USB3140-30-0170-1-C
USB3140-30-0170-1-C
    GCT
    SMD
    USB连接器 Micro-B 5P 立贴 端口数:1 额定电流:1A,1.8A 额定电压:30V 工作温度:-30℃~+85℃
USB3140-30-0170-1-C 数据手册
4.0 With mating entry face 3.5 Without mating entry face 6.85 5.55 7.1 With mating entry face 6.6 Without mating entry face 11.0 4.00 H 5x 0.30±0.10 G 1.30±0.10 2.60±0.10 Cap 5.3 0.2 3.2 1.8 7.15 0.25 PCB Mount &Cap Information F (2.06) 6.50 0.50 E Specifications f) (re Material Plastic Housing: LCP, UL94V-0, Black Contact Terminal: Copper Alloy Metallic Shell: Stainless Steel T=0.25mm. 1.18 3.50±0.10 .50 Ø2 2.70+0.05 -0.08 (3.42) LOGO Area 0.60±0.05 Pick & place cap Plating Contact Terminal: Contact Area:30µ" Gold Solder Tails: Gold Flash Underplating: 50µ" Nickel Metallic Shell: Matte Tin over 50µ" Nickel Pick & place area (3.40) Section A-A 4.75±0.10 Pin 1 1.50 1.64 0.10 0.40 25 R0 . A PIN 5 S=0.70mm 0.20 Solder Area 0.50 USB3140 0.05 0.50 0.50 Detail A 0.20 2 30 XXXX X Mechanical & Environmental Mating Force: 35N max. Unmating Force:Initial 10N min Final 8N min after durability test Durability: 10,000 Cycles Request Samples and Quotation C Contact Plating 30 = 30µ" Gold 0.20 Shell Stake Length "S" 0070 = 0.70mm 0140 = 1.40mm 0170 = 1.70mm 0230 = 2.30mm Designed to comply with physical, electrical and environmental requirements of Micro USB Standard (USB2.0) Detail B 1 Component Outline Packing Options C = Tape & Reel with Cap (500 per reel) S=0.70mm S=1.40mm S=1.70, 2.30mm 0.20 S±0.20 (1.7mm stake shown) Recommended PCB Layout As viewed from component side General tolerance: ±0.05 Ordering Grid Detail A Scale 2:1 0.20 7.15 S=1.40, 1.70, 2.30mm 0.05 A 1.40 1.10 Optional Mating Entry faces C B 0.60 Detail B Pin 1 Electrical Voltage Rating: 30 V AC Current Rating: Signal (Pins 2,3,4): 1.0 A. Power (Pins1,5): 1.8A. Operating Temperature: -25°C to +85°C. Contact Resistance: 30mΩ max. Insulating Resistance: 1000MΩ min. Dielectric Withstand Voltage: 500V AC/minute 2x 1.95 A 0.80 0.05±0.05 3.50Max .2 5 2.77 R0 0.65 0.36±0.10 1.85+0.08 -0.02 D Pin 5 2.60 6.00 6.90+0.06 -0.02 2x 1.15 7.80 3 4 Mating Entry Face 1 = With Mating Entry Face (Standard) 0 = Without Mating Entry Face Part Number Product Description USB3140 Micro USB Receptacle, Type B, Surface Mount, Vertical, with Through-Hole Shell Stakes Drawing Date 2nd April 2013 By Detail Revision Date 5 CC USB3140 E PCN E3 04/05/21 Tolerances (Except as Noted) Length Angle X.±0.50 X.X ± 0.30 X.XX ± 0.20 X.XXX ± 0.10 X.X° ± 2° Units: Metric (mm) C 3rd Angle Projection 6 7 This drawing is confidential and copyright of Global Connector Technology, Ltd (GCT). This drawing must not be copied or disclosed without written consent. E & OE www.gct.co Not to Scale Drawn By AJO 8 Sheet No. 1/2 30.4 Tape & Reel Label 24.4 H in Peeling Angle 165° ~ 180° Ø330 400 m G Vacuum Bag 15 pcs min Empty F End of reel 15 pcs min Empty Start of reel Packing 500pcs product -0 0.1 .0 0 0 4.00±0.10 12.00±0.10 Inner carton dimensions: 340mm x 340mm x 285mm 21.30 11.50±0.15 24.00±0.30 Ø E Void filler 2.00±0.10 1. 50 + 1.75±0.15 User Direction of Unreeling Cover Tape. D Box dimensions: 355mm x 355mm x 305mm C Notes: Peeling off force of top tape: 0.1-1.3N (Peeling direction as shown) Materials: Carrier Tape: Polystyrene (PS) Top Tape: PE Reel Tape: Polystyrene (PS) B Pcs / Reel Reels / Carton 500 Product Description Micro USB Receptacle, Type B, Surface Mount, Vertical, with Through-Hole Shell Stakes By Detail Revision Date 2 3 4 4500 pcs USB3140 2nd April 2013 1 Total Quantity Part Number Drawing Date A 9 5 CC USB3140 E PCN E3 04/05/21 Tolerances (Except as Noted) Length X.±0.20 X.X ± 0.15 X.XX ± 0.10 X.XXX ± 0.05 Angle Units: Metric (mm) X.X° ± 2° C 3rd Angle Projection 6 7 This drawing is confidential and copyright of Global Connector Technology, Ltd (GCT). This drawing must not be copied or disclosed without written consent. E & OE www.gct.co Not to Scale Drawn By AJO 8 Sheet No. 2/2
USB3140-30-0170-1-C 价格&库存
很抱歉,暂时无法提供与“USB3140-30-0170-1-C”相匹配的价格&库存,您可以联系我们找货
USB3140-30-0170-1-C
  • 500+4.49347500+0.58368
  • 1000+4.278891000+0.55581
  • 1500+4.158221500+0.54013
  • 2500+4.011012500+0.52101
  • 3500+3.916913500+0.50879
  • 5000+3.819605000+0.49615
库存:22886
USB3140-30-0170-1-C
    USB3140-30-0170-1-C
      库存:10500
      USB3140-30-0170-1-C
      • 1+6.964181+0.90462
      • 10+5.9264910+0.76982
      • 25+5.5525825+0.72126
      • 50+5.2880950+0.68690
      • 100+5.03501100+0.65403
      • 250+4.71905250+0.61298
      库存:22886
