DCJ250-20-B-K1-A
DCJ250-20-B-K1-A
    GCT
    插件
    DCJ250-20-B-K1-A
DCJ250-20-B-K1-A 数据手册
9.6 H +0.1 -0 Ø1.5 Specifications 规格 1 3 12 E E 2.75 6 2 5.5 Electrical 电气规格 Voltage Rating 电压额定值: 20 V DC Current Rating 电流额定值: 8 Amp Insulation Resistance 绝缘电阻值: 100 MΩ min. Dielectric Withstanding 耐电压: 500 V AC Contact Resistance 接触电阻值: 30 mΩ max. 0.8 13±0.5 G 2x2.00 2x0.8 F Recommended PCB Layout (Tolerance:±0.05mm) Mechanical & Environmental 机械 & 环境 Operating Temperature 工作温度: -20°C to +70°C Durability 耐久性: 5,000 cycles min. Ø1 .6 +0. - 1 0 Component Outline 5 6 10±0.5 1.6±0.1 5.1 10±0.5 Ø5 .3 2.2±0.25 5 Ø2. E D 2.75 1.5±0.1 9.6 C Ø 1 15 0. ± 5 .3 2 3 5.5 8.1 5.8 4 Circuit Diagram 6 Housing PA10T, UL94 V-0 1 1 Zinc Alloy, Nickel plating 1 2 Copper Alloy, Silver plating 1 2 Centre Pin 3 Tip Spring 4 Terminal Copper Alloy 1 5 Shield Plate Stainless Steel 1 6 Ground Terminal DCJ250 5 Ø5. Ø2. 55 (Reference) 1 Q'ty Material E Copper Alloy, Nickel plating 1 Ordering Grid 1.2±0.2 Mating Plug 12 0.49 1 1.5±0.15 Description No. +0 1 -0. 20 B XX Circuit Diagram B = 2 Conductors/2 Contacts Insulator Colour K1 = Black (Standard) O1 = Orange (157C) A Request Samples and Quotation Packing A = Tape & Reel (200 per reel) 1 B 2 # Terminal Number Part Number Product Description DCJ250-20 DC Power Jack, Thru-Hole, Horizontal, Shielded w/ Locating Peg, Ø2.50mm Pin mates with Ø2.55mm Plug Drawing Date A 8th December 2015 By Section A-A 1 2 3 Detail 4 Revision Date 5 CC Drawing Release A1 22/11/16 Tolerances (Except as Noted) Length Angle ± 0.3 ± 2° Units: Metric (mm) C 3rd Angle Projection 6 7 This drawing is confidential and copyright of Global Connector Technology, Ltd (GCT). This drawing must not be copied or disclosed without written consent. E & OE www.gct.co Not to Scale Drawn By AJO 8 Sheet No. 1/2 H Part Number Pcs/Reel Reels/Carton Cartons/Box Pcs/Box DCJ250-20 200 2 5 2000 Fig 3. Reel Desiccants 38.4 Max 32.4 Min G END 10 pcs (240mm) 200pcs (4800mm) 10 pcs (240mm) Empty Connectors Empty 1 Reel = 200 PCS Start 300mm Min Cover Tape Plastic Bag 330 Pullout direction F Fig 1. 14.2±0.15 1.75 E 0.4 Ø1 .55 1 Carton = 2 Reels = 400 Pcs 4±0.2 2±0.2 ±0 .15 32±0.3 28.4±0.15 D 1 Box = 5 Boxes = 2000 Pcs 24±0.1 B A 1.5 1.7 C Pullout direction Fig 2. REMARK: 1.The connector can not be loaded on the position of length 240mm in the reel tape and lead tape.The cover tape with 20~30mm length shall not be adhensive on the lead tape and the cover tape is lead portion shall have 300mm min length (Refer FIG 1). 2.Tape shall turn on right direction. 3.The direction of connector is fixed regarding the position of terminal,please refer outline drawing (Refer FIG 2). 4.After winding,using the adhesive tape(30~50mm) to stick the leader of cover tape on the side of reel. 5.One reel can be loaded 200 pcs connector. 6.The label shall be pasted on the front side of reel . 7.Condition of 300mm per minute ,the extraction strength of cover tape shall reach 20~150 gf. 8.If the quantity is less then 6 reels per carton, the packing shall be able to resist shaking. Part Number Product Description DCJ250-20 DC Power Jack, Thru-Hole, Horizontal, Shielded w/ Locating Peg, Ø2.50mm Pin mates with Ø2.55mm Plug Drawing Date 8th December 2015 By Detail Revision Date 1 2 3 4 5 CC Drawing Release A1 22/11/16 Tolerances (Except as Noted) Length Angle ± 0.3 ± 2° Units: Metric (mm) C 3rd Angle Projection 6 7 This drawing is confidential and copyright of Global Connector Technology, Ltd (GCT). This drawing must not be copied or disclosed without written consent. E & OE www.gct.co Not to Scale Drawn By AJO 8 Sheet No. 2/2
DCJ250-20-B-K1-A 价格&库存
很抱歉,暂时无法提供与“DCJ250-20-B-K1-A”相匹配的价格&库存,您可以联系我们找货
DCJ250-20-B-K1-A
    • 1+13.77000
    • 10+11.83680
    • 30+10.62720
    库存:7
    DCJ250-20-B-K1-A
    • 1+11.207911+1.45182
    • 10+9.5598210+1.23833
    • 25+8.9577925+1.16035
    • 50+8.5286950+1.10477
    • 100+8.12094100+1.05195
    库存:811
    DCJ250-20-B-K1-A
      DCJ250-20-B-K1-A
      • 200+7.73250200+1.00163
      • 400+7.36310400+0.95378
      • 600+7.15521600+0.92685
      库存:811
