This document contains data proprietary to PUI Audio Inc. Any use or reproduction, in any form, without prior written permission
of PUI Audio Inc. is prohibited.
©2017, PUI Audio Inc.
Data Sheet
DOM-3027L-HD-R
PUI Audio’s all-new HD Series microphones use premium-grade FETs and
diaphragms for high sensitivity and superior signal-to-noise ratio. Each
microphone features GSM buzz-blocking capacitors. Upgrade the ECM
microphone that you use today with a PUI Audio HD Series microphone.
The 8mm diameter DOM-3027L-HD-R is designed for extreme fidelity, in even
the quietest settings, from 20 Hz to 20 kHz.
Features:
• 8mm diameter
• 3mm height
• -27 dB sensitivity
• 77 dB signal-to-noise ratio
• True 20 Hz to 20 kHz performance
Specifications
Parameters
Sensitivity (1 kHz @ 50cm)
0 dB=1V/Pa
Rated Voltage
Output Impedance (@ 1 kHz)
Current consumption
(3VS with 2.2 kΩ RL)
Signal-to-Noise Ratio
(1kHz, 94 dB input, A-weighted)
Decreasing Voltage (3VS to 2VS)
Frequency Range
Operating Voltage Range
Maximum SPL Input (THD
很抱歉,暂时无法提供与“DOM-3027L-HD-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+33.41520
- 200+13.33800
- 500+12.89520
- 1000+12.66840
