CMM-2718AB-383161-TR 数据手册
Additional Resources:
Product Page
3D Model
PCB Footprint
date
01/16/2020
page
1 of 5
MODEL: CMM-2718AB-383161-TR │ DESCRIPTION: MEMS MICROPHONE
FEATURES
analog
small package
reflow solder compatible
omnidirectional
ELECTRICAL
parameter
conditions/description
directivity
omnidirectional
sensitivity (S)
at 94 dB SPL, 1 kHz
supply voltage (VDD)
min
typ
max
units
-41
-38
-35
dB
2.0
3.6
1.6
current consumption (IDSS)
VDD = 2.0 V
sensitivity reduction
VDD = 3.6 ~ 1.6 V
160
-0.5
frequency (f)
100
V
µA
dB
10,000
Hz
signal to noise ratio (S/N)
at 94 dB SPL, 1 kHz (A-weighted)
61
dBA
total harmonic distortion (THD)
at 94 dB SPL, 1 kHz
0.2
acoustic overload point (AOP)
at 10% THD, 1 kHz
124
output impedance (Zout)
at 1 kHz
Notes:
dB SPL
300
Ω
2. All specifications measured at 23±2°C, humidity at 55±20%, unless otherwise noted.
ENVIRONMENTAL
parameter
min
operating temperature
storage temperature
in packaging
RoHS
yes
max
units
-40
typ
105
°C
-40
85
°C
max
units
MECHANICAL
parameter
dimensions
2.75 x 1.85 x 0.95
acoustic port
bottom
terminals
surface mount
min
typ
mm
weight
0.02
cuidevices.com
g
Product Page
3D Model
PCB Footprint
CUI Devices │ MODEL: CMM-2718AB-383161-TR │ DESCRIPTION: MEMS MICROPHONE
date 01/16/2020 │ page 2 of 5
MECHANICAL DRAWING
units: mm
tolerance: ±0.1 mm
VDD
2
output
3
GND
5
ķ
ĸ ķ
Ĺ
Recommended Vacuum Nozzle Pickup
Top View
Recommended PCB Layout
Top View
cuidevices.com
ķ ĸ
Ĺ
FUNCTION
1
TERM.
TERMINAL CONNECTIONS
Product Page
3D Model
PCB Footprint
date 01/16/2020 │ page 3 of 5
FREQUENCY RESPONSE CURVE
APPLICATION CIRCUIT
VDD
0.1 µF
R2
Term. 1 (VDD)
Term. 2
(Output)
R1
ˉ
0.1 µF
Dashed Section
Represents
MEMS
Microphone
ˇ
External Gain = -R2/R1
(Set By User)
Term. 3
(GND)
cuidevices.com
Product Page
3D Model
PCB Footprint
date 01/16/2020 │ page 4 of 5
SOLDERABILITY
parameter
reflow soldering
see reflow profile
min
typ
max
units
260
°C
max
units
85
°C
Note:
1. Vacuuming over acoustical hole is not allowed.
2. Not suitable for wash process.
3. Not recommended to exceed 5 reflow cycles.
20~40 s
260
Temperature (°C)
3°C/s max ramp up
6°C/s max ramp down
217
60~150 s
200
150
60~180 s
25
480 s max
Time (sec)
PACKAGING
parameter
min
reel storage
at relative humidity
CMM-2718AB-383161-TR 价格&库存
很抱歉,暂时无法提供与“CMM-2718AB-383161-TR”相匹配的价格&库存,您可以联系我们找货
