SHUTTLE BOARD SET BHA260AB
    BOSCH(博世)
SHUTTLE BOARD SET BHA260AB 数据手册
Bosch Sensortec BHA260 Shuttle Board GENERAL DESCRIPTION Bosch Sensortec’s BHA260 shuttle board is a PCB with the BHA260, a smart sensor sub with integrated acceleration sensor, mounted on it. In addition to the BHA260, the board includes  on M2 master interface (configured as SPI):  a BMG250 Gyroscope  on M3 master interface (configured as I2C):  a BME280 environmental sensor (p, rH, T)  a BMM150 magnetometer  an AK09915 magnetometer connected to the BHA260. Additional sensors can be connected to the M3 I2C bus, using connector J6. The shuttle board allows easy access to pins of the smart sensor hub via a simple socket. The shuttle board comes pre-mounted on a level-shifter board, which allows the PCB stack to be directly plugged into Bosch Sensortec’s advanced development tool (application board). Block diagram of BHA260 shuttle board BHA260 shuttle board mounted on level-shifter board (product photo may differ from real product appearance). Do not connect the shuttle board directly to the application board, as this can lead to severe damage of the shuttle board and its components. Connection of shuttle board, level shifter board and application board Bosch Sensortec | BHA260 Designator J1 Function Shuttle board connector J2, J3, J8 Pull-up resistors for host interface running in I2C mode J4 2-wire JTAG connector J5 J6 J7, J9, J10 2|6 SPI/I2C mode & IC2 address selection M3 I2C interface for bus extensions Access points to BHA260 supply (e.g. for power measurement) Description Pin number Pin name Description 1 VDD Power supply (1.8V only!) 2 VDDIO Power supply (1.8V only!) 3,23 GND Ground 4,15 MISO Master-input-slave-output data pin of SPI bus (connected to BHA260 host interface) 5,17 MOSI 6,18 SCK 7 CS 21 INT Master-output-slave-input data pin of SPI bus, or SDA of I2C bus (connected to BHA260 host interface) Clock pin of both SPI and I2C bus (connected to BHA260 host interface) Chip selection pin of SPI bus (connected to BHA260 host interface) Host interrupt pin (connected to BHA260 host interrupt) 13,12,11, 10,28,27, 26,25,24 COD[x] 8,9,14, 15,16,19, 20,22, NC Device code for application board, COD of BHA260 shuttle board is [100111001]. Not used. J2: BHA260 HSCX pad(SCK) J3: BHA260 HSDX pad(SDA) J8: BHA260 HCSB pad(SPI Chip select) Pin number Pin name Description 1 2,3 TMS NC TMS pin of 2-wire JTAG Not used 4 5 CLK GND CLK pin of 2-wire JTAG Ground on board 6 VDDIO 1.8V power supply on board Setting Mode I2C address Open SPI - Left (towards R12) I2C 0x28 Right (towards R10) I2C 0x29 Pin number 1 Pin name Description M3_SDA SDA pin of M3, with a 4.7kohm pull-up to 1.8V VDDIO SCL pin of M3, with a 4.7kohm pull-up to 1.8V VDDIO 2 M3_SCL 3 GND Ground pin. J7: BHA260 VDD pad J9: BHA260 VDDIO pad J10: BHA260_GND (GND+GNDIO) line Data & Specification are preliminary and subject to change without notice | | Bosch Sensortec GmbH reserves all rights even in the event of industrial property rights. We reserve all rights of disposal such as copying and passing on to third parties. BOSCH and the symbol are registered trademarks of Robert Bosch GmbH, Germany. Doc.-Number: BST-DHW-FL028-01 / Version_1.0_060618 Bosch Sensortec | BHA260 BHA260 shuttle board layout – placement (top, bottom) 3|6 BHA260 shuttle board outline dimensions (in mm) BHA260 shuttle board schematics Data & Specification are preliminary and subject to change without notice | | Bosch Sensortec GmbH reserves all rights even in the event of industrial property rights. We reserve all rights of disposal such as copying and passing on to third parties. BOSCH and the symbol are registered trademarks of Robert Bosch GmbH, Germany. Doc.-Number: BST-DHW-FL028-01 / Version_1.0_060618 Bosch Sensortec | BHA260 4|6 BHA260 shuttle board schematics Headquarters Bosch Sensortec GmbH Gerhard-Kindler-Strasse 9 72770 Reutlingen · Germany Telephone +49 7121 3535 900 Fax +49 7121 3535 909 www.bosch-sensortec.com Data & Specification are preliminary and subject to change without notice | | Bosch Sensortec GmbH reserves all rights even in the event of industrial property rights. We reserve all rights of disposal such as copying and passing on to third parties. BOSCH and the symbol are registered trademarks of Robert Bosch GmbH, Germany. Doc.-Number: BST-DHW-FL028-01 / Version_1.0_060618
SHUTTLE BOARD SET BHA260AB 价格&库存
很抱歉,暂时无法提供与“SHUTTLE BOARD SET BHA260AB”相匹配的价格&库存,您可以联系我们找货
