5.65
H
Designed to comply with physical, electrical and environmental
requirements of Micro USB Standard (USB2.0).
PCB Mount Orientation
G
Pin 1
Pin 5
2.6
0.65
7.4
0.4
2.15
5.5
0.49
0.45
1.45
R0.23
4
4.75
E
2.68
F
1.55
2.15
1.35
ø0.55
PCB EDGE
1.05
5.65
6.20
Specifications 规格:
RECOMMENDED P.C.B LAYOUT
7.8 REF
Materials 材料:
Plastic Housing 塑胶外壳: LCP, UL94V-0, Black; LCP, UL94V-0 黑色
Contact Terminal 接触端子: Copper Alloy 铜合金
Metallic Shell 金属外壳: Stainless Steel 不锈钢 SUS 304 T = 0.25mm
GENERAL TOLERANCE: ±0.05
AS VIEWED FROM COMPONENT SIDE
Solder Area
Component Outline
0.50
2.7
2.35
1.85
D
Plating电镀:
Underplating 底层电镀: 50µ" Nickel, 50µ" 镍
Finish表面处理:Contact Area 接触面积: 30µ" Gold plating, 30µ" 镀金
Solder Tails 焊接末端: Gold Flash 镀金
Metallic Shell 金属外壳: Matte Tin 雾锡
0.75
6.9
0.90
2.15
C
Pin 1
2.85
Electrical 电气规格:
Voltage Rating电压额定值: 30 V AC
Current Rating电流额定值: Signal(Pins 2,3,4)信号:1.0 A.
Power (Pins1,5)电源:1.8A.
Operating Temperature 工作温度: -30°C to +85°C
Contact Resistance接触电阻值: 30mΩ Max.
Insulating Resistance绝缘电阻值: 1000MΩ Min.
Dielectric Withstand Voltage耐电压: 500V AC/Minute
Optional peg
Pin 5
ø0.45
Ordering Grid
0.60
USB3080
B
30
XX
Request Samples
and Quotation
Packing Options
A = Tape & Reel
Contact Plating
30 = 30u" Gold
Mechanical 机械性规格:
Mating Force插入力: 35N Max.
Unmating Force拨出力: Initial 10N min.
Final 8N min after durability test.
Durability耐久性: 10,000 Cycles 次插拨
(1.5K per Reel)
Optional Plastic Locating Peg
00 = Without Peg
01 = With Peg (Standard)
1.3
2.6
A
A
Part Number
Product Description
USB3080
Micro USB Receptacle, TYPE B, SMT, R/A, Bottom Mount,
Optional Peg, With Shell Stakes
Drawing Date
04th April 2011
4.00
By
Detail
1
2
3
4
Revision
Date
5
CC
Tolerances (Except as Noted)
USB3080
E PCN
E2
15/02/17
X.X° ± 2°
X.X ± 0.40
X.XX ± 0.25 X.XX° ± 1°
X.XXX ± 0.05 X.XXX° ± 0.5°
Length
Angle
6
Units:
Metric (mm)
C
3rd Angle Projection
7
This drawing is confidential and
copyright of Global Connector
Technology, Ltd (GCT).
This drawing must not be copied
or disclosed without written
consent. E & OE
www.gct.co
Not to
Scale
Drawn By
SA
8
Sheet No.
1/2
H
FIRST APPROXIMATELY
15PCS EMPTY CARRIER
4.0
FIRST APPROXIMATELY
15PCS EMPTY CARRIER
12.0
16.0
4.0
G
Products P/N
I/O Direction
卷盘绕逆时针方向转动
F
USB3080-30-XX-A
1500
4
6000
Peel off Angle
剥离角度
10°
Cover Tape
盖带
Carrier Tape
载带
Notes注意:
1. Peeling off force of top tape: 0.1-1.3N
2. Part Conforms to EIA-481-C Standards产品符合EIA-481-C标准
3. All dimensions in millimeters 所有尺寸均是毫米
4. 10 sprocket hole pitch cumulative tolerance±0.2mm
120
Ø2
3
ø330
PCS/Reel Reels/Carton PCS/Carton
Ø13.5
E
120°
Detail F
6
P S
Detail F
Cardboard
纸板
Reel 卷筒
D
Waterproof bag
防水袋
Protection Tape
保护胶带
Label
标签
160mm
C
Carton
纸箱
Triangle Liner
三角形班轮
1500 pieces/reel
1500 件/卷
4 Reels
4 卷轴
B
35
700x600x0.08
4
m
Product Description
By
3
0m
Detail
2
35
USB3080
04th April 2011
1
m
Part Number
Drawing Date
A
0m
Revision
Date
5
CC
USB3080
E PCN
E2
15/02/17
Length
Angle
Units:
Metric (mm)
C
6
7
consent. E & OE
www.gct.co
Not to
Scale
Drawn By
SA
8
Sheet No.
2/2
很抱歉,暂时无法提供与“USB3080-30-00-A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+4.93613
- 10+4.10726
- 25+3.86530
- 50+3.68803
- 100+3.52033
- 250+3.29635
- 300+3.24125
- 500+3.12027
- 1500+2.87712
- 4500+2.60761
- 国内价格
- 1+11.45880
- 10+9.51480
- 30+8.45640
