NT-NUC131S
NT-NUC131S
    NUVOTON(新唐)
    NT-NUC131S
NT-NUC131S 数据手册
NuTiny-SDK-NUC131 Series User Manual NuTiny-SDK-NUC131SD2AE User Manual The information described in this document is the exclusive intellectual property of Nuvoton Technology Corporation and shall not be reproduced without permission from Nuvoton. Nuvoton is providing this document only for reference purposes of NuMicro™ microcontroller based system design. Nuvoton assumes no responsibility for errors or omissions. All data and specifications are subject to change without notice. For additional information or questions, please contact: Nuvoton Technology Corporation. Des. 24, 2014 Rev. 1.00 NuTiny-SDK- NUC131 series User Manual Table of Contents 1 Overview ........................................................................................... 3 2 Introduction to NuTiny-SDK- NUC131SD2AE .......................................... 4 1. 2. 3. NuTiny-SDK- NUC131SD2AE Jumper Description ...........................................5 Pin Assignment for Extended Connectors ......................................................6 NuTiny-SDK- NUC131SD2AE PCB Placement .................................................8 Starting to Use NuTiny-SDK- NUC131SD2AE on the Keil μVision® IDE ....... 9 3 4. 5. 6. 7. Downloading and Installing Keil μVision® IDE Software ...................................9 Downloading and Installing Nuvoton Nu-Link Driver .......................................9 Hardware Setup .........................................................................................9 Example Program..................................................................................... 10 4 Starting to Use NuTiny-SDK- NUC131SD2AE on the IAR Embedded Workbench ............................................................................................. 11 8. 9. 10. 11. 5 NuTiny-SDK- NUC131SD2AE Schematics ............................................. 13 12. 13. 14. 6 NuTiny-EVB- NUC131SD2AE Schematic ...................................................... 13 NuTiny-EVB- NUC131SD2AE Schematic ...................................................... 14 Nu-Link-Me Schematic .............................................................................. 15 Downloading NuMicro™ Related Files from Nuvoton Website .................. 16 15. 16. 17. 7 Downloading and Installing IAR Embedded Workbench Software .................... 11 Downloading and Installing Nuvoton Nu-Link Driver ..................................... 11 Hardware Setup ....................................................................................... 11 Example Program..................................................................................... 12 Downloading NuMicro™ Keil μVision® IDE Driver .......................................... 16 Downloading NuMicro™ IAR EWARM Driver ................................................. 18 Downloading NuMicro™ NUC131SD2AE Series BSP Software Library .............. 20 Revision History ............................................................................... 22 Des. 24, 2014 2 of 21 Rev. 1.00 NuTiny-SDK- NUC131 series User Manual 1 Overview The NuTiny-SDK- NUC131SD2AE is a specific development tool for NuMicro™ M0518 series by which users can develop and verify the application program easily. The NuTiny-SDK-NUC131SD2AE includes two portions: NuTiny-EVB-NUC131SD2AE (an evaluation board) and Nu-Link-Me (Debug Adaptor). With the NuTiny-SDKNUC131SD2AE, users do not need additional ICE or debug equipment. Des. 24, 2014 3 of 21 Rev. 1.00 NuTiny-SDK- NUC131 series User Manual 2 Introduction to NuTiny-SDK- NUC131SD2AE The following figure shows the NuTiny-SDK- NUC131SD2AE for NUC131SD2AE series, in which the left portion is called NuTiny-EVB- NUC131SD2AE and the right portion is Debug Adaptor called Nu-Link-Me. The NuTiny-EVB- NUC131SD2AE is similar to other development board. Users can use it to develop and verify applications to emulate the real behavior. In fact, the real chip NUC131SD2AE is mounted on the board. The NuTiny-EVB- NUC131SD2AE can be a real system controller to design user target system. The Nu-Link-Me is a Debug Adaptor which connects the USB port of your PC to your target system (via Serial Wired Debug Port) and allows you to program and debug embedded programs on the target hardware. To use the Nu-Link-Me Debug adaptor with Keil or IAR, please refer to “Nuvoton NuMicro™ IAR ICE Driver User Manual” or Nuvoton NuMicro™ Keil ICE Driver User Manual” for details. VDD (JP1) LQFP-64 pin Extended Connector (JP7, JP6) VSS (JP2) LQFP-64 pin Extended Connector (JP4, JP5) ICE Controller USB Connector (ICEJ2) Reset Key (SW1) Power LED I/O LED Target Chip ICE Controller VCC:3.3V or 5V (JP8) Figure 2-1 NuTiny-SDK- NUC131SD2AE (Green PCB Board) Des. 24, 2014 4 of 21 Rev. 1.00 NuTiny-SDK- NUC131 series User Manual 1. NuTiny-SDK- NUC131SD2AE Jumper Description 2.1.1 Power Settings  JP1: VDD Voltage connecter in NuTiny-EVB- NUC131SD2AE  J1: USB port in Nu-Link-Me Model Model 1 JPR1 Select VCC33 (default) Model 2 X J1 USB port JP1 VDD MCU Voltage Connect to PC DC 3.3V output DC 3.3V X DC 2.5 V ~ 5.5 V Input Voltage by JP1 input X: Unused. 2.1.2 Debug Connectors  JP3: Connector in target board (NuTiny-EVB- NUC131SD2AE) for connecting with Nuvoton ICE adaptor (Nu-Link-Me)  JP8: Connector in ICE adaptor (Nu-Link-Me) for connecting with a target board (e.g. NuTiny-EVB- NUC131SD2AE) 2.1.3 USB Connectors  J1: Mini USB Connector in Nu-Link-Me connected to a PC USB port 2.1.4 Extended Connectors  JP4, JP5, JP6 and JP7: Show all chip pins in NuTiny-EVB- NUC131SD2AE 2.1.5 Buttons  SW1: Reset button in NuTiny-EVB- NUC131SD2AE 2.1.6 Power Connectors  JP1: VDD connector in NuTiny-EVB- NUC131SD2AE  JP2: VSS connector in NuTiny-EVB- NUC131SD2AE Des. 24, 2014 5 of 21 Rev. 1.00 NuTiny-SDK- NUC131 series User Manual 2. Pin Assignment for Extended Connectors The NuTiny-EVB- NUC131SD2AE provides the NUC131SD2AE target chip on board and the extended connectors (JP4, JP5, JP6 and JP7) for LQFP48-pin. The following table is the pin assignment for NUC131SD2AE. Pin No 01 02 10 11 Pin Name PB.14,INT0 PB.13 PB.12,CLKO,BPWM1_CH 3 PF.5,I2C0_SCL,PWM1_C H5 PF.4,I2C0_SDA,PWM1_C H4 PA.11,I2C1_SCL,PWM1_ CH3 PA.10,I2C1_SDA,PWM1_ CH2 PA.9,I2C0_SCL,UART1_n CTS PA.8,I2C0_SDA,UART1_n RTS PB.4,UART1_RXD PB.5,UART1_TXD 12 PB.6,UART1_nRTS 44 13 PB.7,UART1_nCTS 45 14 LDO_CAP 46 15 VDD 47 16 17 18 VSS PB.0,UART0_RXD PB.1,UART0_TXD PB.2,UART0_nRTS,TM2_ EXT,TM2,PWM1_BRAKE1 PB.3,UART0_nCTS,TM3_ EXT,TM3,PWM1_BRAKE0 PD.6,BPWM1_CH1,CAN0 48 49 50 PF.6,ICE_CLK AVSS PA.0,PWM0_CH4,ADC0,I2C1 _SCL,UART5_TXD PA.1,PWM0_CH5,ADC1,I2C1 _SDA,UART5_RXD PA.2,PWM1_CH0,ADC2,UAR T3_TXD PA.3,PWM1_CH1,ADC3,UAR T3_RXD PA.4,ADC4 PA.5,UART3_RXD,ADC5 PA.6,UART3_TXD,ADC6 51 PA.7,Vref,ADC7 52 AVDD 53 PC.7,PWM0_BRAKE1,I2C0_S 03 04 05 06 07 08 09 19 20 21 Des. 24, 2014 Pin No 33 34 Pin Name PC.11,PWM1_BRAKE1 PC.10,PWM1_BRAKE0 35 PC.9,PWM0_BRAKE1 36 PC.8,PWM0_BRAKE0 37 PA.15,PWM0_CH3 38 PA.14,PWM0_CH2 39 40 PA.13,PWM0_CH1,UART5_T XD PA.12,PWM0_CH0,UART5_R XD 41 PF.7,ICE_DAT 42 43 6 of 21 Rev. 1.00 NuTiny-SDK- NUC131 series User Manual 22 23 24 25 26 27 28 29 30 31 32 Des. 24, 2014 _RXD PD.7,BPWM1_CH0,CAN0 _TXD PD.14,BPWM0_CH5,UAR T2_RXD PD.15,BPWM0_CH4,UAR T2_TXD PC.3,BPWM0_CH3,SPI0_ MOSI0 PC.2,BPWM0_CH2,SPI0_ MISO0 PC.1,BPWM0_CH1,SPI0_ CLK PC.0,BPWM0_CH0,SPI0_ SS0 PE.5,PWM0_CH5,TM1_E XT,TM1 PB.11,TM3,PWM0_CH4 PB.10,TM2 54 CL,UART4_RXD PC.6,PWM0_BRAKE0,I2C0_S DA,UART4_TXD 55 PC.15 56 PC.14 57 PB.15, ,BPWM1_CH5TM0,TM 0_EXT,INT1 58 PF.0,XT1_OUT 59 PF.1,XT1_IN 60 nRESET 61 VSS 62 63 VDD PF.8, PWM1_CH4,CLKO PB.8,BPWM1_CH2,CLKO,TM PB.9,TM1 64 0,STADC Table 2-1 Pin Assignment for NUC131SD2AE 7 of 21 Rev. 1.00 NuTiny-SDK- NUC131 series User Manual 3. NuTiny-SDK- NUC131SD2AE PCB Placement The following figure shows the NuTiny-SDK- NUC131SD2AE PCB placement. Figure 2-2 NuTiny-SDK- NUC131SD2AE PCB Placement Des. 24, 2014 8 of 21 Rev. 1.00 NuTiny-SDK- NUC131 series User Manual 3 Starting to Use NuTiny-SDK- NUC131SD2AE on the Keil μVision® IDE 4. Downloading and Installing Keil μVision® IDE Software Please connect to the Keil company website (http://www.keil.com) to download the Keil μVision® IDE and install the RVMDK. 5. Downloading and Installing Nuvoton Nu-Link Driver Please connect to Nuvoton NuMicro™ website (http://www.nuvoton.com/NuMicro) to download the “NuMicro™ Keil μVision® IDE driver” file. Please refer to section 15 for the detailed download flow. After the Nu-Link driver is downloaded, please unzip the file and execute the “Nu-Link_Keil_Driver.exe” to install the driver. 6. Hardware Setup The hardware setup is shown in the following figure. Figure 3-1 NuTiny-SDK- NUC131SD2AE Hardware Setup Des. 24, 2014 9 of 21 Rev. 1.00 NuTiny-SDK- NUC131 series User Manual 7. Example Program This example demonstrates how to download and debug an application on a NuTinySDK- NUC131SD2AE board. The example file can be found in the directory list shown in the following figure. Directory Figure 3-2 Example Directory To use this example: The I/O LED on the NuTiny-EVB- NUC131SD2AE board will turn on.     Start μVision® Project – Open Open the SYS.uvproj project file  Start Debug mode When using the debugger commands, you may:  Review variables in the watch window  Single step through code  Reset the device  Run the application Project – Build Compile and link the SYS application Flash – Download Program the application code into on-chip Flash ROM Des. 24, 2014 10 of 21 Rev. 1.00 NuTiny-SDK- NUC131 series User Manual 4 Starting to Use NuTiny-SDK- NUC131SD2AE on the IAR Embedded Workbench 8. Downloading and Installing IAR Embedded Workbench Software Please connect to IAR company website (http://www.iar.com) to download the IAR Embedded Workbench and install the EWARM. 9. Downloading and Installing Nuvoton Nu-Link Driver Please connect to Nuvoton Company NuMicro™ website (http://www.nuvoton.com/NuMicro) to download “NuMicro™ IAR EWARM Driver” file. Please refer to section 16 for the detail download flow. After the Nu-Link driver is downloaded, please unzip the file and execute the “Nu-Link_IAR_Driver.exe” to install the driver. 10. Hardware Setup The hardware setup is shown in the following figure. Figure 4-1 NuTiny-SDK- NUC131SD2AE Hardware Setup Des. 24, 2014 11 of 21 Rev. 1.00 NuTiny-SDK- NUC131 series User Manual 11. Example Program This example demonstrates how to download and debug an application on a NuTinySDK- NUC131SD2AE board. The example file can be found in the directory list shown in the following figure. Directory Figure 4-2 Example Directory To use this example: The I/O LED on the NuTiny-EVB- NUC131SD2AE board will turn on.    Start IAR Embedded Workbench File-Open-Workspace Open the SYS.eww workspace file Project - Make Compile and link the SYS application Des. 24, 2014  Project – Download and Debug Program the application code into on-chip Flash ROM  Single step through code  Reset the device  Run the application 12 of 21 Rev. 1.00 NuTiny-SDK- NUC131 series User Manual 5 NuTiny-SDK- NUC131SD2AE Schematics 12. NuTiny-EVB- NUC131SD2AE Schematic Off-page Connector ADAVSS ICE_CLK ICE_DAT P[1:64] D12MO D12MO P48 P47 P46 P45 P44 P43 P42 P41 P40 P39 P38 P37 P36 P35 P34 P33 D12MI D12MI VCC5 DAVDD CB5 0.1u C0603 D12MO D12MI RESET DVCC5 CB3 0.1u C0603 P49 P50 P51 P52 P53 P54 P55 P56 P57 P58 P59 P60 P61 P62 P63 P64 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 48 47 46 45 44 43 42 41 40 39 38 37 36 35 34 33 PA.5/UART3_RXD/ADC5 PA.6/UART3_TXD/ADC6 PA.7/Vref /ADC7 AVDD PC.7/PWM0_BRAKE1/I2C0_SCL/UART4_RXD PC.6/PWM0_BRAKE0/I2C0_SDA/UART4_TXD PC.15 PC.14 PB.15/BPWM1_CH5/TM0/TM0_EXT/INT1 PF.0/XT1_OUT PF.1/XT1_IN nRESET VSS VDD PF.8/PWM1_CH4/CLKO PB.8/BPWM1_CH2/CLKO/TM0/STADC TM1/PB.9 TM2/PB.10 TM3/PWM0_CH4/PB.11 TM1_EXT/TM1/PWM0_CH5/PE.5 SPI0_SS0/BPWM0_CH0/PC.0 SPI0_CLK/BPWM0_CH1/PC.1 SPI0_MISO0/BPWM0_CH2/PC.2 SPI0_MOSI0/BPWM0_CH3/PC.3 UART2_TXD/BPWM0_CH4/PD.15 UART2_RXD/BPWM0_CH5/PD.14 CAN0_TXD/BPWM1_CH0/PD.7 CAN0_RXD/BPWM1_CH1/PD.6 UART0_nCTS/TM3_EXT/TM3/PWM1_BRAKE0/PB.3 UART0_nRTS/TM2_EXT/TM2/PWM1_BRAKE1/PB.2 UART0_TXD/PB.1 UART0_RXD/PB.0 32 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 P32 P31 P30 P29 P28 P27 P26 P25 P24 P23 P22 P21 P20 P19 P18 P17 PB.14/INT0 PB.13 PB.12/CLKO/BPWM1_CH3 PF.5/I2C0_SCL/PWM1_CH5 PF.4/I2C0_SDA/PWM1_CH4 PA.11/I2C1_SCL/PWM1_CH3 PA.10/I2C1_SDA/PWM1_CH2 PA.9/I2C0_SCL/UART1_nCTS PA.8/I2C0_SDA/UART1_nRTS PB.4/UART1_RXD PB.5/UART1_TXD PB.6/UART1_nRTS PB.7/UART1_nCTS LDO_CAP VDD VSS R8 0 GND P1 P2 P3 P4 P5 P6 P7 P8 P9 P10 P11 P12 P13 P14 P15 P16 NUC131SD2AE_LQFP64 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 2 1 JP11 VCC GND ADC4/PA.4 ADC3/PWM1_CH1/UART3_RXD/PA.3 ADC2/PWM1_CH0/UART3_TXD/PA.2 ADC1/PWM0_CH5/I2C1_SDA/UART5_RXD/PA.1 ADC0/PWM0_CH4/I2C1_SCL/UART5_TXD/PA.0 AVSS ICE_CLK/PF.6 ICE_DAT/PF.7 PWM0_CH0/UART5_RXD/PA.12 PWM0_CH1/UART5_TXD/PA.13 PWM0_CH2/PA.14 PWM0_CH3/PA.15 PWM0_BRAKE0/PC.8 PWM0_BRAKE1/PC.9 PWM1_BRAKE0/PC.10 PWM1_BRAKE1/PC.11 U2 P[1:64] DVCC5 CT2 1uF/6.3V TANT-A CB4 0.1u C0603 Title NUTINY -SDK-NUC131 Size Document Number Custom Date: Des. 24, 2014 13 of 21 Thursday , December 25, 2014 Rev Sheet 3 of 3 Rev. 1.00 NuTiny-SDK- NUC131 series User Manual 13. NuTiny-EVB- NUC131SD2AE Schematic DVCC5 VCC5 R1 10K R0603 SW1 PUSH BOTTOM SW DVCC5 JP1 DAVDD NC RESET L0603 1 2 Reset TANT-A L1 P[1:64] L2 JP2 C1 10uF/10V Off-page Connector DVCC5 1 2 ICERST D12MO L0603 ADAVSS NC D12MI P[1:64] D12MO D12MI Power DVCC5 JP3 1 3 5 7 9 2 4 6 8 10 ICEDAT ICECLK ICERST NC VCC5 ICE INTERFACE GND TICEDVDD5 TICEDAT TICECLK TICERST C2 20p D12MO C0603 C3 20p VCC GND TICEDVDD5 TICEDAT ICEDAT TICECLK ICECLK TICERST ICERST VCC5 X1 12MHz VCC XTAL3-1 GND P1 P3 P5 P7 P9 P11 P13 P15 D12MI C0603 DVCC5 2 P33 P35 P37 P39 P41 P43 P45 P47 R2 1 0805 2 POWER1 Green 1 0805 P17 P19 P21 P23 P25 P27 P29 P31 JP5 1 3 5 7 9 11 13 15 2 4 6 8 10 12 14 16 P18 P20 P22 P24 P26 P28 P30 P32 NC JP6 1 3 5 7 9 11 13 15 2 4 6 8 10 12 14 16 P34 P36 P38 P40 P42 P44 P46 P48 P49 P51 P53 P55 P57 P59 P61 P63 JP7 1 3 5 7 9 11 13 15 2 4 6 8 10 12 14 16 P50 P52 P54 P56 P58 P60 P62 P64 NC IO PR1 LED P2 P4 P6 P8 P10 P12 P14 P16 NC 510 R0603 N2 2 4 6 8 10 12 14 16 connect DVCC5 P2 1 3 5 7 9 11 13 15 NC Crystal IO1 Red JP4 510 R0603 N1 Title NUTINY-SDK-NUC131 Size Document Number Custom Date: Des. 24, 2014 14 of 21 Thursday , December 04, 2014 Rev 1.0 Sheet of Rev. 1.00 NuTiny-SDK- NUC131 series User Manual 14. Nu-Link-Me Schematic VCC5 VCC5 R3 10K R0603 VCC5 ISPLED 2 ICP1 Y ellow 1 0805 NUC_RST# RP1 1 8P4R-330 2 3 4 5 6 7 8 NUC_RST# 12M_I 12M_O ICE1 Red PVSS 8P4RA 2 GND 1 0805 C4 10uF/10V GREEN 2 BUSY 1 Green 1 0805 U1 ICELED ISPLED RED GREEN VCC5 CB1 0.1u C0603 AVDD INT0/PB14 CPO1/PB13 CPO0/PB12 X32I X32O I2C1SCL/PA11 I2C1SDA/PA10 I2C0SCL/PA9 I2C0SDA/PA8 RX1/PB4 TX1/PB5 RTS1/PB6 CTS1/PB7 LDO VDD VSS VCC5 N3 R5 NC R0603 C0603 X2 12MHz XTAL3-1 C6 20p 12M_I PA4/ADC4 PA3/ADC3 PA2/ADC2 PA1/ADC1 PA0/ADC0 AVSS ICE_CK ICE_DAT PA12/PWM0 PA13/PWM1 PA14/PWM2 PA15/PWM3 PC8/SS10 PC9/SPCLK1 PC10/SDI10 PC11/SDO10 NUC12SRE3AN C0603 48 47 46 45 44 43 42 41 40 39 38 37 36 35 34 33 VCC5 ICE_CLK ICE_DAT RTCK1 100K R0603 ADAVSS TICERST TICECLK RTDA3 RTDA2 RTDA1 100K R0603 RRSET1 100K R0603 TICEDAT TICERST 0 33 R0603 R0603 VCC5 VCC5 VCC5 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 L3 L0603 2 4 6 8 10 C5 20p R4 33 R0603 VBUS VDD33 DD+ PB0/RX0 PB1/TX0 PB2/RTS0 PB3/CTS0 PC3/SDO00 PC2/SDI00 PC1/SPCLK0 PC0/SS00 PE5 PB11/TM3 PB10/SS01/TM2 PB9/SS11/TM1 CT1 1uF/6.3V TANT-R 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 1 3 5 7 9 TICEDAT TICECLK TICERST NC 64 63 62 61 60 59 58 57 56 55 54 53 52 51 50 49 IDLE1 Red 1 0805 SS24A RB060L TANT-A AVDD STADC/TM0/PB8 PVSS VDD1 VSS1 /RESET XT1_In XT1_Out INT1/PB15 CPP1/PC14 CPN1/PC15 CPP0/PC6 CPN0/PC7 AVDD ADC7/PA7 ADC6/PA6 ADC/PA5 2 D1 JP8 TICEVCC TICEDAT TICECLK TICERST ICE_RST 12M_O RED 1 VCC ICELED 2 VCC5 ICE CONNECT IF VCC5 VBUS USB_D+ USB_D- L4 L0603 ADAVSS USBVBUS R6 100 R0603 USBVBUS C7 1u C0603 CB2 0.1u C0603 R7 100 R0603 DM DP J1 mini USB 5pin 1 2 3 4 5 VCC DM DP NC GND SHIELD SHIELD SHIELD SHIELD USB_MINI_B VCC5 RTIDA1 100K R0603 NC 6 7 8 9 1 2 3 4 5 L5 ICE_DAT ICE_CLK ICE_RST RICK1 100K R0603 DEBUG JP9 L0805 P5V OUT 3 2 1 CP1 10uF/10V TANT-A JPR1 HEADER 3 P3V USBVBUS DM DP 4 3 1 2 PD1 USBVBUS SS24A 1 2 IN GND OUT UP1 AMS1117_3.3v RB060L JP10 1 2 3 4 Title Rev 1.0 NC Date: Des. 24, 2014 NuLink-Me Size Document Number Custom 15 of 21 Thursday , December 04, 2014 Sheet of Rev. 1.00 NuTiny-SDK- NUC131 series User Manual 6 Downloading NuMicro™ Related Files from Nuvoton Website 15. Downloading NuMicro™ Keil μVision® IDE Driver Step1 ™ Visit the Nuvoton NuMicro website: http://www.nuvoton.com/NuMicro. 2-1. Move to “Support” 2-2. Click here to enter Tool & Software Step2 Des. 24, 2014 16 of 21 Rev. 1.00 NuTiny-SDK- NUC131 series User Manual Click here to enter Software download page Step3 Click here to download the file. Step4 Step5 ™ ® Download the NuMicro Keil μVision IDE driver. Des. 24, 2014 17 of 21 Rev. 1.00 NuTiny-SDK- NUC131 series User Manual 16. Downloading NuMicro™ IAR EWARM Driver Step1 ™ Visit the Nuvoton NuMicro website: http://www.nuvoton.com/NuMicro. 2-1. Move to “Support” 2-2. Click here to enter Tool & Software Step2 Des. 24, 2014 18 of 21 Rev. 1.00 NuTiny-SDK- NUC131 series User Manual Click here to enter Software download page Step3 Step4 Step5 Click here to download the file. ™ Download the NuMicro IAR EWARM driver. Des. 24, 2014 19 of 21 Rev. 1.00 NuTiny-SDK- NUC131 series User Manual 17. Downloading NuMicro™ NUC131SD2AE Series BSP Software Library Step1 ™ Visit the Nuvoton NuMicro website: http://www.nuvoton.com/NuMicro. 2-1. Move to “Support” 2-2. Click here to enter Tool & Software Step2 Des. 24, 2014 20 of 21 Rev. 1.00 NuTiny-SDK- NUC131 series User Manual Click here to enter Software download page Step3 Step4 ™ Download the NuMicro NUC131 Series CMSIS BSP. Des. 24, 2014 21 of 21 Rev. 1.00 NuTiny-SDK- NUC131 series User Manual 7 Revision History Revision 1.00 Date Des. 25, 2014 Description Preliminary version. Important Notice Nuvoton Products are neither intended nor warranted for usage in systems or equipment, any malfunction or failure of which may cause loss of human life, bodily injury or severe property damage. Such applications are deemed, “Insecure Usage”. Insecure usage includes, but is not limited to: equipment for surgical implementation, atomic energy control instruments, airplane or spaceship instruments, the control or operation of dynamic, brake or safety systems designed for vehicular use, traffic signal instruments, all types of safety devices, and other applications intended to support or sustain life. All Insecure Usage shall be made at customer’s risk, and in the event that third parties lay claims to Nuvoton as a result of customer’s Insecure Usage, customer shall indemnify the damages and liabilities thus incurred by Nuvoton. Des. 24, 2014 22 of 21 Rev. 1.00
NT-NUC131S 价格&库存
很抱歉,暂时无法提供与“NT-NUC131S”相匹配的价格&库存,您可以联系我们找货
