WRL-15031
WRL-15031
    SPARKFUNELECTRONICS
    WRL-15031
WRL-15031 数据手册
    SparkFun WiFi IR Blaster (ESP8266) WRL-15031   DESCRIPTION Do you want to control your TV via a web-browser? Want to ask Alexa to mute your stereo? Want to schedule triggers to your IR-controlled LED strip? These are all applications that the WiFi IR Blaster is perfect for. The SparkFun WiFi IR Blaster is designed to connect all of those old, legacy IRcontrolled devices to a WiFi network exposing them to a new method of control with the Internet of Things. The WiFi IR Blaster combines an ESP8266 – a powerful WiFi/microcontroller SoC – with IR emitters and receivers. With built-in WiFi support, the ESP8266 can be programmed to provide an interface between HTTP, MQTT, TCP, and infrared-controlled devices. This module equips the ESP8266 with a crystal, 4MB flash, and a PCB antenna – just about everything it needs to get going. Please be aware that the antenna sits under the SparkFun logo on the board, so try not to place anything that may interfere with WiFi signals near that area. The IR emitter and detector components are packaged with the board, but not soldered in place. This allows you to solder both components at any angle your project requires. It also leaves the option to customize the board and spec out your own emitter and/or receiver. So some soldering will be required to get the WiFi IR Blaster operational. INCLUDES    1x SparkFun WiFi IR Blaster 1x LTE-302 IR Emitter 1x TSOP382 IR Detector                                                              https://www.sparkfun.com/products/15031/12‐10‐18
WRL-15031 价格&库存
很抱歉,暂时无法提供与“WRL-15031”相匹配的价格&库存,您可以联系我们找货
