TLP604
TLP604
    TRIPPLITE
    TLP604
TLP604 数据手册
Protect It! 6-Outlet Surge Protector, 4 ft. (1.22 m) Cord, 790 Joules, Diagnostic LED, Light Gray Housing MODEL NUMBER: TLP604 Highlights ● 6 NEMA 5-15R outlets—one designed for a bulky transformer ● 790-joule surge protection rating ● Filters out threatening EMI/RFI line noise ● 15A resettable circuit breaker prevents dangerous overloads ● 4 ft. AC power cord with NEMA 5-15P plug Package Includes Safeguard your computer, printer, scanner, router, modem and other small home electronics against dangerous surges, spikes and line noise. Recommended for any desktop, network or home application requiring AC line protection. Features 790-Joule Surge Protection for Home or Office Electronics ● Protects your computer, printer, scanner, router, modem and other small home electronics against even the strongest surges and spikes ● Recommended for any desktop, network or home electronics application requiring AC line protection ● Full normal mode (H-N) and common mode (N-G/H-G) line surge suppression ● Filters out disruptive EMI/RFI line noise that can cause equipment damage or data loss ● Exceeds IEEE 587 Category A and B surge suppression specifications 6 Outlets Accept Wide Range of Electronic Devices ● 6 NEMA 5-15R AC outlets accept most computers and peripherals ● Special end outlet designed for bulky transformers without blocking other outlets Premium Safety Features ● Lighted on/off switch provides one-touch control over connected equipment ● Automatic shutoff permanently cuts power to outlets if protection circuit is incapacitated, preventing equipment damage and indicating replacement is required ● Diagnostic LED confirms protection status at a glance ● Conforms to current UL 1449 3rd Edition safety standards ● ABS fire retardant plastic case provides extra safety and durability Fits Effortlessly Into Your Workstation ● 4 ft. AC power cord with NEMA 5-15P plug reaches nearby outlets ● Keyhole slots on bottom panel provide convenient wall or desk mounting options Backed by Tripp Lite’s Ultimate Lifetime Insurance ● $20,000 Ultimate Lifetime Insurance covers any connected components damaged by power surge (U.S., Canada and Puerto Rico only) 1/4 ● TLP604 Protect It! 6-Outlet Surge Protector, Light Gray Housing ● Owner’s manual Specifications OVERVIEW UPC Code 037332100498 INPUT Nominal Input Voltage(s) Supported 120V AC Recommended Electrical Service 120V (110-125V) Input Cord Gauge Type 14 gauge; SJT Input Cord Gauge (AWG) 14 Voltage Compatibility (VAC) 120 Maximum Surge Amps 36000 Input Plug Type NEMA 5-15P Input Cord Details SJT Input Cord Length (ft.) 4 Right-Angle Plug No Input Cord Length (m) 1.22 Integrated Cord Clip No OUTPUT Frequency Compatibility 50 / 60 Hz Output (Watts) 1800 Output Receptacles (6) 5-15R Circuit Breaker (amps) 15 Transformer Accommodation (2) Yes Outlet Orientation Single row Right-Angle Outlets No USER INTERFACE, ALERTS & CONTROLS Diagnostic LED(s) Yes Switches Combination AC circuit breaker and 2 position on/off power switch Diagnostic LED Details Built-in LED confirms suppressor "protection present" (green) status SURGE / NOISE SUPPRESSION AC Suppression Joule Rating 790 AC Suppression Response Time < 1 ns Protection Modes Includes full normal mode (H-N) and common mode (N-G / H-G) line suppression 2/4 UL1449 Let Through Rating 500V EMI / RFI Filtering Yes Automatic Shut-Off Yes DATALINE SURGE SUPPRESSION Cable (Coax) Protection No Network (Ethernet) Protection No Telephone/DSL Protection No PHYSICAL Material of Construction Plastic Power Cord Color Light Gray Housing Color Light Gray Mounting Holes or Slots Yes Slot or Hole Mount Measurement (Center to Center) Distance between slots = 101 mm; Distance between slot height = 28 mm Outlets Measurement (Center to Center) 28.5mm Receptacle Color Gray Shipping Dimensions (hwd / in.) 12.60 x 1.60 x 4.90 Shipping Dimensions (hwd / cm) 32.00 x 4.06 x 12.45 Shipping Weight (lbs.) 1.00 Shipping Weight (kg) 0.45 Unit Dimensions (hwd / in.) 10.8 x 1.85 x 1.23 Unit Dimensions (hwd / cm) 27.43 x 4.70 x 3.12 Unit Weight (lbs.) .80 Unit Weight (kg) 0.36 FEATURES & SPECIFICATIONS Antimicrobial No Rotatable Outlets No STANDARDS & COMPLIANCE Product Certifications CAN/CSA-C22.2 No. 269.3 (Canada); CAN/CSA-C22.2 No. 308 (Canada); cUL Listed; UL 1449; UL 1363; UL Listed Product Compliance RoHS WARRANTY Product Warranty Period (Worldwide) Lifetime limited warranty 3/4 Connected Equipment Insurance (U.S., Canada & Puerto Rico) $20,000 Ultimate Lifetime Insurance  © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 4/4
TLP604
- 物料型号:Tripp Lite TLP604 - 器件简介:该保护器用于保护电脑、打印机、扫描仪、路由器、调制解调器和其他小型家用电器免受危险的浪涌、尖峰和线路噪声的影响。 - 引脚分配:文档中未明确提及引脚分配,但提到了6个NEMA 5-15R交流电源插座,其中一个特殊设计用于容纳大型变压器。 - 参数特性: - 790焦耳的浪涌保护 - 适用于120V交流电 - 4英尺(1.22米)长的电源线 - 自动断电功能,如果保护电路失效,则自动切断电源 - 诊断LED指示保护状态 - 功能详解:包括全模式(H-N)和共模(N-G/H-G)线路浪涌抑制,以及过滤掉可能导致设备损坏或数据丢失的EMI/RFI线路噪声。 - 应用信息:推荐用于任何需要交流线路保护的桌面、网络或家庭电子设备应用。 - 封装信息:ABS阻燃塑料外壳,颜色为浅灰色,带有挂孔,便于壁挂或桌面安装。
TLP604 价格&库存
很抱歉,暂时无法提供与“TLP604”相匹配的价格&库存,您可以联系我们找货
