PORTENTA H7
Code: 7630049202252
WiFi 32 bit ARM 100 mA 3.3V Large (~70) LiPo
The Portenta H7 will be ready for shipment approximately at the
end of March 2020.
Program it with high-level languages and AI while performing
low-latency operations on its customizable hardware.
Portenta H7 simultaneously runs high level code along with real time
tasks. The design includes two processors that can run tasks in parallel.
For example, is possible to execute Arduino compiled code along with
MicroPython one, and have both cores to communicate with one another.
The Portenta functionality is two-fold, it can either be running like any
other embedded microcontroller board, or as the main processor of an
embedded computer. Use the Portenta Carrier board to transform your H7
into an eNUC computer and expose all of the H7 physical interfaces.
Portenta can easily run processes created with TensorFlow™ Lite, you
could have one of the cores computing a computer vision algorithm on the
fly, while the other could be making low level operationis like controlling a
motor, or acting as a user interface.
Use Portenta when performance is key, among other cases, we envision it
to be part of:
High-end industrial machinery
Laboratory equipment
Computer vision
PLCs
Industry-ready user interfaces
Robotics controller
Mission-critical devices
Dedicated stationary computer
High-speed booting computation (ms)
Two Parallel Cores
H7's main processor is the dual core STM32H747 including a Cortex® M7
running at 480 MHz and a Cortex® M4 running at 240 MHz. The two cores
communicate via a Remote Procedure Call mechanism that allows calling
functions on the other processor seamlessly. Both processors share all
the in-chip peripherals and can run:
Arduino sketches on top of the Arm® Mbed™ OS
Native Mbed™ applications
MicroPython / JavaScript via an interpreter
TensorFlow™ Lite
Graphics Accelerator
Probably one of the most exciting features of the Portenta H7 is the
possibility of connecting an external monitor to build your own dedicated
embedded computer with a user interface. This is possible thanks to the
STM32H747 processor's on-chip GPU, the Chrom-ART Accelerator™.
Besides the GPU, the chip includes a dedicated JPEG encoder and
decoder.
A new standard for pinouts
The Portenta family adds two 80 pin high density connectors at the
bottom of the board. This ensures scalability for a wide range of
applications by simply upgrading your Portenta board to the one suiting
your needs.
On-board Connectivity
The onboard wireless module allows to simultaneously manage WiFi and
Bluetooth® connectivity. The WiFi interface can be operated as an Access
Point, as a Station or as a dual mode simultaneous AP/STA and can
handle up to 65 Mbps transfer rate. Bluetooth® interface supports
Bluetooth Classic and BLE. It is also possible to expose a series of
different wired interfaces like UART, SPI, Ethernet, or I2C, both through
some of the MKR styled connectors, or through the new Arduino industrial
80 pin connector pair.
USB-C Multipurpose Connector
The board's programming connector is a USB-C port that can also be
used to power the board, as a USB Hub, to connect a DisplayPort
monitor, or to deliver power to OTG connected devices.
Multiple options in one board
Order the default Arduino Portenta H7 (codename H7-15EUNWAD) that
comes with:
STM32H747 dual-core processor with graphics engine
8MB SDRAM
16MB NOR Flash
10/100 Ethernet Phy
USB HS
NXP SE050C2 Crypto
WiFi/BT Module
Ceramic Antenna
DisplayPort over USB-C
If you need more memory, Portenta H7 can host up to 64 MByte of
SDRAM, and 128 MByte of QSPI Flash. Order it with an external UFL
connector for adding a higher-gain antenna to the board. Decide between
crypo-chips from Microchip® and NXP. The board is highly customizable
in volumes, ask our sales representatives for options.
The basic configurations you can consider to get the board to
accommodate to your needs and budget are:
Option
Description
Option Codes
external SDRAM memory
2
3
4
None
8 MByte
16 MByte
32 MByte
64 MByte
FLASH
external QSPI Flash Memory
5
8
None
2 MByte (NOR)
16 MByte (NOR)
128 MByte (NAND)
Ethernet
10/100 Ethernet PHY
0 - None
E - Fitted
HS USB
High Speed USB PHY
0 - None
U - Fitted
Crypto
Crypto Chip
0 - None
M - ATECC608A
N - SE050C2
Wireless
Wireless Module
0 - None
W - Fitted
Antenna
Antenna option
0 - None
A - on board ceramic antenna
C - UFL connector
Video
Displayport output over USB-C
0 - None
D - Fitted
SDRAM
Need Help?
Check the Arduino Forum for questions about the Arduino Language, or
how to make your own Projects with Arduino. Need any help with your
board please get in touch with the official Arduino User Support as
explained in our Contact Us page.
Warranty
You can find here your board warranty information.
https://www.arduino.cc/en/Main/warranty
The Arduino Portenta H7 is based on the STM32H747 microcontroller, XI
series.
Microcontroller
STM32H747XI dual Cortex®-M7+M4 32bit low
power ARM MCU (datasheet)
Radio module
Murata 1DX dual WiFi 802.11b/g/n 65 Mbps and
Bluetooth 5.1 BR/EDR/LE (datasheet)
Secure Element
(default)
NXP SE0502 (datasheet)
Board Power Supply
(USB/VIN)
5V
Supported Battery
Li-Po Single Cell, 3.7V, 700mAh Minimum
(integrated charger)
Circuit Operating
Voltage
3.3V
Current Consumption
2.95 μA in Standby mode (Backup SRAM OFF,
RTC/LSE ON)
Display Connector
MIPI DSI host & MIPI D-PHY to interface with lowpin count large display
GPU
Chrom-ART graphical hardware Accelerator™
Timers
22x timers and watchdogs
UART
4x ports (2 with flow control)
Ethernet PHY
10 / 100 Mbps (through expansion port only)
SD Card
Interface for SD Card connector (through expansion
port only)
Operational
Temperature
-40 °C to +85 °C (excl. Wireless module) / -10 °C to
+55 °C (incl. Wireless module)
MKR Headers
Use any of the existing industrial MKR shields on it
High-density
Connectors
Two 80 pin connectors will expose all of the board's
peripherals to other devices
Camera Interface
8-bit, up to 80 MHz
ADC
3× ADCs with 16-bit max. resolution (up to 36
channels, up to 3.6 MSPS)
DAC
2× 12-bit DAC (1 MHz)
USB-C
Host / Device, DisplayPort out, High / Full Speed,
Power delivery
OSH: Schematics
The Portenta H7 is open-source hardware! You can study how the board
works using the following files:
SCHEMATICS IN .PDF
https://content.arduino.cc/assets/Arduino-PortentaH7-schematic-V1.0.pdf
Pinout Diagram
The Portenta H7 follows the Arduino MKR form factor, but enhanced with
the Portenta family 80 pin high-density connector. Learn more about the
board's pinout by reading the board's pinout documentation.
Download the full pinout diagram as PDF here.
https://content.arduino.cc/assets/Pinout-PortentaH7_latest.pdf
Interactive Board Viewer
Additional I2C Port
The Portenta H7 has an additional connector meant as an extension of
the I2C bus. It's a small form factor 5-pin connector with 1.0 mm pitch.
The mechanical details of the connector can be found in the connector's
datasheet.
https://content.arduino.cc/assets/ESLOV_connector.pdf
The I2C port, also referred to as the Eslov self-identification port within
Arduino, comes with: SDA, SCL, GND, +5V, and an extra digital pin meant
to send an alarm to the otherwise plain I2C devices connected to it. The
pinout is shown in the following image:
If you are interested in designing your own modules for Arduino boards
with this expansion port, the connector we suggest using is code: SHR05V-S-B, also in the picture.
https://store.arduino.cc/usa/portenta-h7/3-13-20
https://www.arduino.cc/pro/hardware/product/portenta-h7
很抱歉,暂时无法提供与“ABX00042”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+943.78523
- 10+923.20749
- 25+904.30637
- 国内价格 香港价格
- 1+1031.736421+128.04969
- 10+1011.0938010+125.48772
- 25+993.6059125+123.31728
- 50+967.2462450+120.04576
