3.0SMI SERIES
Technical Data
Data Sheet N1804 Rev. A
3.0SMI SERIES
SURFACE MOUNT TRANSIENT VOLTAGE SUPPRESSOR
Features
SMC
Circuit Diagram
Mechanical Data
Unipolar
Glass Passivated Die Construction
3000W Peak Pulse Power Dissipation
5.0V- 170V Standoff Voltage
Uni- and Bi-Directional Versions Available
Excellent Clamping Capability
Fast Response Time
Plastic Case Material has UL Flammability
Classification Rating 94V-O
Terminals finish: 100% Pure Tin
This is a Pb − Free Device
All SMC Parts are Traceable to the Wafer Lot
Additional testing can be offered upon request
Case: SMC Low Profile Molded Plastic
Terminals: Solder Plated , Solderable per MIL-STD
750, Method 2026
Polarity: Cathode Band or Cathode Notch
Weight:0.21 grams(approx.)
Bipolar
Maximum Ratings and Thermal Characteristics@TA=25°C unless otherwise specified
Parameter
Symbol
Value
Units
PPPM
3000
W
IFSM
300
A
Typical Thermal Resistance Junction to Lead
RθJL
15
°C/W
Typical Thermal Resistance Junction to Ambient
RθJA
75
°C/W
TJ,TSTG
-55 to 150
°C
Peak Pulse Power Dissipation on 10/1000us waveform
(NOTE 1, 2, Fig.1)
Peak Forward Surge Current, 8.3ms
Single Half Sine Wave (Note 2),(Note 3)
Operating Junction and Storage Temperature Range
Notes: 1. Non-repetitive current pulse , per Fig. 3 and derated above TA = 25°C per Fig. 2.
2. Mounted on 8.0mm2 copper pads to each terminal
3. Measured on 8.3ms single half sine wave or equivalent square wave, duty cycle=4pulses per minute maximum.
China - Germany - Korea - Singapore - United States
http://www.smc-diodes.com - sales@ smc-diodes.com
3.0SMI SERIES
Technical Data
Electrial Characteristics@TA=25°C unless otherwise specified
DEVICE
MARKING
CODE
UNI-POLAR
BI-POLAR
UNI
BI
REVER
SE
STANDOFF
VOLTA
GE
VRWM
(V)
BREAKD
OWN
VOLTAG
E
VBR (V)
MIN.
@IT
BREAKDO
WN
VOLTAGE
VBR (V)
MAX.
@IT
TEST
CURR
ENT
IT(MA)
MAXMUM
CLAMPIN
G
VOLTAGE
@IPP
VC(V)
PEAK
PULSE
CURRENT
IPP(A)
REVERSE
LEAKAGE
@VRWM
IR(uA)
3.0SMI5.0A
3.0SMI5.0CA
HDE
IDE
5
6.4
7
10
9.2
326.1
2000
3.0SMI6.0A
3.0SMI6.0CA
HDG
IDG
6
6.67
7.37
10
10.3
291.3
2000
3.0SMI6.5A
3.0SMI6.5CA
HDK
IDK
6.5
7.22
7.98
10
11.2
267.9
1000
3.0SMI7.0A
3.0SMI7.0CA
HDM
IDM
7
7.78
8.6
10
12
250
400
3.0SMI7.5A
3.0SMI7.5CA
HDP
IDP
7.5
8.33
9.21
1
12.9
232.6
200
3.0SMI8.0A
3.0SMI8.0CA
HDR
IDR
8
8.89
9.83
1
13.6
220.6
100
3.0SMI8.5A
3.0SMI8.5CA
HDT
IDT
8.5
9.44
10.4
1
14.4
208.3
50
3.0SMI9.0A
3.0SMI9.0CA
HDV
IDV
9
10
11.1
1
15.4
194.8
3.0SMI10A
3.0SMI10CA
HDX
IDX
10
11.1
12.3
1
17
176.5
5
3.0SMI11A
3.0SMI11CA
HDZ
IDZ
11
12.2
13.5
1
18.2
164.8
5
3.0SMI12A
3.0SMI12CA
HEE
IEE
12
13.3
14.7
1
19.9
150.8
5
3.0SMI13A
3.0SMI13CA
HEG
IEG
13
14.4
15.9
1
21.5
139.5
5
3.0SMI14A
3.0SMI14CA
HEK
IEK
14
15.6
17.2
1
23.2
129.3
5
3.0SMI15A
3.0SMI15CA
HEM
IEM
15
16.7
18.5
1
24.4
123
5
3.0SMI16A
3.0SMI16CA
HEP
IEP
16
17.8
19.7
1
26
115.4
5
3.0SMI17A
3.0SMI17CA
HER
IER
17
18.9
20.9
1
27.6
108.7
5
3.0SMI18A
3.0SMI18CA
HET
IET
18
1
29.2
102.7
5
3.0SMI20A
3.0SMI20CA
HEV
IEV
24.5
1
32.4
92.6
5
3.0SMI22A
3.0SMI22CA
HEX
IEX
22
24.4
26.9
1
35.5
84.5
5
3.0SMI24A
3.0SMI24CA
HEZ
IEZ
24
26.7
29.5
1
38.9
77.1
5
3.0SMI26A
3.0SMI26CA
HFE
IFE
26
28.9
31.9
1
42.1
71.3
5
3.0SMI28A
3.0SMI28CA
HFG
IFG
28
31.1
34.4
1
45.4
66.1
5
3.0SMI30A
3.0SMI30CA
HFK
IFK
30
33.3
36.8
1
48.4
62
5
3.0SMI33A
3.0SMI33CA
HFM
IFM
33
36.7
40.6
1
53.3
56.3
5
3.0SMI36A
3.0SMI36CA
HFP
IFP
36
40
44.2
1
58.1
51.6
5
3.0SMI40A
3.0SMI40CA
HFR
IFR
40
44.4
49.1
1
64.5
46.5
5
3.0SMI43A
3.0SMI43CA
HFT
IFT
43
47.8
52.8
1
69.4
43.2
5
3.0SMI45A
3.0SMI45CA
HFV
IFV
45
50
55.3
1
72.7
41.3
5
3.0SMI48A
3.0SMI48CA
HFX
IFX
48
53.3
58.9
1
77.4
38.8
5
3.0SMI51A
3.0SMI51CA
HFZ
IFZ
51
56.7
62.7
1
82.4
36.4
5
3.0SMI SERIES
Technical Data
DEVICE
MARKING
CODE
UNI-POLAR
BI-POLAR
UNI
BI
REVERS
E
STANDOFF
VOLTAG
E
VRWM (V)
BREAKD
OWN
VOLTAGE
VBR (V)
MIN.
@IT
BREAKDOW
N
VOLTAGE
VBR (V)
MAX.
@IT
TEST
CURR
ENT
IT(MA)
MAXMUM
CLAMPIN
G
VOLTAGE
@IPP
VC(V)
PEAK
PULSE
CURR
ENT
IPP(A)
REVERS
E
LEAKAG
E
@VRWM
IR(uA)
3.0SMI54A
3.0SMI54CA
HGE
IGE
54
60
66.3
1
87.1
34.4
5
3.0SMI58A
3.0SMI58CA
HGG
IGG
58
64.4
71.2
1
93.6
32.1
5
3.0SMI60A
3.0SMI60CA
HGK
IGK
60
66.7
73.7
1
96.8
31
5
3.0SMI64A
3.0SMI64CA
HGM
IGM
64
71.1
78.6
1
103
29.1
5
3.0SMI70A
3.0SMI70CA
HGP
IGP
70
77.8
86
1
113
26.5
5
3.0SMI75A
3.0SMI75CA
HGR
IGR
75
83.3
92.1
1
121
24.8
5
3.0SMI78A
3.0SMI78CA
HGT
IGT
78
86.7
95.8
1
126
23.8
5
3.0SMI85A
3.0SMI85CA
HGV
IGV
85
94.4
104
1
137
21.9
5
3.0SMI90A
3.0SMI90CA
HGX
IGX
90
100
111
1
146
20.5
5
3.0SMI100A
3.0SMI100CA
HGZ
IGZ
100
111
123
1
162
18.5
5
3.0SMI110A
3.0SMI110CA
HHE
IHE
110
122
135
1
177
16.9
5
3.0SMI120A
3.0SMI120CA
HHG
IHG
120
133
147
1
193
15.5
5
3.0SMI130A
3.0SMI130CA
HHK
IHK
130
144
159
1
209
14.4
5
3.0SMI150A
3.0SMI150CA
HHM
IHM
150
167
185
1
243
12.3
5
3.0SMI160A
3.0SMI160CA
HHP
IHP
160
178
197
1
259
11.6
5
3.0SMI170A
3.0SMI170CA
HHR
IHR
170
189
209
1
275
10.9
5
For bidirectional type having VRWM of 10 volts and less, the IR limit is double.
For parts without A , the VBR is ± 10%
3.0SMI SERIES
Technical Data
Ratings and Characteristics Curves
3.0SMI SERIES
Technical Data
Ordering Information
Device
3.0SMI5.0A
THRU
3.0SMI170CA
3.0SMI5.0ATR
THRU
3.0SMI170CATR
Marking Diagram
Package
Plating
Shipping
SMC
(Pb-Free)
Pure Sn
3000pcs / reel
SMC
(Pb-Free)
Pure Sn
Where XXXXX is YYWWL
HDE/IDE
YY
WW
L
3.0SMI5.0A
= Marking code
= Year
= Week
= Lot Number
3000pcs / reel
For information on tape and reel specifications, including part
orientation and tape sizes, please refer to our tape and reel
packaging specification.
Autions:Molding resin
Epoxy resin UL:94V-0
3.0SMI5.0CA
Mechanical Dimensions SMC
SMC/DO-214AB
Dim.
Min.
Max.
Min.
Max.
A
5.59
6.22
0.220
0.245
B
6.60
7.11
0.260
0.280
C
2.90
3.20
0.114
0.126
D
0.152
0.305
0.006
0.012
E
7.75
8.13
0.305
0.320
F
2.00
2.95
0.079
0.116
G
0.203
0.008
H
0.76
1.52
0.030
0.060
In Millimeters
Soldering Pad Layout (Millimeters )
In inches
3.0SMI SERIES
Technical Data
Carrier Tape Specification SMC
SYMBOL
A
B
C
d
E
F
P
P0
P1
T
W
Millimeters
Min.
Max.
5.90
8.20
2.40
1.40
1.40
7.60
7.90
3.90
3.90
15.80
6.10
8.40
2.60
1.60
1.60
7.70
8.10
4.10
4.10
0.600
16.20
DISCLAIMER:
1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product
characteristics. Before ordering, purchasers are advised to contact the SMC Diode Solutions sales department for the latest version of the
datasheet(s).
2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment,
medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by
means of users’ fail-safe precautions or other arrangement .
3- In no event shall SMC Diode Solutions be liable for any damages that may result from an accident or any other cause during operation
of the user’s units according to the datasheet(s). SMC Diode Solution assumes no responsibility for any intellectual property claims or any
other problems that may result from applications of information, products or circuits described in the datasheets.
4- In no event shall SMC Diode Solutions be liable for any failure in a semiconductor device or any secondary damage resulting from use
at a value exceeding the absolute maximum rating.
5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC Diode Solutions.
6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC
Diode Solutions.
7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will
hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third
party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and
regulations..
很抱歉,暂时无法提供与“3.0SMI10CATR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+7.524211+0.94355
- 5+4.109035+0.51528
- 25+2.7393625+0.34352
- 100+2.46903100+0.30962
- 500+2.18968500+0.27459
- 3000+1.982433000+0.24860
- 国内价格
- 1+6.72186
- 5+3.64661
- 25+2.42827
- 63+1.87372
- 172+1.77289
- 3000+1.75609
