RC12-6-01S
RC12-6-01S
    MARLOWINDUSTRIES,INC.
    RC12-6-01S
RC12-6-01S 数据手册
  Technical Data Sheet for RC12‐6  Single‐Stage Thermoelectric Module      NOMINAL PERFORMANCE IN NITROGEN      Hot Side Temperature (°C)  Δ Tmax (°C):  Qmax (watts):  Imax (amps):  Vmax (vdc):  AC Resistance (ohms):  Device ZT  27  66  54  5.6  14.7  2.2  0.76  50  74  60  5.6  16.4  ‐‐‐  ‐‐‐      PRODUCT FEATURES          ORDERING OPTIONS      RoHS EU Compliant  REACH EU Compliant Rated operating temperature of 130°C.  Ceramic Material:  Aluminum Oxide  Porched configuration for enhanced leadwire strength.  Superior nickel diffusion barriers on elements.  High strength for rugged environment.  Lapped option available for multiple module applications.     OPERATION CAUTIONS    For maximum reliability, storage and operation below  130°C in a non‐condensing environment is recommended.  To minimize thermal stress when operating in cooling  mode, use linear/proportional temperature control or a  similar method rather than an ON/OFF method.  Model Number  RC12‐6‐01  RC12‐6‐01L  RC12‐6‐01S  RC12‐6‐01LS  RC12‐6‐06LS  RC12‐6‐09S  RC12‐6‐11LS      Description  102mm Leadwires  102mm Leadwires, Lapped  102mm Leadwires, Sealed  102mm Leadwires, Lapped, Sealed  368mm Leadwires, Lapped, Sealed  305mm Leadwires, Sealed  150mm Leadwires, Lapped, Sealed      INSTALLATION    Recommended mounting methods: Clamp under uniform  pressure with thermal grease or suitable flexible thermal  interface. For additional information, please refer to our TEM  Installation Guide.        II‐VI Marlow – Dallas, TX USA  214‐340‐4900  877‐627‐5691  marlow.sales@ii‐vi.com  Marlow Industries Europe  GmbH ‐ Germany  +49 (0) 6150 5439 ‐ 403  info@marlow‐europe.eu  II‐VI Japan Inc.   81 43 297 2693 (tel)  center@ii‐vi.co.jp  www.ii‐vi.co.jp  MI Form 005‐0690 Rev. 4  Marlow Industries China, II‐VI  Technologies Beijing  86‐10‐643 98226  info@iivibj.com  DOC # 102‐0278 REV K ‐ PAGE 1 OF 3  www.marlow.com    II‐VI Singapore Pte., Ltd.   (65) 6481 8215 (tel)  info@ii‐vi.com.sg        THERMOELECTRIC COOLING PERFORMANCE CURVES  ENVIRONMENT:  ONE ATMOSPHERE DRY NITROGEN Hot Side Temperature 27°C Hot Side Temperature 50°C 80.0 40.0 20.0 0.0 60.0 T (C) T (C) 60.0 0.0 16.0 VOLTAGE (VDC) VOLTAGE (VDC) 40.0 20.0 16.0 12.0 8.0 Q=0 T=0 4.0 0.0 0.0 1.0 2.0 3.0 4.0 5.0 CURRENT (AMPS) 6.0 12.0 Q=0 T=0 8.0 4.0 0.0 0.0 7.0 1.0 2.0 3.0 4.0 5.0 CURRENT (AMPS) 6.0 7.0   For performance information in a vacuum or with hot side temperatures other than 27°C or 50°C, contact one of our Applications Engineers at 877‐627‐5691.    POWER GENERATION PERFORMANCE CURVES  ENVIRONMENT:  ONE ATMOSPHERE DRY NITROGEN    Cold Side Temperature 50°C η / Opt η 2 1.8 1.6 1.4 1.2 1 0.8 0.6 0.4 Power Voltage 0.2 0 26.9 31.9 36.9 Tc=27°C 1.9 6.9 11.9 0.4 Efficiency 2 85 1 Tc=50°C 0.3 1.2 0.8 0.25 0.2 0.6 0.15 0.4 0.1 0.2 0.05 Power 0 3.1 5.1 7.1 Voltage 0 9.1 11.1 13.1 15.1 17.1 19.1 21.1 Heat (W) Hot Side Temperature (°C)  Cold Side Temperature (°C)  Optimum Efficiency, η (%)  Optimum Power (W)  Optimum Voltage (V)  Load Resistance for Opt η (Ω)  Open Circuit Voltage, VOC (V)  Short Circuit Current (A)  Thermal Resistance (°C/W)  85  27  2.52  0.931  1.795  3.46  3.15  1.20  1.57  55  27  1.27  0.227  0.856  3.23  1.50  0.62  1.57    35  27  0.37  0.019  0.242  3.07  0.43  0.18  1.57  3 4 5 6 7 8 Load Resistance Ratio   For performance information with hot side temperatures other than 27°C or 50°C, contact one of our Applications Engineers at 877‐627‐5691.    1 1 0.9 0.8 0.7 0.6 0.5 0.4 0.3 0.2 Voltage 0.1 0 9 10 Hot Side Temperature (°C) Hot Side Temperature (°C) 60 65 70 75 80 55 0.35 16.9 21.9 Heat (W) Normalized Off-Peak Performance 1 0.9 0.8 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0 0 85 Opt Power (W) 35 Opt Voltage (V) 30 Voltage / VOC 1 0.9 0.8 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0 Hot Side Temperature (°C) Hot Side Temperature (°C) 40 45 50 55 65 75 Opt Voltage (V) Cold Side Temperature 27°C Opt Power (W) TYPICAL PERFORMANCE CURVES  HEAT LOAD (WATTS) 0.00 5.00 10.0 15.0 20.0 25.0 30.0 35.0 40.0 45.0 50.0 55.0 80.0 HEAT LOAD (WATTS) 0.00 5.00 10.0 15.0 20.0 25.0 30.0 35.0 40.0 45.0 50.0   MI Form 005‐0690 Rev. 4  DOC # 102‐0278 REV K ‐ PAGE 2 OF 3  www.marlow.com      MECHANICAL CHARACTERISTICS      All units are in millimeters unless otherwise stated.    *NOTE:  Cold side, hot side, positive lead, and negative lead are valid only for thermoelectric cooling.  For power generation, refer to figure below:          For customer support or general questions please contact a local office or visit our website at www.marlow.com.  Marlow reserves the right to make product changes without notice.    MI Form 005‐0690 Rev. 4  DOC # 102‐0278 REV K ‐ PAGE 3 OF 3  www.marlow.com
RC12-6-01S
物料型号:RC12-6 器件简介:单级热电模块,符合RoHS和REACH欧盟标准,额定工作温度130°C,使用氧化铝陶瓷材料,具有增强的引线强度和优越的镍扩散屏障。 引脚分配:提供不同长度和类型的引线选项,例如RC12-6-01(102mm引线)、RC12-6-01L(102mm打磨引线)、RC12-6-01S(102mm密封引线)等。 参数特性:在27°C和50°C的热侧温度下,模块的最大工作温度(Tmax)、最大热负荷(Qmax)、最大电流(Imax)、最大电压(Vmax)、交流电阻以及设备ZT值。 功能详解:建议在130°C以下、非凝结环境下存储和操作,以最小化冷却模式下的热应力,推荐使用线性/比例温度控制或类似方法,而不是开关控制。 应用信息:适用于需要高可靠性和在恶劣环境下工作的场合,提供打磨选项以适应多个模块应用。 封装信息:详细列出了引线规格和尺寸,包括正负引线的颜色和尺寸。
RC12-6-01S 价格&库存
很抱歉,暂时无法提供与“RC12-6-01S”相匹配的价格&库存,您可以联系我们找货
RC12-6-01S
  • 50+353.7043250+45.89285
