SHUTTLE BOARD SET BHI260AB
    BOSCH(博世)
SHUTTLE BOARD SET BHI260AB 数据手册
Bosch Sensortec BHI260 Shuttle Board GENERAL DESCRIPTION Bosch Sensortec’s BHI260 shuttle board is a PCB with the BHI260, a smart sensor hub with integrated IMU sensor, mounted on it. In addition to the BHI260, the board includes  on M2 master interface (configured as I2C):  a BME280 environmental sensor (p, rH, T)  a BMM150 magnetometer  an AK09915 magnetometer on QSPI interface:  a W25Q32FWSSI 4M-Byte flash memory connected to the BHI260. Addition sensors can be connected to the M3 I2C bus, using connector J8. The shuttle board allows easy access to pins of the smart sensor hub via a simple socket. The shuttle board comes pre-mounted on a level-shifter board, which allows the PCB stack to be directly plugged into Bosch Sensortec’s advanced development tool (application board). Block diagram of BHI260 shuttle board BHI260 shuttle board mounted on level-shifter board (product photo may differ from real product appearance). Do not connect the shuttle board directly to the application board, as this can lead to severe damage of the shuttle board and its components. Connection of shuttle board, level shifter board and application board Bosch Sensortec | BHI260 Designator J1 2|6 Function Shuttle board connector Description Pin number Pin name Description 1 VDD Power supply (1.8V only!) 2 VDDIO Power supply (1.8V only!) 3,23 GND Ground 4,15 MISO Master-input-slave-output data pin of SPI bus (connected to BHI260 host interface) 5,17 MOSI 6,18 SCK 7 CS 21 INT Master-output-slave-input data pin of SPI bus, or SDA of I2C bus (connected to BHI260 host interface) Clock pin of both SPI and I2C bus (connected to BHI260 host interface) Chip selection pin of SPI bus (connected to BHI260 host interface) Host interrupt pin (connected to BHI260 host interrupt) 13,12,11, 10,28,27, 26,25,24 COD[x] 8,9,14, 15,16,19, 20,22, NC Device code for Application board, COD of BHI260 shuttle board is [100011001]. Not used. J2,J3,J4 Access points to BHI260 supply (e.g. for power measurement) J2: BHI260 VDD pad J3: BHI260 VDDIO pad J4: BHI260_GND (GND+GNDIO) line J5,J6 Pull-up resistors for host interface running in I2C mode J5: BHI260 HSCX pad(SCK) J6: BHI260 HSDX pad(SDA) J7 Boot source selection J7: BHI260 HOSTBOOT pad J8 M3 I2C interface for bus extensions J18 J19,J20 2-wire JTAG connector Bus master selection for I2C sensors on shuttle board Pin number Pin name Description M3_SDA SDA pin of M3, with a 4.7kohm pull-up to 1.8V VDDIO 2 M3_SCL SCL pin of M3, with a 4.7kohm pull-up to 1.8V VDDIO 3 GND Pin number Pin name 1 TMS 2,3 NC Not used. 4 CLK CLK pin of 2-wire JTAG. 5 GND Ground pin. 6 VDDIO 1 Ground pin. Description TMS pin of 2-wire JTAG. Power supply of JTAG, connected to VDDIO of BHI260. Jumper setting Bus master of sensors M2 (Left) M2 of BHI260 AUX (Right) AUX of BHI260 Data & Specification are preliminary and subject to change without notice | | Bosch Sensortec GmbH reserves all rights even in the event of industrial property rights. We reserve all rights of disposal such as copying and passing on to third parties. BOSCH and the symbol are registered trademarks of Robert Bosch GmbH, Germany. Doc.-Number: BST-DHW-FL026-01 / Version_1.0_060618 Bosch Sensortec | BHI260 BHI260 shuttle board layout – placement (top, bottom) 3|6 BHI260 shuttle board outline dimensions (in mm) BHI260 shuttle board schematics Data & Specification are preliminary and subject to change without notice | | Bosch Sensortec GmbH reserves all rights even in the event of industrial property rights. We reserve all rights of disposal such as copying and passing on to third parties. BOSCH and the symbol are registered trademarks of Robert Bosch GmbH, Germany. Doc.-Number: BST-DHW-FL026-01 / Version_1.0_060618 Bosch Sensortec | BHI260 4|6 BHI260 shuttle board schematics Headquarters Bosch Sensortec GmbH Gerhard-Kindler-Strasse 9 72770 Reutlingen · Germany Telephone +49 7121 3535 900 Fax +49 7121 3535 909 www.bosch-sensortec.com Data & Specification are preliminary and subject to change without notice | | Bosch Sensortec GmbH reserves all rights even in the event of industrial property rights. We reserve all rights of disposal such as copying and passing on to third parties. BOSCH and the symbol are registered trademarks of Robert Bosch GmbH, Germany. Doc.-Number: BST-DHW-FL026-01 / Version_1.0_060618
SHUTTLE BOARD SET BHI260AB 价格&库存
很抱歉,暂时无法提供与“SHUTTLE BOARD SET BHI260AB”相匹配的价格&库存,您可以联系我们找货
