8D521K77AN
8D521K77AN
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    8D521K77AN
8D521K77AN 数据手册
LAYOUT SHOWN AS EXAMPLE Keying Shown as example CHARACTERISTICS Connector dimension Dim Nominal ØS 41.7 Max Z 31 Max VV THREAD M31x1-6g -Standard : Based on MIL-DTL-38999 Series III -Shell Material : Stainless Steel -Shell Plating : Passivated -Insulator : Thermoplastic -Contacts : Copper Alloy -Seals & Grommet : Silicon Elastomer -Contact Plating : Gold over copper Alloy 0.8µm minimum -Durability : 500 Mating cycles SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR PN: 8D521K77AN -Delivered with Souriau contacts and Accessories -Temperature Range -Salt Spray : -65°C to +200°C : 500 hours A 07-10-2016 First Release ISS DATE Designed By: TITLE BASIC SERIES: 8D 5 - 21 K 77 A SCALE N NA SHELL TYPE : Plug with RFI Shielding CONTACT TYPE : Standard Crimp Contact SHELL SIZE : 21 PLATING : K = Jurisdiction & Control List Not Listed ORIENTATION : N SOURIAU Latest modification - by MOD N° CUSTOMER DRAWING Date: Stainless Steel Plug 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM CONTACT TYPE : PIN(500 Matings) Passivated CONTACT LAYOUT : 21-77 FORMAT A3 SOURIAU DRG N° 8D521K77AN-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 1/2 Contact Layout SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR Jurisdiction & Control List Not Listed PN: 8D521K77AN A 07-10-2016 First Release ISS DATE Designed By: TITLE SCALE NA SOURIAU FORMAT A3 Latest modification - by MOD N° CUSTOMER DRAWING Date: Stainless Steel Plug 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM SOURIAU DRG N° 8D521K77AN-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 2/2
8D521K77AN
1. 物料型号: 8D521K77AN-C 2. 器件简介: 这是SOURIAU品牌的General linear Tolerances不锈钢插头,具有RFI屏蔽功能。 3. 引脚分配: 提供了详细的引脚布局图,包括21个引脚的分配,例如PIN(500次配对)。 4. 参数特性: - 接触镀层: 铜合金上镀金,最小0.8微米 - 标准: 基于MIL-DTL-38999系列III - 密封和垫圈: 硅橡胶 - 壳体材料: 不锈钢 - 绝缘体: 热塑性材料,钝化处理 - 耐久性: 500次配对周期 5. 功能详解: 插头具有温度范围-65°C至+200°C,耐盐雾500小时。 6. 应用信息: 提供了与SOURIAU接触和配件一起交付的信息。 7. 封装信息: 尺寸和公差数据,例如最大直径41.7mm,最大Z尺寸31mm,螺纹规格M31x1-6g。
8D521K77AN 价格&库存
很抱歉,暂时无法提供与“8D521K77AN”相匹配的价格&库存,您可以联系我们找货
