MIKROE-2503
MIKROE-2503
    MIKRO
    MIKROE-2503
MIKROE-2503 数据手册
MSP432 Clicker PID: MIKROE-2503   MSP432 clicker is a compact development board with a mikroBUS™ socket for click board connectivity. It carries the SimpleLink™ MSP432™ - ARM® 32-Bit Cortex®-M4F CPU with integrated 1Msps 14-bit SAR-based ADC from Texas Instruments. Everything you need to get started The board features everything you need to get started: a 32-bit MSP432™ microcontroller, micro USB connector, two LEDs and push buttons, reset button and headers for interfacing with external electronics. SimpleLink™ MSP432™ microcontroller The SimpleLink™ MSP432™ microcontroller is ultra-low-power microcontrollers with highperformance processing capabilities and high-precision analog integration optimized for as host MCU for wireless connectivity, sensing and measurement. The SimpleLink™ MSP432™ MCUs feature the ARM Cortex-M4 processor in a wide configuration of device options including a rich set of high-precision analog, timing, and communication peripherals, thereby catering to a large number of application scenarios where both efficient data processing and enhanced low-power operation are paramount. The MCU has 256KB of Flash Main Memory (Organized Into Two Banks Enabling Simultaneous Read/Execute During Erase). 16KB of Flash Information Memory (Used for BSL, TLV, and Flash Mailbox). Up to 64KB of SRAM (Including 6KB of Backup Memory). 32KB of ROM With MSP432™ Peripheral Driver Libraries. Hundreds of possibilities with click boards™ Take advantage of the constantly expanding range of over 270 click boards™ - the onboard mikroBUS™ socket allows you to add new functionality to your project. Each click board™ comes with a set of working example code. Programming To make your prototyping experience as convenient as possible, MSP432 clicker is preprogrammed with a UART bootloader. Just download our mikroBootloader application and you’re ready to upload your firmware. On-board mikroProg for MSP432 connector enables programming through external programmer/debugger. Product Type ARM This compact development board brings the flexibility of click boards to Applications your favorite microcontroller, making it a perfect starter kit for implementing your ideas. Architecture ARM (32-bit) MCU MSP432 from Texas Instruments MCU Memory 256KB of Flash Main Memory, 64KB of SRAM On-board modules 1 x USB MINI-B connector, 2 x LEDs, 2 x push buttons, 1 x reset button Expandability mikroBUS socket https://shop.mikroe.com/development-boards/starter/clicker/msp432 3/21/2017
MIKROE-2503 价格&库存
很抱歉,暂时无法提供与“MIKROE-2503”相匹配的价格&库存,您可以联系我们找货
