fold bidirectional ESD protection array IPPM IPP aaa-029986 8 Cd (pF) 6 IR IRM -VCL -VBR -VRWM 4 -IRM -IR VRWM VBR VCL 2 - + 0 -IPP -IPPM Fig. 3. 006aab325 V-I characteristics for a bidirectional ESD protection diode -2 0 2 VR (V) 4 f = 1 MHz; Tamb = 25 °C Fig. 4. Diode capacitance as a function of reverse voltage; typical values aaa029987 40 -4 aaa029988 0 IPP (A) IPP (A) 30 -10 20 -20 Rdyn = 0.2 Ω 10 0 0 2 4 6 8 10 12 VCL (V) -40 -14 14 tp = 100 ns; Transmission Line Pulse (TLP) Fig. 5. Rdyn = 0.2 Ω -30 Product data sheet -10 -8 -6 -4 -2 VCL (V) 0 tp = 100 ns; Transmission Line Pulse (TLP) Positive clamping voltage (TLP); typical values PESD3V3L4BHC -12 Fig. 6. Negative clamping voltage (TLP); typical values All information provided in this document is subject to legal disclaimers. 7 June 2019 © Nexperia B.V. 2019. All rights reserved 4 / 11 PESD3V3L4BHC Nexperia 4-fold bidirectional ESD protection array ESD TESTER 4 GHz DIGITAL OSCILLOSCOPE RG 223/U 50 Ω coax Rd 40 dB ATTENUATOR Cs 50 Ω DUT (DEVICE UNDER TEST) IEC 61000-4-2 ed.2 Cs = 150 pF; Rd = 330 Ω 10 2 V (kV) 8 V (kV) 0 6 -2 4 -4 2 -6 0 -8 -2 -10 0 10 20 30 40 50 t (ns) 60 -10 -10 70 unclamped +8 kV ESD pulse waveform (IEC 61000-4-2 network) 0 10 20 30 40 50 t (ns) 60 70 unclamped -8 kV ESD pulse waveform (IEC 61000-4-2 network) aaa-003952 Fig. 7. ESD clamping test setup and waveforms aaa-029989 100 VCL (V) VCL (V) 60 20 VCL at 30 ns = 7.0 V 20 -60 -10 -60 10 30 50 t (ns) -100 -10 70 Clamped +8 kV pulse waveform (IEC 61000-4-2 network) PESD3V3L4BHC Product data sheet VCL at 30 ns = -6.8 V -20 -20 Fig. 8. aaa-029990 60 Fig. 9. 30 50 t (ns) 70 Clamped -8 kV pulse waveform (IEC 61000-4-2 network) All information provided in this document is subject to legal disclaimers. 7 June 2019 10 © Nexperia B.V. 2019. All rights reserved 5 / 11 PESD3V3L4BHC Nexperia 4-fold bidirectional ESD protection array 10. Application information The device is designed for protection of up to 4 bidirectional data lines from the damage caused by ESD and surge pulses. The device is suitable on lines where the signal polarities are above or below ground. data- or transmission lines DUT 1 6 2 5 3 4 006aab335 Fig. 10. Application diagram Circuit board layout and protection device placement Circuit board layout is critical for the suppression of ESD, Electrical Fast Transient (EFT) and surge transients. The following guidelines are recommended: • • • • • • • • PESD3V3L4BHC Product data sheet Place the device as close to the input terminal or connector as possible Minimize the path length between the device and the protected line. Keep parallel signal paths to a minimum. Avoid running protected conductors in parallel with unprotected conductors. Minimize all Printed-Circuit Board (PCB) conductive loops including power and ground loops. Minimize the length of the transient return path to ground. Avoid using shared transient return paths to a common ground point. Use ground planes whenever possible. For multilayer PCBs, use ground vias. All information provided in this document is subject to legal disclaimers. 7 June 2019 © Nexperia B.V. 2019. All rights reserved 6 / 11 PESD3V3L4BHC Nexperia 4-fold bidirectional ESD protection array 11. Package outline DFN1308-6, plastic, leadless extremely thin small package; 6 terminals; body 1.3 x 0.8 x 0.38 mm A D SOT8006 B E pin 1 index area detail X (optional side view) (6x) seating plane X A1 y C C A2 A e G x 45° y1 C e 1 2 3 L (6x) 6 5 4 b (6x) v 0 C A B 0.5 1 mm scale Dimensions (mm are the original dimensions) Unit max nom min mm A A1 A2 b D E e G L u v y y1 0.43 0.38 0.33 0.05 0.02 0.00 0.18 0.13 0.08 0.23 0.18 0.13 1.40 1.30 1.20 0.90 0.80 0.70 0.45 0.11 0.08 0.05 0.30 0.25 0.20 0.1 0.1 0.05 0.05 sot8006_po Outline version SOT8006 References IEC JEDEC JEITA European projection Issue date 19-05-06 --- Fig. 11. Package outline DFN1308-6 (SOT8006) PESD3V3L4BHC Product data sheet All information provided in this document is subject to legal disclaimers. 7 June 2019 © Nexperia B.V. 2019. All rights reserved 7 / 11 PESD3V3L4BHC Nexperia 4-fold bidirectional ESD protection array 12. Soldering Footprint information for reflow soldering of DFN1308-6 package SOT8006 1.6 0.28 0.17 0.18 0.27 0.45 0.5 0.45 0.4 1.05 1.35 0.15 0.25 1.08 recommend stencil thickness: 0.1 mm occupied area solder resist solder lands solder paste Dimensions in mm Issue date 19-05-06 sot8006_fr Fig. 12. Reflow soldering footprint for DFN1308-6 (SOT8006) PESD3V3L4BHC Product data sheet All information provided in this document is subject to legal disclaimers. 7 June 2019 © Nexperia B.V. 2019. All rights reserved 8 / 11 PESD3V3L4BHC Nexperia 4-fold bidirectional ESD protection array 13. Revision history Table 7. Revision history Data sheet ID Release date Data sheet status Change notice Supersedes PESD3V3L4BHC v.1 Product data sheet - - PESD3V3L4BHC Product data sheet 20190607 All information provided in this document is subject to legal disclaimers. 7 June 2019 © Nexperia B.V. 2019. All rights reserved 9 / 11 PESD3V3L4BHC Nexperia 4-fold bidirectional ESD protection array 14. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal PESD3V3L4BHC Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. 7 June 2019 © Nexperia B.V. 2019. All rights reserved 10 / 11 PESD3V3L4BHC Nexperia 4-fold bidirectional ESD protection array Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Quick reference data....................................................1 5. Pinning information......................................................2 6. Ordering information....................................................2 7. Marking.......................................................................... 2 8. Limiting values............................................................. 2 9. Characteristics.............................................................. 3 10. Application information............................................. 6 11. Package outline.......................................................... 7 12. Soldering..................................................................... 8 13. Revision history..........................................................9 14. Legal information......................................................10 © Nexperia B.V. 2019. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 7 June 2019 PESD3V3L4BHC Product data sheet All information provided in this document is subject to legal disclaimers. 7 June 2019 © Nexperia B.V. 2019. All rights reserved 11 / 11
PESD3V3L4BHCYL 价格&库存
很抱歉,暂时无法提供与“PESD3V3L4BHCYL”相匹配的价格&库存,您可以联系我们找货
PESD3V3L4BHCYL
  • 10000+0.8211010000+0.10629
  • 20000+0.8020620000+0.10382
  • 30000+0.7925230000+0.10259
  • 50000+0.7819650000+0.10122
  • 70000+0.7757970000+0.10042
  • 100000+0.76985100000+0.09965
库存:13353
PESD3V3L4BHCYL
  • 1+2.115431+0.27382
  • 10+1.4583610+0.18877
  • 25+1.2936225+0.16745
  • 100+1.10622100+0.14319
  • 250+1.01677250+0.13161
  • 500+0.96323500+0.12468
  • 1000+0.918971000+0.11896
  • 2500+0.894922500+0.11584
库存:13353
