0.70
0.90
No5
1.20
4.10
0.65
1.20
0.80
3.75
5.05
4.25
2.50
3.10 ref.
5.30
G
F
0.45
No1
R0
Pick&Place Area
Ø3.00
0.65
.50
2.60
1.20
H
PCB EDGE
7.90
8.30
9.55
9.70
Specifications
Material
Insulator: High Temp. Plastic UL 94V-0, Black
Contact:Copper Alloy
Shell(including pegs):Stainless Steel
Recommended PCB Layout
6.90+0.10
-0.02
R0.25±0.15
Solder Area
A
Component Outline
A
No5
3.50
B
Mechanical & Environmental
Operating Temperature: -30°C to +85°C
Mating Force: 35N max.
Unmated Force: 8N to 25N
Durability: 10,000 cycles
Ingress Protection Rating: IP67
4x Ø0.60
2x 2.50
C
2x 2.10
10.30
9.70
Electrical
Current Rating: Signal (Pins 2,3,4): 1.0A
Power (Pins 1,5): 1.8A
Voltage Rating: 30V AC
Contact Resistance: 30mΩ max.
Dielectric Withstanding Voltage: 100V AC
Insulation Resistance: 1000MΩ min. 100V DC
2.95
0.60
No1
1.425±0.20
D
R0.25
Plating
Contact: 30µ" Gold
Shell: 50µ"-80µ" Nickel over all
0.08
2.85
4.90
0.60
E
1.85+0.10
-0.02
3.50
As viewed from component side Tolerance:±0.03mm
Recommended PCB Thickness: 0.60mm
Section A-A
Ordering Grid
5x 0.95±0.10
5x 0.30±0.08
A
1
1.30±0.08
2.60±0.08
USB3500
30
A
Contact Plating
30 = 30µ" Gold
Request Samples
and Quotation
Packing Options
A = Tape & Reel
Part Number
Product Description
USB3500
Micro USB Type B Receptacle,Mid-Mount,IP67
Drawing Date
16th January 2019
By
(1,000 per reel)
2
3
4
Detail
Revision
Date
5
CC
Drawing
Release
A2
20/12/19
Tolerances (Except as Noted)
Length
Angle
X. ± 0.50
X.X ± 0.30
X.XX ± 0.20
X.XXX ± 0.10
± 1°
Units:
Metric (mm)
C
3rd Angle Projection
6
7
This drawing is confidential and
copyright of Global Connector
Technology, Ltd (GCT).
This drawing must not be copied
or disclosed without written
consent. E & OE
www.gct.co
Not to
Scale
Drawn By
CC
8
Sheet No.
1/4
H
R0
C 0.20
.6
R1
.0
Panel
5
4.70
2.05
3.10
6.61
G
45
R0
F
.35
7.10
8.85+0.20
-0.00
8.20
0.50
9.80
1.00
7.10+0.00
-0.15
R0.30
3.80+0.20
-0.00
E
Recommended Panel Spec
Tolerance:±0.05mm
2.05+0.00
-0.15
1.50
90°
0.40mm Min gasket compression
between panel and shell
D
(Suggest compression 40-50%
of gasket thickness)
0.90+0.10
-0.05
0.60
C
Recommended Waterproof Gasket
Gasket Part No.: USBTJ-02
(Gasket must be ordered separately)
(See separate datasheet for specification)
B
(Suggest compression 40-50% of gasket thickness)
A
Part Number
Product Description
USB3500
Drawing Date
16th January 2019
By
Detail
1
2
3
4
Revision
Date
5
CC
Drawing
Release
A2
20/12/19
Length
Angle
X. ± 0.50
X.X ± 0.30
X.XX ± 0.20
X.XXX ± 0.10
± 1°
Units:
Metric (mm)
C
6
7
consent. E & OE
www.gct.co
Not to
Scale
Drawn By
CC
8
Sheet No.
2/4
H
G
F
Panel
Panel
Connector
Gasket
E
D
Step 2
Step 1
C
Step 3
Assembly instruction for Gasket set after Reflow
Available for Micro USB Waterproof Series
B
Part Number
Product Description
USB3500
Drawing Date
16th January 2019
A
By
Detail
Revision
Date
1
2
3
4
5
CC
Drawing
Release
A2
20/12/19
Length
Angle
Units:
Metric (mm)
C
6
7
consent. E & OE
www.gct.co
Not to
Scale
Drawn By
CC
8
Sheet No.
3/4
H
30.5
24.5
Label
Tape & Reel
400
min.
Ø330
G
Peeling Angle
165° ~ 180°
Vacuum Bag
F
20pcs empty
Unloaded Section
20pcs empty
Unloaded Section
Product Loaded Section
User Direction of Unreeling
Void filler
1.75
E
12.00
2.00
Inner carton dimensions
340mm x 340mm x 285mm
.50
Ø1
11.50
24.00
D
4.00
C
B
A
Pcs /
Reel
1000
Notes:
Peeling off force of top tape: 0.1-1.3N (Peeling direction as shown)
Materials:
Carrier Tape: Polystyrene (PS)
Top Tape: PE
Reel Tape: Polystyrene (PS)
Bag: PE
Reels /
Carton
9
Part Number
Product Description
USB3500
Drawing Date
16th January 2019
By
Detail
Revision
Date
1
2
Box dimensions
355mm x 355mm x 305mm
Total
Quantity
9000
3
4
5
CC
Drawing
Release
A2
20/12/19
Length
Angle
Units:
Metric (mm)
C
6
7
consent. E & OE
www.gct.co
Not to
Scale
Drawn By
CC
8
Sheet No.
4/4
很抱歉,暂时无法提供与“USB3500-30-A-KIT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1000+13.937101000+1.80402
- 国内价格 香港价格
- 1+22.451381+2.90610
- 10+19.0512010+2.46598
- 25+17.8542225+2.31105
- 50+16.9985350+2.20029
- 100+16.18671100+2.09520
- 250+15.17287250+1.96397
- 500+14.44868500+1.87023
- 国内价格 香港价格
- 25+17.8537925+2.31099
- 50+16.9979050+2.20020
- 100+16.18628100+2.09515
- 250+15.17240250+1.96391
- 500+14.44823500+1.87018
