SM20B-SRDS-G-TF
SM20B-SRDS-G-TF
    JST
    SMD,P=1mm,卧贴
    线对板针座 2x10P 卧贴 间距:1mm
SM20B-SRDS-G-TF 数据手册
SHD CONNECTOR Crimp Emboss Tape Disconnectable Crimp style connectors 1.0mm (.039") pitch Features –––––––––––––––––––––––– • Ultra-compact, low profile design The SHD connector is compact with a mounting height of 6.3mm (.248") for top entry type and 5.5mm (.217") for side entry type, and a width of 5.0mm (.197") for top entry type and 5.1mm (.201") for side entry type. • Reliable contact The same contact can be used for the single-row SH connectors. • Anti-misinsertion feature Ribs and grooves on the header and receptacle prevent misinsertion and distortion during mating and unmating. • Receptacles with protrusions The receptacle has protrusions on both ends for an operator to disengage the receptacle from the header without holding the Ultra-compact, double-row design wires. • Header designed for vacuum pick and place robotics Although this shrouded header has locking features for its mating receptacle, there are no holes in the header shroud that would adversely effect vacuum gripping equipment. Since there is enough flat surface for secure vacuum gripping, this miniature surface mount connector is versatile for designers and economic for manufacturing. Specifications ––––––––––––––––––– 11 21 31 39 • Current rating: 1.0A AC, DC (AWG #28) • Voltage rating: 50V AC, DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/20m Ω max. After environmental testing/40m Ω max. • Insulation resistance: 100M Ω min. • Withstanding voltage: 500V AC/minute • Applicable wire: AWG #32 to #28 Insulation O.D./0.4 to 0.8mm (.016" to .031") * Contact JST for details. Standards –––––––––––––––––––––– 0 1 Recognized E60389 Certified LR20812 6 SHD CONNECTOR Contact ––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––– Model No. 3.9(.154) 1.6(.063) 1.55(.061) SSH-003GA-P0.2 0.8(.031) 0.032 to 0.08 32 to 28 0.4 to 0.8(.016 to .031) 23,000 Material and Finish 1.35(.053) 2.0(.079) 0.5(.020) 0.8(.031) Applicable wire Q'ty / Insulation O.D. mm(in.) reel AWG# mm2 Phosphor bronze, nickel-undercoated, selective gold-plated Note: Contact JST for tin-plated contacts. 0.45(.018) Housing ––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––– Dimensions mm(in.) Circuits Model No. 20 SHDR-20V-S-B 9.0(.354) 11.2( .441) 13.0( .512) 4,000 30 SHDR-30V-S-B 14.0(.551) 16.2( .638) 18.0( .709) 4,000 40 SHDR-40V-S-B 19.0(.748) 21.2( .835) 23.0( .906) 2,000 50 SHDR-50V-S-B 24.0(.945) 26.2(1.031) 28.0(1.102) 2,000 A C 4.9 (.193) A 1.0(.039) Circuit No.3 5.0 (.197) No.1 mark B Q'ty / box C Material PBT, UL94V-0, natural (white) 4.2 (.165) B Shrouded header ––––––––––––––––––––––––––––––––––––––––––––––––––––––––– Top entry type Circuits 20 4.25(.167) 30 1.0 (.039) 40 50 1.5 (.059) 0.2(.008) A B Circuit No.1 Circuit No.3 Circuits 0.7(.028) 5.0(.197) 20 30 Side entry type 40 Circuit No.3 Circuit No.1 50 Model No. Top entry type BM20B-SRDS-G-TF BM30B-SRDS-G-TF BM40B-SRDS-G-TF BM50B-SRDS-G-TF Model No. Side entry type SM20B-SRDS-G-TF SM30B-SRDS-G-TF SM40B-SRDS-G-TF SM50B-SRDS-G-TF H JST 0.2(.008) 0.7(.028) B 0.6(.024) 4.25(.167) Top entry type with a boss 1.0 (.039) 0.5(.020)dia. 0.2(.008) Circuit No.1 A B Circuit No.3 0.85(.033) 9.0(.354) 12.3( .484) 1,500 14.0(.551) 17.3( .681) 1,500 19.0(.748) 22.3( .878) 1,500 24.0(.945) 27.3(1.075) 1,500 Dimensions mm(in.) A B Q'ty / reel 9.0(.354) 13.1(.516) 1,250 14.0(.551) 18.1(.713) 1,250 19.0(.748) 23.1(.909) 1,250 24.0(.945) 28.1(1.106) 1,250 Header contact: Phosphor bronze, nickel-undercoated, gold-plated Wafer: Glass-filled polyamide, UL94V-0, natural (ivory) Solder tab: Brass, copper-undercoated, tin/lead-plated 1.5(.059) 5.1(.201) A Q'ty / reel Material and Finish 5.5(.216) 1.0 (.039) Dimensions mm(in.) A B 1.9 (.075) 1.5 (.059) 5.0(.197) Note: 1. The products listed above are supplied on embossed-tape. 2. Contact JST for the headers with tin-plated pins. 3. Contact JST for the top entry type headers with suction cap. Dimensions mm(in.) A B Q'ty / reel BM20B-SRDS-A-G-TF 9.0(.354) 12.3( .484) 1,250 BM30B-SRDS-A-G-TF 14.0(.551) 17.3( .681) 1,250 40 BM40B-SRDS-A-G-TF 19.0(.748) 22.3( .878) 1,250 50 BM50B-SRDS-A-G-TF 24.0(.945) 27.3(1.075) 1,250 Circuits Model No. 20 30 Material and Finish 0.7(.028) Header contact: Phosphor bronze, nickel-undercoated, gold-plated Wafer: Glass-filled polyamide, UL94V-0, natural (ivory) Solder tab: Brass, copper-undercoated, tin/lead-plated Note: 1. The products listed above are supplied on embossed-tape. 2. Contact JST for the headers with tin-plated pins. 7 SHD CONNECTOR Taping specifications –––––––––––––––––––––––––––––––––––––––––––––––––––––– Carrier tape 380.0±2.0(14.961±.079) Feeding direction W1+2.5 -1.0 (W1+.098 -.039 ) Lead tape (Unloaded area) 20 vacancies min. Connector loaded area 400(15.748)min. 2±0.5(.079±.02) 4.0±0.1 2.0±0.1 1.55±0.05dia. Feeding direction (.157±.004) (.079±.004) (.061±.002) 1.75±0.1 (.069±.004) (.069±.004) (20 circuits) 5.05 (.199) 0.8 (.031) 0.3±0.05 (.012±.002) Carrier tape F±0.1(.004) W±0.3(.012) F±0.1(.004) 1.75±0.1 4.0±0.1 2.0±0.1 1.55±0.05dia. Feeding direction (.157±.004) (.079±.004) (.061±.002) Tail tape (Unloaded area) 40.0(1.575)min. W±0.3(.012) (30,40,50 circuits) Top entry type S±0.1(.004) [13.0(.512)dia.] Cover tape leader area Feeding direction Cover tape 12.0±0.1 (.472±.004) (30,40,50 circuits) 1.75±0.1 (.069±.004) 5.75 (.226) 4.0±0.1 2.0±0.1 1.55±0.05 Feeding direction (.157±.004) (.079±.004) (.061±.002)dia. W F±0.1(.004) S±0.1(.004) 1.75±0.1 (.069±.004) (20 circuits) 4.0±0.1 2.0±0.1 1.55±0.05 Feeding direction (.157±.004) (.079±.004) (.061±.002)dia. 12.0±0.1 (.472±.004) Circuits Reel dimensions mm(in.) W1 W Top entry type Side entry type Top entry type Side entry type Top entry type Q'ty / reel Side entry type Top entry type Side entry type Top entry type Side entry type 24.0( .945) 25.5(1.004) 25.5(1.004) 1,500 1,250 32.0(1.260) 32.0(1.260) 33.5(1.319) 33.5(1.319) 1,500 1,250 40.4(1.591) 44.0(1.732) 44.0(1.732) 45.5(1.791) 45.5(1.791) 1,500 1,250 40.4(1.591) 44.0(1.732) 44.0(1.732) 45.5(1.791) 45.5(1.791) 1,500 1,250 20 11.5(.453) 11.5(.453) – – 24.0( .945) 30 14.2(.559) 14.2(.559) 28.4(1.118) 28.4(1.118) 40 20.2(.795) 20.2(.795) 40.4(1.591) 50 20.2(.795) 20.2(.795) 40.4(1.591) Note: 1. Specifications conform to JIS C 0806. The tape width, connector loading recess square dimensions, etc.are determined by the number of circuits and external shape of the connector to be loaded. Note: 2. Specifications are subject to change without prior notice. 8 Carrier tape Cover tape Dimensions mm(in.) S F 0.3±0.05 (.012±.002) F±0.1(.004) W±0.3(.012) Side entry type SHD CONNECTOR PC board layout (viewed from component side) and Assembly layout –––––––––––––––––– Side entry type Top entry type with a boss 5.4(.213) Circuit No.1 0.7 Header outline (.028) Circuit No.1 0.7 (.028) 1.0±0.1 0.6 (.039±.004) (.024) 0.9±0.1 (.035±.004) 0.85±0.1 (.033±.004) 0.5 (.020) 5.5 (.217) 4.1(.161) 0.85±0.1 (.033±.004) 1.9±0.1 (.075±.004) 0.9 1.8±0.1 (.035)(.071±.004) 1.5 (.059) 5.0(.197) 0.6 1.0±0.1 (.039±.004) (.024) 7.1 (.280) 1.6 (.063) Header outline 1.6 (.063) 0.85±0.1 (.033±.004) 6.3(.248) 0.9±0.1 (.035±.004) 0.5 (.020) 1.8±0.1 (.071±.004) 4.0(.157) 7.2(.283) 1.0±0.1 0.6 (.039±.004) (.024) 0.7 (.028) 1.5(.059) 5.1(.201) 0.7 (.028) 0.55+0.05 0 (.022+0.05 0 )dia. 1.8±0.1 (.071±.004) 4.0(.157) 7.2(.283) Top entry type Header outline Circuit No.1 0.85±0.1 1.25±0.1 (.049±.004) (.033±.004) Note: 1. Tolerances are non-Cumulative: ±0.05mm( ±.002") for all centers. Note: 2. Hole dimensions differ according to the kind of PC board and piercing method. Note: The dimensions above should serve as a guide line. Contact JST for details. Applicator for the semi-automatic press AP-K2N ––––––––––––––––––––––––––––––– Contact SSH-003GA-P0.2 Crimp applicator MKS-L-10-3 with safety cover without safety cover APLMK SSH/L003-02 APLNC SSH/L003-02 Compact crimp applicator MKS-LS with safety cover without safety cover – – Strip-crimp applicator MKS-SC with safety cover APLSC SSH003-02 9
SM20B-SRDS-G-TF 价格&库存
很抱歉,暂时无法提供与“SM20B-SRDS-G-TF”相匹配的价格&库存,您可以联系我们找货
SM20B-SRDS-G-TF
  • 1250+9.570841250+1.24418
  • 2500+9.114262500+1.18483
  • 3750+8.857423750+1.15144
  • 6250+8.544196250+1.11072
  • 8750+8.343958750+1.08469
库存:8230
SM20B-SRDS-G-TF
  • 1+15.888481+2.06545
  • 10+13.4566610+1.74933
  • 100+11.43864100+1.48699
  • 500+10.21014500+1.32729
库存:8230
SM20B-SRDS-G-TF
    • 1250+5.63490
    库存:10000
    SM20B-SRDS-G-TF
      • 1+10.20030
      • 10+8.44580
      • 30+7.47780
      • 100+6.37670
      • 500+5.89270
      库存:878
